  New Posts New Posts RSS Feed - Passive xover design with mismatched impedances
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Topic: Passive xover design with mismatched impedances
    Posted: 23 June 2008 at 2:06pm
I'm considering building prototype filter/xover with following specifications,
Input   impedance      :8 ohms
Output  impedance      :4ohms
Input freq range       :1khz-20khz
Power handling         :300W rms
Xover Point            :10khz with 12db rolloff
This will be connected in parallel with compression drivers to feed Bullets or Supertweeters.
Wondering if anyone has ciruits diags for anything similiar, and can recommend component types for PA audio use, especially inductors.
Know all about Links Dynamics, but they dont usually do 8ohm in, 4 ohm out xovers.
Regards.
Deadbeat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2008 at 3:33pm
Away on extended leave.
This page was generated in 0.107 seconds.
web department
