Patch Panel Help |
razorray
Registered User Joined: 06 December 2005 Location: London Status: Offline Points: 425 |
Posted: 19 January 2017 at 11:00pm |
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2537 |
What are you trying to do here?
Are you mounting each amp in a separate case or both in 1 case? Are you powering a low/mid/hi speaker stack with this or a bunch of separate fullrange speakers? |
Earplug
For a start, double up on the inputs so you have an In/Out for daisy-chaining. And on the outputs use seperate amp outs as in the "OR" above.
razorray
Each amp in a separate amp case.
Mono amp will be driving 4 bass speakers and the stereo amp will be driving 4 x 15s
MattStolton
If the amps feature neutrik "D" series XLRs, that you want to make into speakon, by use of patch panel, why not just mod the amplifiers direct, and upgrade the output XLR to speakon outlets?
