Pd 615wg in Turbosound Floodlight |
Post Reply | Page 123 4> |
montarbo
New Member Joined: 06 September 2006 Location: Germany Status: Offline Points: 9 |
Posted: 21 May 2016 at 1:07am |
Has anyone tried yet wheather the new Pd 615wg driver will work in a turbosound floodlight enclosure?
Will the phaseplug mount fit through the hole in the magnet when i cut a hole in the paper infront? Any experiences welcome. |
tv00
Old Croc Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
Perharps you should ask formidable audio as they had a new version 6,5" made for the flashlight in cooperation with Tony Andrews:
http://www.formidableaudio.com/flashlight-reborn/flashlight-refurb-in-detail/ I know a lot of people in here appears to think they're complete idiots making fake turbo-cabs, even though the designers are involved and everyone seems to agree they sound better, I REALLY like the sound of that bms 4540nd too! |
toastyghost
It's from the Flash refurb so if they had the same driver designation for Flood I would say yes.
Hvedstrup
Registered User Joined: 30 October 2009 Status: Offline Points: 413 |
They are not the same. Flashlight uses LS-6501 6,5" and Floodlight uses LS-6503 6,5".
The phase plugs are different and they won't fit in the Floodlights. I have heard that 615wg will indeed fit the Floodlights but nothing confirmed.
Edited by Hvedstrup - 05 October 2016 at 7:49am |
tv00
I have wg & wg/2 here if you want to try
Unless your system is sold before:-) |
toastyghost
http://www.formidableaudio.com/formidable-audio-provides-mk-iii-flashlight-for-newton-faulkner/
Bottom paragraph - they most definitely did put the 615wg and the BMS in their Floods. |
tv00
Do you think it's the pd shelf driver that's designed for it with T.A. support?
"All the 6.5-inch drivers have had an amazing makeover by Precision Devices with support from Turbosound co-founder Tony Andrews. Precision Devices, of course, was originally founded in 1987 to cover the loudspeaker manufacturing requirements of Turbosound." |
fatfreddiescat
Young Croc Joined: 15 October 2010 Location: N.E.Wales Status: Offline Points: 1081 |
The Floodlight phaseplug bolts through the pole piece as I have swapped them out, not done it on the Flashlight but IIRC the phase plug doesn't bolt through and the driver has a dustcap.
bee
Old Croc Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4553 |
Thanks(1)
can confirm they defo fit the floods, have done this and it was a great improvement, the original were warn and loose...
Sypa
Young Croc Joined: 21 February 2013 Location: Croatia Status: Offline Points: 920 |
Nice to know ! Could the 615wg recone fit the ls6503?
Also could some pd 12" recones fit the 12" from the floods or is that asking for too much? |
tv00
You should definately ask formidable what they're using, who will do this and update the thread? :-)
I doubt the driver designet with support from Tony is the shelf driver, but who knows? |
Sypa
Send me one and il put it in and give feedback as fast as possible
Well Bee confirmed up there so thats that I guess. All the 12" on my floods still work but they all rub when you push them a bit,so yeah they work but are they working as they should and as new,i doubt it. Think some of mine are 97 made so thats almost 20 years, gonna need some upgrades in the next few:) |
