PD186's over excursion and hot of Proline 3000 |
Post Reply | Page 123> |
tcourtneyvincent
Young Croc Joined: 04 January 2011 Location: Devon Status: Offline Points: 1146 |
Posted: 26 November 2014 at 10:23pm |
Have a got a Proline 3000 here which we use to power 4 ES18's loaded with PD186's. Now i have read that at full whack this amp has been bench tested to do 2k a side a 4ohm, so 1k a driver MAX.
Now the problem im having is that the drivers in our kicks get too hot for my liking well before the clip light comes on? After the amp last came out of repair the amp repair man said there was a small amount of DC on the outputs but it wasnt enough to worry about. Maybe it is worth worrying about, since the drivers are getting hot and we popped one of them a while back from over excursion even though we never went near the clip light.... . Or am i being overly cautious about the temp of our magnet? But that still doesnt explain the over excursion as i have limiters set so the amp cant clip anyway! When i say hot i dont mean to hot to touch, but defiantly hotter than 'warm' if that makes sense haha Can anyone relate the too and put it down to an amp fault or do i just need to man up and push it harder? Cheers Tom Edited by tcourtneyvincent - 26 November 2014 at 10:27pm |
cravings
Old Croc Joined: 30 January 2007 Location: Ireland Status: Online Points: 7442 |
i've got no experience with the amp.. but where is your high pass? that could explain over excursion before amp clipping..
and out of curiosity.. how do you know your drivers are hot? are the cabs getting hot? |
odc04r
Few things here you might be confusing.
If drivers are getting hot it is due to the average sustained power. With kick bass you are not getting as much physical excursion as lower frequencies (depending on music played of course but this is likely as a general rule). If the drivers are better cooled by larger excursion (driving more air through the voice coil) then you can see why they might get hot as you have the worst of a situation. Being hot is not necessarily a problem, but you will hit diminishing returns as your coils warm up due to power compression (the coils get more resistive). If they are too hot to touch without burning skin you may want to back off a little, but they are probably ok. Just let them cool down before you start moving them. Just because your amplifiers are not clipping, does not mean you can't pop a driver due to physical excursion. That depends totally on the driver, the enclosure, the music you play, and the voltage of the signal being applied to the driver. |
michel29
Registered User Joined: 04 November 2014 Location: france brittany Status: Offline Points: 55 |
one PD186 was dead ?
a amount of DC current in this speaker 5 volts ? more ? only when amplifier is hot ? |
michel29
speaker burned ?
or break ? |
Andy Kos
My life would be sooo much simpler if everyone understood this... |
tcourtneyvincent
We run them 75hz - 180hz so no chance of over excursion there. The cabs are BPH's with the driver mounted in reverse so you can touch the magnet in the horn path.
tcourtneyvincent
Yep one pd186 just stopped working mid gig. Couldnt tell you the any more about the DC as i have no idea, the amp man just said there was a small amount not worth looking into
Andy Kos
Its quite normal for drivers to get 'hot' to the touch. A modern driver, with fibreglass coil former and high temperature enamel on the copper wire should be able to cope with atleast 150 degrees celsius, probably more. A lot of that heat will get transferred to the magnet and chassis, so easily reach a temperature that you shouldnt be touching with bare skin.
bitSmasher
Old Croc Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2295 |
Just because an amp has measured at x Watts continuous, doesn't stop it putting out much more than that in a spike |
tcourtneyvincent
These are Paulies words from the recone he did to the PD186 'lead wire failure at the joint inside the coil, it looks as if it's had serious jolt of power to burn the driver at this point. The middle of the coil itself is fairly dark too meaning it's been exposed to a an element of DC at some point.' Now we got these drive second hand so i dont know if we cause the darkness or the people we got them off....
Edited by tcourtneyvincent - 26 November 2014 at 10:55pm |
Andy Kos
Slight blackening of enamel can be cumulative over year and years of use. There is no way to detect this when you buy a second hand speaker, it just means the driver has been pushed hard on a regular basis, but not quite hard enough to kill it. All it needs is something to finish the job and it will die..
