Peshkov Sub - Scoop / Tapped / ARLS??? |
Post Reply | Page <1 2345> |
jethrocker
Old Croc Joined: 07 June 2006 Location: Chiapas, Mexico Status: Offline Points: 1942 |
@Ibex.. as you say most TH designs don't use a chamber, though as mentioned by Johan they will generally then need to have a longer horn to achieve the low end response. Cabs sizes for either approach will probably end up similar as the extra horn or the chamber will take up a similar amount of space.
@Johan.. you mention that an 18" tends to play flatter in a given design than a 15".. what in particular about the specs do you think is causing this result? Is it ratio of SD to driver BL or FS, or something along those lines? |
mobiele eenheid
Old Croc Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
From a constructional perspective, including a small chamber is easier to design/build (in designs where the magnet facing the outside would cause problems, i.e. think the HOG and Microscoop's inability to have grills in such way). In the initial/ original tapped horn design a chamber is small by means of the way it's constructed. Tom Danley advised against having a significant chamber in such designs.
@HeaveyJeth: Up till now I've been looking at it as a matter of larger Sd, increasing SPL between the 2 "tapped resonance peaks", but I probably should probe it further then that.
Regards Johan
Ibex
Young Croc Joined: 27 May 2009 Status: Offline Points: 1013 |
Okay guys, so it's on me, what kind of enclosure i would prefer... maybe i will build both (tapped & microscoop) and then make a decision.
Before i will resimulate the scoop designs as a tapped one... stay tuned an keep me up-to-date with your results relating to dependence of SPL between the 2 tapped resonance peaks on driver parameter. maybe thats interesting too: http://www.speakerplans.com/forum/th-mini--tapped-horn--by-danley-sound-labs_topic19409_post277611.html#277611 greez |
bomber
New Member Joined: 18 June 2009 Status: Offline Points: 1 |
Hi all!
I have 16 of Peshkov subs
use them 3 years already.
If someone has to questions please write me.
This is very fast hi spl subs.Best for very fast bass lines,like drum n bass bass lines.
This subs was used in different clubs in "Blazin" party of dj Profit in Moscow,concert sweden rap-dancehall artist - MillionStylez in the club Yellow Moscow... and many others
so i can just tell pluses and minuses of this subs in use:
PLUSES:
1.very fast responding bass reproduction,ultimate for very fast music like drum n bass music
2.when use stacks of its - u got extended lower bass,but still fast
3.hi spl for ultimate mini size
4.very useful,easy move and transport,u can drag and move it by 1 person,and very easy with 2 person,easy placeable in small spaces like small rooms,or if you need to move it in limited passes
like ship`s traps and other situations,when you`ll have big problems and many people to load or unload water transport e t c...
5.hi power and durablilty thanks to 12LW1400 power driver
6. very LOW total system latency - bass vs mid vs sat - so singer hear no chorus effect with monitors portals and singer`s voice
7. easy divided to few small sound installations or combined into one big installaition.
8.can be used like low-mid bass section,and extend any sound system if needed
... and sometimes i hear bassists replics - wow it sounding as fast as my bass combo!!! and i hear all notes i playing!!
Also i have 4 of WSX re-designed by Peshkov for PD1850.
sometimes i used 1 peshkov sat+2 WSX pers side and powering up mid bass section with Peshkov`s small subs,converted to lo-mid sections in this case and i have i clear ultra fast bass lines and still very low latency - so i not use special latency for make WSX faster - i just use latency sat-mid-midlow and WSX play like they can))) but extend hearing lows
In some cases i use only Peshkov sat`s with WSX too - he wrote about before
If any questions - please ask me
And big thx fo Maksim Peshkov and Eugeniy Goryachev again again and again
Ibex
Hi Bomber! Very cool what you haver writen! Do you use the WSX Subs stand alone as well? Isn't it better to use 3 small Peshkov subs instead of one WSX, does the WSX (stand alone) have an lower cut-off frequency than 3 of the small subs??? Where are the crossover points, when you use 1 Peshkov top combined with 1 WSX, or what's the lower cut-off frequency of a Peshkov sat? (questions based on following post of mine: http://www.speakerplans.com/forum/forum_posts.asp?TID=27673&PID=276714&title=peshkov-sub--scoop--tapped--arls#276714 ) I think it would be better to make a stack of 4 WSX instead of 2x2, because the WSX is constructed to use it in arrays of 4 and more... Would you be so kind to tell me the outer dimensions of a small peshkov sub? How does one of the small Peshkov subs work when you use it stand alone? (based on this post: http://www.speakerplans.com/forum/forum_posts.asp?TID=27673&PID=275337&title=peshkov-sub--scoop--tapped--arls#275337 ) Do you have any pix of your system to post? greez |
Ibex
Hey folks!
I don't know if somebody is interested, but here is the HOG Scoop downscaled correctly simulated as a tapped horn:
First the comparison between the RLH and the tapped horn simulation:
black = Tapped Horn
grey = RLH
Now the complete hornresponse simulation for 1/3 cabs:
black = 1x
grey = 3x
Quantum Sounds
Registered User Joined: 26 December 2008 Status: Offline Points: 462 |
ibex you appear to have the wrong s/t peramiters for the 12lw400, i have BL=24.5, Re = 5.5, mms 95, Le = 1.72, cms = 1.14e-4 and rms = 4.16, are you using an older version of the driver?
http://lautsprecher-technik.de/pdf/18sound/12LW1400.pdf |
levyte357
The 10,000 Points Club Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
With the "right" drivers, WSX will easily go downto usable 45hz in paris. Think you'll find 186Horn in pairs with right drivers, is also very interesting. Edited by levyte357 - 03 July 2009 at 6:43pm |
Ibex
Hi! I think you have an old one, mine is from 02/03/2009 loaded from www.eighteencound.com... greez |
Ibex
Which driver would work so brilliant in the WSX cabs? I have used the supposed original (according to TDA) driver RCF L18P300... (as I wrote before, some don't take notice that the WSX is a hyperbolic horn and has no exponential flare, expo would go down very low easily) greez |
levyte357
V18-1000 You really do need to search the forum and read up on WSX. A number of members have built the WSX, and used either V18-1000 or Celestion. Edited by levyte357 - 04 July 2009 at 9:19pm |
tv00
Old Croc Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
@ibex: this is interesting, I would like to build some 12" cabs. considering scoop, hog or tapped?
And now we're at it: Where do i find the graph of the correctly simulated 18" hog scoop? I've been searching around here for it, next week I think I might stack hog+1850 horn + altec 816 + ev sh-1810h Edited by tv00 - 23 October 2011 at 10:23pm |
