  New Posts New Posts RSS Feed - Pirlo's hd215 build-thread
Message Reverse Sort Order
Pirlo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pirlo Quote  Post ReplyReply Direct Link To This Post Topic: Pirlo's hd215 build-thread
    Posted: 27 July 2010 at 10:31pm
 I wouldn't worry about painting the inside of the cabs, just paint any surface that is visible.
Shure, but when ya look in the mouth of a hd15 ya can see almost everything. Tongue
Think I will give the "horn" a clean/plain paint with a brush or role and use a spray-gun to raise the warnex on the outer sides. (give it the well known structure).
Hope to get nice crossings, but thats my personal problem - will do my best!
Edited by Pirlo - 27 July 2010 at 10:35pm
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 27 July 2010 at 9:52pm
Looking foward to the pictures, always nice to see new projects coming together!
"bite my shiny metal ass!"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pirlo Quote  Post ReplyReply Direct Link To This Post Posted: 27 July 2010 at 8:58pm
To make it clear; Round all edges and paint the inner sides as "smooth" as possible would be the way to go?!
Thanks again guys, seems that all clear what necessaryto know for me.
Build will start next week, pictures follow.
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 27 July 2010 at 8:04pm
 With regards to rounding edges, as said above do every edge you can and dont forget to round the brace(on the front edge) before you put it in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pirlo Quote  Post ReplyReply Direct Link To This Post Posted: 27 July 2010 at 1:14am
Originally posted by imageoven imageoven wrote:
yes it's common practice to round over the inner edges.
I would recomend rounding over every edge that doesnt need to be square. Its helps prevent splintering, smoothes the way for sound waves to pass and is easy on the hands and eyes.
That's the question; "need some edges in a hd15 to be definitively square"!?
@all: Thanks for ya answers so far. Smile
Edited by Pirlo - 27 July 2010 at 1:15am
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 26 July 2010 at 10:18pm
1 yes, a rough surface would affect air flow and hence sound, an ideal horn surface would be smooth, however whether anyone could tell the difference (blind) between two cabs, one with smooth paint another with rough....
2. If I understand your question, yes it's common practice to round over the inner edges.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pirlo Quote  Post ReplyReply Direct Link To This Post Posted: 26 July 2010 at 11:07am
Okay, I understand - singles then! Angry
thanks Big smile
Over time thinking about it two additional general questions come up:
(One ask in another thread already, but let me do it again)
1.) Will rough cabinet-surfaces have influences on sound!?
("broken" soundwaves, Huygens' principle etc. pp.)
Want to use the the well known warnex-paint and if there is no "problem" with it paint the whole boxes (inside, flare, [...]), otherwise only the outer-ply with it.
2.) Have anyone round the inner-surface edges!?
Looks good in my head, will give it a try if there are no objections to it.
Davey]
Sorry to stress ya again.
Saul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saul Quote  Post ReplyReply Direct Link To This Post Posted: 26 July 2010 at 9:59am
i reckon there's loads of way round that personally.
you could rebate the edge of the curve in or cut curved formers that you screw flat to the side of the box before put the curve in, you then just screw down to the edge of the former.
tbh tho i'd go for option one as it looks way nicer. actually no, i'd go for singles!!!
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 26 July 2010 at 12:25am
if you're going to make doubles, make them as you have them in picture 1, and not picture 2.
reason is, it's impossible to screw both of the curved flare pieces to the center piece.. look at it and imagine building it and you'll see what i mean
well obviously it's possible.. could be done with biscuits, or just glue.. or using battens behind.. but it's simpler the other way.
loudnclear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote loudnclear Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2010 at 10:45pm
+1 singles. easy to lift and move around by 1 person.... Then stack them whatever way suits...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pirlo Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2010 at 8:43pm
The bigger "gaps" between them when build as singles and stacked are disregard!?
That was my intention to build it as 215, okay- the look as well Big smile - but when everybody said it's unimportant than singles would be the way I think.
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2010 at 12:44pm
 I would also suggest building them as singles, I wished I had built my HD215's as singles the first time I had to move them up a flight of stairs on my ownOuch.
Forum Software by Web Wiz Forums® version 10.10
This page was generated in 0.609 seconds.
