Plans available here |
Post Reply | Page 123 5> |
Lasse Lukkari
Young Croc Joined: 09 March 2004 Location: Finland Status: Offline Points: 615 |
Posted: 24 March 2006 at 7:28am |
Mark James
omg! vivo, u r a legend! |
Contour
Young Croc Joined: 03 March 2004 Status: Offline Points: 620 |
Hello, Nice to see this section over here! I am reading the speakerplans.com forum frequently so I will try to answer the questions whenever possible. But I saw Vivo moved a lot of topics into this section so there already is a lot of information. I think it is wise for everyone who wants to build a Punisher or X-tro that they first read a number of these topics. Both the Punisher and X-tro are quite complex too build. If you have never build a cabinet before I would advise to try something more easy first. The thing with horns is, they need to be strong and airtight for best performance. The X-tro also needs a lot of amps. In fact this cabinet is something like a pornhorn top and some sort of HD-15 into one cabinet. The original X-tro uses B&C 1" + 8" and 2x15" 18Sound. But of course different drivers are possible (But I have not seen many suited 8" drivers) Best regards, Walt |
IAIN RENDLE
Registered User Joined: 23 May 2005 Location: United Kingdom Status: Offline Points: 836 |
http://www.vortexsound.co.uk/P-II.zip some useful stuff created by CARLOS |
-=vortex sound systems=-
www.vortexsound.co.uk |
Mark James
what format are those files in? i cant seem to open them!
IAIN RENDLE
you need Auto CAD 2005 to open them ...... its a bit expensive to buy!!!! so thats why they made bit torrent
Jay Lawless
Old Croc Joined: 22 August 2005 Location: United States Status: Offline Points: 1702 |
Good'ol bit torrent, slow, but none-traceable
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist |
IAIN RENDLE
i find it suprisingly fast.... but it is dependant on what you want.... i have had upto speeds of 240kb/s down stream.... and also had to wait a week for acid pro 5.0
tb_mike
Old Croc Joined: 01 October 2004 Location: New Zealand Status: Offline Points: 2744 |
And ive spend 90days downloading a <500mb file :P |
moray james
Registered User Joined: 07 September 2005 Location: Canada Status: Offline Points: 141 |
Looking at the Punisher plans I see that the driver is 100% loaded into the horns throat. Perhaps I have been looking at older designs but most horns that I have seen have the driver slot loaded into the throat. Can someone tell me why the punisher has no slot? I had been under the impression that slot loading was necessary. Thanks. Moray James.
moray james
Nigey-C
Registered User Joined: 06 February 2006 Location: Grimsby... FISH Status: Offline Points: 1342 |
do you mean that the whole of the driver fires into the horn??? unlike say on a WSX where the driver fires through a small hole into the horn??
mobiele eenheid
Old Croc Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
Half of the air volume in front of the woofer is pressed towards the dead end of the horn, effectively acting as compression chamber, while the other half will follow the horn path, effectively starting at the throat. Some air in front of the driver might be doing both.
This theory might not be spot on in practice but has proven itself, in many designs and over time to be acceptable. Still other theories are acceptable too, as in the end they're just a over-simplification/approximation of reality, with all of it's flaws.
-edit- As a side note, many theories in modern science are accepted as not beïng 100% correct, just acceptable.
Wkr Johan
Edited by mobiele eenheid - 17 November 2006 at 5:16am |
