  New Posts New Posts RSS Feed - PLANS FOR JBL 2241H OR PEAVEY LOWRIDER 18
trentp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trentp Quote  Post ReplyReply Direct Link To This Post Topic: PLANS FOR JBL 2241H OR PEAVEY LOWRIDER 18
    Posted: 04 October 2014 at 9:36pm
hi, does anyone have a single reflex plan for either of these drivers? i need to build one by 10/09/14.
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 05 October 2014 at 3:32pm
Good luck with that, 10th September was nearly a month ago Wink
I think Peavey do recommended box sizes & tunings for their drivers, not sure if they're on the driver datasheet or a separate doc, you could search their website for that I'm sure.
Failing that, WinISD would allow you to model each and come up with a suitable box quite easily.
Post Options Post Options   Thanks (0) Thanks(0)   Quote trentp Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2014 at 1:18am
Oct 9th
sn95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sn95 Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2014 at 4:17pm
Peavey,s =5 to 9cuft
vectrasoundz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vectrasoundz Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2014 at 11:17am
hey, do you still need a plan?
smithshorn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smithshorn Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2014 at 4:15pm
JBL 2241/2242. 10 cu ft cabinet tuned to 40hz, from the JBL web site. Or Google jbl enclosure guide.
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2014 at 9:19pm
10 cu ft? Over 280 litres? A nice compact cab there then!Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2014 at 1:19pm
They probably meant that for things like Cinema where portability isn't an issue. (Probably pre Dolby/THX etc - wouldn't be deep enough for modern cinema FX mind you.)
It actually works OK for the 2241, if running into Xmax at just under 400W is OK for the intended application:
Cheers,
David.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smithshorn Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2014 at 1:49pm
Used in the Keele w-bin when the K151 was no longer available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote trentp Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2014 at 1:43am
i sure do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote trentp Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2014 at 1:44am
yes i do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vectrasoundz Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2014 at 10:38am
PM'd
