Plans of X-Sub by Electrovoice |
Post Reply | Page 12> |
chavamax
Registered User Joined: 07 January 2008 Location: Mexico Status: Offline Points: 13 |
Posted: 16 July 2009 at 5:06pm |
Hi
Someone has a picture of the box inside. I have one plan, but i don´t understand two parts. the design is thank's |
S.A.L.S.A
Registered User Joined: 15 June 2008 Location: Aruba DC Status: Offline Points: 21 |
Hola Chavamax,
Soy david de Aruba, te recuerdo?
como estas?
Tiene mi e-mail?
Hablamos!
Chau
Dave
Get to the Point with L'acoustics Dv-Dosc!
chavamax
Saludos, Claro, pasamelo de nuevo por favor para contactarnos
Saludos desde México. |
CLsystems
Old Croc Joined: 16 March 2007 Location: Birmingham Status: Offline Points: 2736 |
what dont you understand?
its just a reflex box, with the drivers been in the own chambers. |
chavamax
Hi,
Internal divisions, as are located and to distance between them. Edited by chavamax - 23 July 2009 at 2:15pm |
_djk_
"Internal divisions, as are located and to distance between them."
You're pulling my leg?
It's a box with a divider down the middle, the rest is bracing.
Unless using a driver with the exact same parameters the design is rather useless anyway.
djk
chavamax
Yes, take one middle division, its ok
But, the arms ( Reinforcements ) What position are ? The A,B,C parts, What are the measures Thanks Edited by chavamax - 24 July 2009 at 1:42pm |
djeddie
As the parts are only really used for bracing, the actual dimensions aren't going to be that important. Just make sure you have enough room behind the baffle to fit the driver in.
Hopefully that should help. |
Shelfstacker
Registered User Joined: 11 July 2008 Location: Midlands Status: Offline Points: 495 |
Isn't it taking the piss to rip off a current product?
If you are at the circus and being attacked by clowns - go for the juggler
ceharden
I don't think EV need to worry, given he's having trouble copying them, even with the plans!
It's a bog standard 2x18" reflex box, just about every PA manufacturer has done one. Calculate volume, use simulator to calculate port dimensions for chosen tuning freq. Simples, even son of Mongoose could do it! |
chavamax
ok, thank's, I will build the cabinet soon, and upload the pictures.
I see you soon. |
Vaso_Bobinata
Registered User Joined: 21 May 2017 Location: Sofia BUL Status: Offline Points: 37 |
Hi mate, i had 4 damaged ev 18 inch drivers. I would need the shematics of the xsub so i can build the boxes in my garage. I alredy purshased the recone kits from thoman.de.
Can you help. Thanks |
