pm 80 |
Post Reply | Page 123> |
Quantum Sounds
Registered User Joined: 26 December 2008 Status: Offline Points: 462 |
Posted: 18 March 2010 at 1:47pm |
i have had a pm 80 for a while that originaly didn't work but i have managed to fix (well mostly need soem pot cleaner and poss a couple of new pots and faders) tbh i haven't had to do much, just clean a bit and resolder a wire here remove a randome bit of metal that was shortign the power supplie there
any way i have now also got a crossfader for it but it is confusing me alot, it has a scerial port on the back as well as a 1/4 inch jack in a 1/4 inch jack out and a 3pin plug like a small xlr this is not like the one in the pic as it has little number selectors either side of the crosfader my quenstion is... how do i plug it in? the 3 pin plug goes in the power suply on the aux power socet but where do the jacks go?? and what is the serial port for ??? it was mentioned on anouther thread that the crosover is conected with jacks to that
but the cross fader has no jacks, will this have somthing to do with the remote out? any help will be much appreciated thanks ps i willtry to put up pics later but i don't have a camera atm |
burningbush
Old Croc Joined: 25 May 2009 Location: Pictland Status: Offline Points: 5897 |
pm JBL-man on here, he knows these units. In fact AFAIK thats his in the picture. Lovely isn't it?
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4938 |
Just ring Formula Sound, they're still going
Just a thought, have you got the right versions of crossfader and chassis? The PM80 was re-issued recently and is internally different to the original ancient unit. Edited by kedwardsleisure - 19 March 2010 at 7:23pm |
North Staffordshire |
rich21
Young Croc Joined: 24 September 2007 Location: south london Status: Offline Points: 632 |
the serial port should have a break out to ? number of 3.5mm jacks
they plug in to each input module BUT each in put mod will need to be fitted with a VCA and a 3.5mm socket Rich PS i had one once !!! |
burningbush
Bringing this thread back from zombie land, does anyone have a schematic or circuit diagram for the main mixer section? I plug mine in and it is very very quiet, put it on pfl and it hard clips, but I got it off ebay for £30, so could well be only half of it in there.
jbl_man
Moderator Group Joined: 12 January 2005 Location: London. Status: Offline Points: 11154 |
Gavin,make sure the main contact strip bus that connects all the modules together is clean,also clean the pfl function switches on all the modules.
burningbush
'kay.
mostyn
Registered User Joined: 24 March 2012 Location: cannock Status: Offline Points: 186 |
jbl man,the line modules on mine seem very quiet in comparison to the phonos;also i noticed something,the logo on the psu monitor module-like mine-lacks the fs logo though i gave ian at fs the serial number he reckons mine was made about 93? |
jbl_man
I believe mine (the one in the photo above) was made around 1984,DJ Simon Harris bought it new from Formula sound,and used it on his early mixes,even Pete Tong and Froggy used this actual mixer too...Simon originally had it in his first studio.
mostyn
any recommendations on cleaning the rs connectors on the ribbon please?
Pinyorouk
Young Croc Joined: 31 January 2011 Status: Offline Points: 550 |
JBL, I have always wanted to ask this question. Is Simon Harris on this forum the same Simon Harris who produced a track called: "Bass, How Low Do You Go?"? |
jbl_man
The very same!
Simon also had a number 1 hit with The Real Thing- You to me are everything. |
