  New Posts New Posts RSS Feed - Porn Addick
Porn Addick
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2005 at 8:48pm
I bet my ass those breasts cast a huge shadow...
tendril View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tendril Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2006 at 6:29am
Would there be any reason why this design couldn't be altered, so that there is an access panel at the rear for the mid driver, and then having the empty space on the horn side between the horn and the cabinet wall filled with expanding foam, to give support and improve sound quality?
Tendril
A mistake is a mistake only if one learns nothing from it.
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2006 at 2:10pm
because then the poor lass would die!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2006 at 8:11am
also that plan says for 2x12" porn ahorn and 1x1.5" and only seems to show 1x12" or am i just looking at it wrong?
edit. ive just realised it sys for 2x12" [ie If you are doing a 2x12" version] then make it said 12??cm height as opposed to the height on the drawings.
Edited by coner - 14 February 2006 at 8:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote tendril Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2006 at 1:26pm
why? If I keep the back volume the same then an access panel won't effect the back volume. And the foam was meant to go as in red:
Obviously the driver would need to be mounted to the horn differently, but this was just a 'what if' scenario.
Tendril
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2006 at 10:10pm
i was reffering to the girl in the avatar whom if an acces panel was added to her rear and her mid and then filled her with expanding foam..... oh dear that sounds rather rude actualy making an acces panel on her rear and filling with expanding foam.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote tendril Quote  Post ReplyReply Direct Link To This Post Posted: 18 April 2006 at 1:46pm
aha!
Tendril
fr3ttch3n View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fr3ttch3n Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2007 at 10:46am
What is the maximum SPL of the Porn horn and respectively what is the f low at full load(+- 3db)? Are there any Plots online?
greez from austria
alex
bitzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2008 at 3:19pm
how do you build the phase plug? Is there any plot?
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2008 at 11:43am
You don't build it, you buy it. As well as the flare.
All parts and plots are on proaudioparts.co.uk
after11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote after11 Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2008 at 11:38am
OK just outa curiosity what does it cost in materials to build a pair of porn horns ? any one?
WWW.AFTER11SV.CO.UK
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2008 at 8:22am
What do you mean for build?
The porn horn is selled on proaudioparts but....if you mean building the horn uhmmmmm I think you need some foam, a steel wire to model it or antything you need for modelling, poliuretanic  resin to get it solid. Another method could be using only wood like this master do http://www.volvotreter.de/roundhorns.htm, I think this is the only method to build a round phase plug.
web department
