Port depth question |
Pbg
New Member Joined: 13 January 2015 Location: Wv USA Status: Offline Points: 8 |
Posted: 21 June 2016 at 1:53pm |
I'm building some boxes for a space constrained use, so it's not as big as I'd prefer. As constructed, they tune slightly higher than intended (mid 30's), but I'm curious if there is any inherent issue with having a rather deep rectangular shelf port. Box is a bit over 200L, port is about 425 cm and 45cm deep. Thoughts appreciated.
Crashpc
Registered User Joined: 26 February 2008 Location: Czech Republic Status: Offline Points: 465 |
There is no issue with port 45cm deep once it is built properly and cross-section area is good for the application.
