Poweraudio Romania - MAP of speaker plans |
Post Reply | Page 123 7> |
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2581 |
Thanks(8)
Posted: 05 February 2011 at 10:19am |
Greetings from PowerAudio Forum Romania
www.forum.poweraudio.ro We are delighted to present you with this large map of speaker plans made complete in 3D and with detailed cutlist, by our users. The plans are free to use for non comercial purposes. some of the plans originate from Rog mogale's designs. We wish to thank him for those. Enjoy, and remember, the best things in life are FREE! Bandpass Subwoofer Designs: BP6-E12-250N BP4-E12-100S BP6-Budget BP6-X1 184SUB BP6-K-bin BP6-C-sub Planar Wave Horn Designs Goliath LSW218 LSW118 PWH lung-port interior PWH-18SW1P Planar-SD21EL PWH scurt-port interior F17-versiunea 1 F17-versiunea 2 FX20 Bassreflex Subwoofer Designs Subwoofer dual C18-600LF Infrabass E18ELF Subwoofer 18SW2P4 Subwoofer C18-650EL Subwoofer FL18ELF,C18ELF Subwoofer E18ELF Subwoofer 18inch-supercompact Subwoofer dual HP15S Subwoofer 15WS600 Subwoofer HP15W Subwoofer C15-400B Subwoofer compact E15LF Horn loaded Bass and subbass designs HD15 CB18-Cyclops Horn hybrid-dual 18 inch Punisher Mach Ballister Ultrahog Fullrange mid top designs Dual 12 inch+PH2723-Vector Satelit/FR E12-100S+PHT411 Satelit 12inch+PH2723 Satelit/FR 12inch+PH220 Satelit/FR 12inch+PH220 Satelit SN10MB+HM17-25 FR hi-fi cu PCT300+PA800K 15" bassreflex Fulrange designs Fullrange 15inch+1inch Fullrange 15inch+PH642/942/64/94 Fullrange BM15CXHB Satelit/FR 15inch+PH220 Satelit wn15R+wnD72+PH2723 Fullrange 15inch+PH2723 Fullrange 15PW6+HM2525+D220Ti Fullrange 15inch+PH3220 Satelit/FR Wn15R+PH2723 Fullrange C15-300MB+BMD440+PH3713 Fullrange HP15W+PHT408 Fullrange 15PW4+PHT408 Fullrange 3 cai Horn loaded Mid Top designs MT122 MT121 FX12 Horn hybrid coaxial-15CO1P X-tro Complete deployable system designs Expander Katiusha Edited by Mircea Bartic - 05 February 2011 at 10:22am |
VentureSound
Young Croc Joined: 18 October 2009 Location: London N20 Status: Offline Points: 950 |
Amazing! Great effort!
djyves
Young Croc Joined: 06 April 2009 Location: the Netherlands Status: Offline Points: 564 |
Great
The Builder
Old Croc Joined: 03 January 2010 Status: Offline Points: 3107 |
Wow.
It just is.
Foca_Dacian
Registered User Joined: 05 February 2011 Location: Romania,Cluj Status: Offline Points: 118 |
Hello guys,it's my first post here. I want to add something regarding the bassreflex cabinets. If you want to put fonotransparent foam on the grills make sure to leave clearance for that to.The dimensions of the cabinets are given without the thickness of the foam. I'll post some more designs soon and the Map will be updated. Have fun building Edited by Foca_Dacian - 05 February 2011 at 11:44am |
AM55
Old Croc Joined: 16 August 2007 Location: Matlock Status: Offline Points: 1728 |
Very nice, well done! I like the 2 systems, very compact. Do you have any suggestions on how to secure the access panel for easy removal?
Edit/ Is there a off the self or DIYable xover for the mid/highs? Edited by AM55 - 05 February 2011 at 1:11pm |
Mircea Bartic
the acces panel can be secured using euroscrews
there is a crossover available but only in Romania http://www.discopro.ro/?p=productsMore&iProduct=118&sName=filtru-pasiv-dna-xpro-2 |
hmaudio
Old Croc Joined: 03 April 2009 Location: Nottingham Status: Offline Points: 3844 |
you legend!!
This account is used by 2 people. |
AM55
As in these? Not really the easy access I was hoping for as you need at least a screw driver to get into it. I was thinking maybe countersunk shouldered thumbscrews |
Flano
Registered User Joined: 29 April 2006 Location: Ireland Status: Offline Points: 216 |
Great job nexus!
Mircea Bartic
we used an imbus key it took about 3-4 minutes to unscrew , pull the satelites out , and screw back the access door. |
MarjanM
Old Croc Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7809 |
Mircea they call it allen screw.
