powered mixer set up |
stevew
Joined: 27 June 2011 Location: milton keynes Status: Offline Points: 56 |
Topic: powered mixer set upPosted: 20 February 2012 at 3:34pm |
Looking for the basic starting position for all faders and knobs on a dynacord powermate prior to singing.thanks in advance
OllieMan
Joined: 02 March 2006 Location: Midlands, UK. Status: Offline Points: 884 |
Posted: 20 February 2012 at 4:58pm |
http://www.saeuk.com/subjects/index_audio2.html?gclid=CPDjgIiDra4CFUcTfAodmB80RQ
No, but in all seriousness there are no basic starting positions. It all depends on what mics you're using, how loud the sourse vocal or intrument is or what speakers you're using, what room you're in..... |
DOJO MEDIA.
PA HIRE/ RECORDING STUDIOS/ BACKLINE HIRE. |
TheOrangeDot
Joined: 27 February 2012 Location: Liverpool Status: Offline Points: 35 |
Posted: 28 February 2012 at 9:40pm |
Agreed OllieMan, too many variables to give such broad stroke advise. My advise would be to find an engineer in your area and try to learn from them, shouldn't take too long to learn the basics.
Tom Edwards
Earplug
Joined: 03 January 2012 Location: Europe Status: Offline Points: 718 |
Posted: 29 February 2012 at 12:16pm |
For a start, I´d turn down the all the gains and faders and put the eq´s at their midpoint. From there, I think you´re on your own!
Smiter
Joined: 21 August 2010 Location: UK Status: Offline Points: 1169 |
Posted: 29 February 2012 at 12:57pm |
Trying to put a simple starting point... Your mic channel gain at 25db. Or halfway up. EQ flat, but take a little bass off. Start with your master and channel faders at 0, bring the master up half way then the channel fader up slowly. Once the channel fader is at 0, use the master fader to go up to the desired level! I hope this helps mate.
Tweet
