Stasys 3 MK2 VS Porn Horn V2 vs Limmer 042
Category: Plans
Forum Name: Po rn Horns
Forum Description: Discussion / Questions about the Po rn Horns
URL: https://forum.speakerplans.com/forum_posts.asp?TID=19787
Printed Date: 16 April 2024 at 6:18am
Topic: Stasys 3 MK2 VS Porn Horn V2 vs Limmer 042
Posted By: Father-Francis
Subject: Stasys 3 MK2 VS Porn Horn V2 vs Limmer 042
Date Posted: 20 September 2008 at 12:17am
Dom you built the Limmer042 with the porn 12", haven´t you .
how´s the sound comp´´ed to the porn or the stasys 3 series 2 what do
think if one built the 12" alone an the limmer on it´s own?
Posted By: bitzo
Date Posted: 20 September 2008 at 8:21pm
could I suggest antoher contender? Omintop 15 or 12 as you like
Posted By: norty303
Date Posted: 22 September 2008 at 9:04pm
Shouldn't make any difference to the sound if you built the 12" and 042 in separate boxes.
My laser stuff: http://www.facebook.com/SubsonicSystems" rel="nofollow - Frikkin Lasers
Posted By: sKs01
Date Posted: 22 September 2008 at 9:41pm
or perhaps modified mt121 (what ill be building pase plugged 6.5 and 12" section both or just the 6" plugged not sure yet still in very early stages working with what studio 45's got as a basis) thinking perhaps 1" or a convex melded pezio array (which is what ill be testing soonish as its got a minimal outlay to test it)
Date Posted: 28 September 2008 at 1:17pm
started cutting some form out to mold the horns an plugs
Posted By: Dom
Date Posted: 28 September 2008 at 6:24pm
To be honest the 12" alone isn't doing anything too special as it's only playing 140hz-600hz.  You could probably get very similar results with an MT121.
The limmer 042 does a really good job of 600hz though...  Before I went down the limmer route I did try the mk1 porn horn top and an unreleased porn horn 6.5".  I preferred the limmer to be honest...
As for comparison with a stasys 3 mk 2 - they are a completely different beast.  The limmer has a much wider dispersion and is really designed for one box per side.  The stasys 3's are very good sounding boxes...
Date Posted: 29 September 2008 at 7:22pm
hey Dom how did your boxes sound when didn´t you once build some porn-limmer mix do think they come close to the big boys F1´s or the stasys
Posted By: Dom
Date Posted: 01 October 2008 at 1:20pm
The limmer porn boxes sound really good.
Not sure what you mean by come close to the big boys.  They do a different job.  They sound good but are really only suitable for small rooms due to the wide dispersion.
Posted By: mykey
Date Posted: 01 October 2008 at 1:32pm
a 15 and my 2 x 8''
2 x 1'' in the center of the 2 x 8''
......just all them hanging there like giant bananas.
Posted By: Deadbeat
Date Posted: 01 October 2008 at 1:42pm
Can't see anything Mykey...
Away on extended leave.
Posted By: mykey
Date Posted: 01 October 2008 at 2:16pm
sorry about the center drawing but you get the picture
http://imageshack.us">
http://g.imageshack.us/img66/m28dgs6.jpg/1/">
Posted By: Deadbeat
Date Posted: 01 October 2008 at 2:28pm
Okay. Didn't realize. Looks cool. Have you thought of intergating that into a single piece (seperating the 8s and putting 2 splayed 1s in between one one big fibreglass baffle)?
Posted By: mykey
Date Posted: 01 October 2008 at 2:51pm
like the res 2's you mean
Posted By: Deadbeat
Date Posted: 01 October 2008 at 2:59pm
Nah, I mean like an MT122 with 8s instead of 12s, a double Mykey 1" in the centre, all in one fibreglass baffle.
Date Posted: 01 October 2008 at 4:44pm
Am looking and liking got a drawing on the table right now with a 2x10" +1.4horn but am looking for a 2 way - 3 way Active mode switch kind of thing . so depending on what one´s playing I could add more lower mids to run hogs some good (kickbin) and this cab that on it´s own can just be put on the Hogs , or DubsubBig%20smile
Posted By: Deadbeat
Date Posted: 01 October 2008 at 8:21pm
I'm not sure what you mean - could you cite a commercial example?
Date Posted: 01 October 2008 at 8:57pm
http://www.kv2audio.com/product.asp?ProdID=VHD2.0&ProdSeries=VHD
The VHD 2.0 ,
ttp://www.turbosound.com/showroom/ta880h/index.html
Stasys 3 MK2
Posted By: Deadbeat
Date Posted: 01 October 2008 at 9:12pm
You want to be able to use it on it's own with smaller shows and use it with kick bins in larger shows? The kick bins are going to have be exactly the same as the ones in the cabs, unfortunately.
Stasys 3 ain't the same class as the others - it's designed to have a kick bin under it.
Have a look at Martin H3+ actually.
I think you should pick one way or another.
Date Posted: 01 October 2008 at 10:00pm
I´ve been working on this but will have to lose the tweets change one of the 10" to a 12" and go for a 6.5 or a 8" and 1.4 horn
Posted By: Deadbeat
Date Posted: 01 October 2008 at 10:17pm
Eh? All I see is a guy in boxers.
EDIT:
Not any more! Have you hornresped this! I'll be happy to help.
Posted By: dj-panoramix
Date Posted: 21 October 2008 at 11:22am
is it possible to tell me wich speaker have you used in the limmer 042 ,and wich 12" horn have yu used to make a limmer/pornhorn combo ,because i will be really interested to make 2 or 4  for me.
i see that some have used the 12 of the porn horn v2 with the limmer 042 ,is there any problem of dispersion ?
where can i see picture of this limmer/horn combo ?
Posted By: norty303
Date Posted: 21 October 2008 at 1:55pm
I would think that he used the Pornhorn 12" section to make his limmer/porhorn combo - otherwise I suspect he might've called it something else.
I think he mentioned (here or in another thread) that he bought the full kit of parts for the Limmer which comes with a Ciare 6.13 (iirc)
Posted By: Timebomb
Date Posted: 21 October 2008 at 4:36pm
limmer horn and ciare 6" package on sale at speakerstore.nl i think
Date Posted: 21 October 2008 at 5:33pm
ok but he used the 12" porn horn from v1 or v2 ?
i can't find any other thread than this one who speak from this combo, have any link ?
does anyone have try other 6.5 speaker than the ciare one  ?
Posted By: norty303
Date Posted: 21 October 2008 at 11:04pm
Ok, I think you're talking about Dom's combo in which case it is a V1 Porn horn.
To cut this short, if you want to know anything worthwhile about the Porn Horn go to search and use:
Username = Rog Mogale
Search string = Porn
Forums = All
Time period = All posts ever
If you want to know about Dom's then do:
Username = Dom
Search string = Limmer
Forums = All
If you want anything about Limmer try searching for 'Limmer' on all forums.
This is how i manage to put up useful links in other threads about Porn Horns, perhaps it might work for you too.
