Portable sound system!
Category: Plans
Forum Name: Other plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=25442
Printed Date: 23 April 2024 at 11:39am Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Portable sound system!
Posted By: subbass
Subject: Portable sound system!
Date Posted: 30 March 2009 at 4:01pm
Hi all, glad to join the forum :-).
I know that this post / topic is a little unorthodox for this forum, but I guess I'll just see how you guys handle it......
I basically am going to create a small soundsystem, or 'boombox' for the summer. I am currently doing my A2 finals, and would like to have a system ready for the end of them - ie the summer! I am thinking a sub 10kg box with plenty of power that can run well for an afternoon, and cost under £200 (!)
So, I thought car stereo system (amp + equaliser + linein + radio in one) with a 12v deep cycle battery, and 6" car speakers. Here are what I have found so far:
VIBE SEK60 speakers http://www.bassjunkies.com/audio/vibe-sek60-v3 - http://www.bassjunkies.com/audio/vibe-sek60-v3
Pioneer DEH 112e head unit http://www.bassjunkies.com/audio/pioneer-deh-112e - http://www.bassjunkies.com/audio/pioneer-deh-112e
YUASA NPC17-12 battery http://www.thebatteryshop.co.uk/yuasa-npc17-12-308-p.asp - http://www.thebatteryshop.co.uk/yuasa-npc17-12-308-p.asp
The SEK60s handle 115w RMS, so I would bridge the rear and front from the amp (4x55wrms per channel) to deliver more power to them. The battery while quite heavy holds alot of juice and can deliver it over a long time :-)
These would all be in a plywood box covered over with some speaker felt for a quality feel / construction.
Thoughts? Is there a better way of doing it? I know that car head units arent very efficient.....
Thanks all
Posted By: MikeHunt79
Date Posted: 30 March 2009 at 4:24pm
I cheated and used bits I had lying around. I ripped apart laptop battery packs for their Li-ion cells, and used a Tripath based amp module which is ~90%efficient as it's class D.
I gaffer taped some old Aiwa midi hifi speakers together and it works a treat. Plenty of volume and the battery lasts around 10 hours. I have 2 batteries so I can charge 1 while using the other.
I would not use a headunit and car amp, as you say they use a fair amount of power.... Get something like a Sonic Impact T-amp and try it up to some car speakers, you'll be surprised how much sound it kicks out...
------------- I'm English, and as such I crave disappointment. I actively seek it out.
Posted By: subbass
Date Posted: 30 March 2009 at 4:42pm
Sonic amp has only 15wrms x2? I know going by watts isnt a great idea - but 220 vs 30 is quite a difference :\. Have just read some reviews though, none of them can recommend them enough though! Although, I can't find anywhere that will sell them below £60, when they used to be £20...I meant just a head unit by the way - no external amp.
Posted By: Deadbeat
Date Posted: 30 March 2009 at 5:53pm
'I know that this post / topic is a little unorthodox for this forum, but I guess I'll just see how you guys handle it, lol.'
If you use the search function, there's been a few of these style things, you can see how people have solved the problem. Davey T's 'minirig' is probably the best looking one imo, and there are others on wheels etc. If you have a 20W amp, try looking for sensitive speakers
------------- Away on extended leave.
Posted By: subbass
Date Posted: 30 March 2009 at 6:46pm
dont know if its just me, but I can't seem to find davey ts page on his minirig .. after much searching..
Can you give me a link to the topic? Thanks alot for the help
Date Posted: 31 March 2009 at 1:22pm
subbass wrote:
Sonic amp has only 15wrms x2? I know going by watts isnt a great idea - but 220 vs 30 is quite a difference :\. Have just read some reviews though, none of them can recommend them enough though! Although, I can't find anywhere that will sell them below £60, when they used to be £20...I meant just a head unit by the way - no external amp. |
Ahh, so you're using the amp in the headunit? I think you'll find the 4x50W rating is BS...it's more like 10W per chan.
The sonic impact T-amp will give more power per channel then the headunit, they both run from 12v and the t-amp is higher efficiency...
Posted By: subbass
Date Posted: 31 March 2009 at 6:54pm
Oh, okay - I was under the impression that the quoted power from the head unit was rms - i should look closer at the packaging next time :P.
Is there a good site you could recommend for buying speaker components? For a good pair of sensitive speakers with tweeters (+ a little crossover) ?
thanks
Posted By: subbass
Date Posted: 31 March 2009 at 7:09pm
** found http://www.bluearan.co.uk/ , what kind of sensitivity should I be looking for? 1w@1m = 96db seems to be the highest I can find, this is about right I take it?
Posted By: davey t
Date Posted: 31 March 2009 at 9:33pm
hey dude, i'm gonna be buildin minrigs when i get back in a couple months so u can place an order. or if you want to do your own:
Simple and cheap would be Eminence beta 8a in 18L enclosure tuned to 70hz with APT80 tweeter. a skytronic 3.5khz crossover would work fine - all of this you can buy from bluearan. You might want to put an L-pad on the tweeter or input filter on the amp to take down the hf.
for something smaller, look for generalosity on ebay - he used to sell really good 4" full range wharfdale drivers which i used in my mini rigs. These sound great in 3L vented boxes.
http://cgi.ebay.co.uk/2-15-watt-4ohm-TA2024-D-class-Audio-Amplifier-Board_W0QQitemZ370167643444QQcmdZViewItemQQptZUK_AudioTVElectronics_HomeAudioHiFi_Amplifiers?hash=item370167643444&_trksid=p3286.c0.m14&_trkparms=72%3A1683|66%3A2|65%3A12|39%3A1|240%3A1318
sure electronics sell the t-amps in bare module form on ebay.
go to www.41hz.com to build your own but it'l probably work out the same price!
plug the head unit into the battery with an amp meter in series and tell us what it pulls when its just on - i bet its a lot. Unless the head unit has a voltage boost circuit (which few do) then it'l put out the same power into 8r as the t-amps as mentioned above.
you can power those t-amp modules off 10xAA rechargables or a nice 5ah 12v would last well.
see you in st andrews park!
------------- Minirig portable soundsystem movement
Date Posted: 31 March 2009 at 10:42pm
davey t: Have you thought about using an active crossover as those Sure amps are stereo and your minirig is mono, you could use 1 ch for bass and the other chan for treble - it would be biamped like those high end studio monitors...
You a Brizzle person too as it says NZ in your location...
Posted By: subbass
Date Posted: 31 March 2009 at 10:53pm
Safe, thanks so much!
The eminence beta 8a - are they the standard beta 8s? Or is there a difference? Thanks for the advice, I would never have thought a 15w amp would have been possible to drive 8"s and tweeters 0.o.
I found 41hz, and was looking at the AMP1 packages - but then it started getting technical with the power supply needed and i began to doubt if it was worth figuring out all the electrics... That ebay link looks brilliant, and so cheap!
I think I'll go with a bigger battery tbh, not to keen on buying AAs, they seem to cost far too much in comparison, and a battery that will run all day is pretty tempting :).
I'm starting to be tempted to build a second module as well, the same amp but running twin subs to put underneath it to reinforce the lowend, but thats probably just me going over the top lol :).
Posted By: darkmatter
Date Posted: 01 April 2009 at 12:57am
I use a beyma 8bx co-axial driver off one of those sure electronics amps, plenty loud enough most of the time and that's only 92db sensitive. Runs for ages off a drill battery.
Next step is to learn to build and power an active crossover, so I can use a class D car amp for bass and go horn loaded for top and mid.
Posted By: rich_gale
Date Posted: 01 April 2009 at 1:13pm
i have been building a rig for my brother. itll be complete by the weekend and i will post up picks of the build. his budget was £200 total.
it consists:
4x 8inch bass/mids
1x 5.5inch mid
1x piezo tweeter
running from a sony 100watt amp (bridged)
batteries: 3x 7ah yuasa = 21ah.
the cabinet is designed so it can be dragged on two wheels in the same way most modern suitcases are designed.
Posted By: subbass
Date Posted: 02 April 2009 at 3:45pm
well, does anyone know if the 2x15w amp gives good sound for x2 8"s andx2 tweeters? Or would two, for the left and right channel, both bridged give far better sound?
Date Posted: 02 April 2009 at 3:57pm
subbass wrote:
well, does anyone know if the 2x15w amp gives good sound for x2 8"s andx2 tweeters? Or would two, for the left and right channel, both bridged give far better sound? |
You can't bridge that amp as it's already bridged.
I use it to power 2 x 6" and 2x 1" tweeters and it sounds great with more then enough volume for me.
Posted By: subbass
Date Posted: 02 April 2009 at 4:34pm
*facepalms*
Well, I guess when I get around to actually making the thing (2 months tops, I think im being a little premature..) Ill try it with one, and if it doesnt have enough kick, then I'll try running it with two ^_^.
After all £18 is pretty cheap- so I havent really got anything to lose, if I dont use the second then ill whack it in somewhere else :).
Date Posted: 02 April 2009 at 4:55pm
Yep, just try out the amp, I'll think you'll be surprised how loud it goes when up to sensitive speakers...
Date Posted: 02 April 2009 at 5:46pm
i recon running one of these £18 amps into a dual vc 8" woofer would work great. like the volt dvc 8inch. then maybe another one of them running a mid on one side and a tweeter on the other. i just got my 12v active crossover in the post. gonna open up a lot of options for me now, and also allow better efficiency.
Date Posted: 03 April 2009 at 1:16pm
one last important point i think is worth making is that i find running an electronic high pass filter saves oodles of battery life. my rig wont go much lower than 60hz, so i threw the highpass on the amp to 60hz. this is pretty damn low setting for a built in high pass on a car amp so i was lucky(most are around 80-120hz). you might want to look at electronic kits or 12volt crossovers where you can highpass the input to your amps.
Date Posted: 03 April 2009 at 2:52pm
rich_gale wrote:
i recon running one of these £18 amps into a dual vc 8" woofer would work great. like the volt dvc 8inch. then maybe another one of them running a mid on one side and a tweeter on the other. i just got my 12v active crossover in the post. gonna open up a lot of options for me now, and also allow better efficiency. |
Good idea, what are you using as a 12v active crossover? I was going to try and make my own but it's pretty complex with rail-splitters and op-amps...
Posted By: SamV
Date Posted: 09 April 2009 at 10:49pm
Excellent advice on the high pass. I have a bunch of Sony (not so) Microamps, two channel 25wrms a channel, and a couple of class h/t 50wrms per channel amps.
Date Posted: 10 April 2009 at 3:54am
have a look on ebay for crossovers in the in car entertinment section. im using a caliber half din unit. its the same width as a head unit, but half the height. nice little box with a preamp, 5 band eq, subwoofer volume etc., only negative is the fixed crossover points which im gonna be modifying to different frequencies if i can work out how. try and find one with a variable crossover. £20 should get you something more than adaquate.
Date Posted: 10 April 2009 at 4:05am
http://cgi.ebay.co.uk/Pro-Soubd-DR67-2-3-4-5-Way-Crossover-Competition_W0QQitemZ140313348963QQcmdZViewItemQQptZUK_Audio_TV_Electronics_In_Car_Entertainment_GPS_Car_Amplifiers_PP?hash=item140313348963&_trksid=p3286.c0.m14&_trkparms=72%3A1689%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318 - http://cgi.ebay.co.uk/Pro-Soubd-DR67-2-3-4-5-Way-Crossover-Competition_W0QQitemZ140313348963QQcmdZViewItemQQptZUK_Audio_TV_Electronics_In_Car_Entertainment_GPS_Car_Amplifiers_PP?hash=item140313348963&_trksid=p3286.c0.m14&_trkparms=72%3A1689%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
these babies are very good value. and most of the models from prosound have crossover freq knobs and multiplier switches meaning hyper flexibility. i once even used one of these for a party because my 230v berry gave up the ghost becaue its multiplier switches started to play up. sound quality wasnt too shabby from a car audio product either..
Posted By: subbass
Date Posted: 12 April 2009 at 5:35pm
They look pretty good, preamp and xover in one :). and its 12v..
So far I'm thinking a Yuasa 17Ah (smallest SLA deep cycle battery I can find, would use smaller ones in parallel if I could...) or 2 17Ah if I can find the cash.. This would then perhaps feed into a 1F cap (will 'loan' it from maplins to see if it works well enough, if not then ill package it up and return it). Then they go to the 12v equaliser and the 2x15w amp (which if it doesnt do the job then ill buy another and run one per channel). each these will then feed into a beta 8 and APT80 (1 of each per chan) via a little passive Xover..
Battery(s) -> Cap(?) -> 12v equaliser -> amp(s) -> passive Xover -> speakers
How does that sound?
Posted By: SamV
Date Posted: 12 April 2009 at 6:59pm
15w into a beta 8? Won't you need more than that to get one moving?
Date Posted: 12 April 2009 at 7:04pm
the 15w amps wont require a capacitor man. you wont be drawing much current:)
Posted By: subbass
Date Posted: 12 April 2009 at 7:50pm
Oops, didnt mean to leave that in - my bad :)
SamV - MikeHunt79 reckoned earlier in this thread that they would be up to it? It is a pretty sensitive after all @ 97db 1w1m
Date Posted: 13 April 2009 at 12:24pm
i just started working on the wheel system for my bigger 12v system (the one in the video with 18" bass)
i have used some pnuematic tyres. the ones that come on sack trucks. i have also ripped apart my budget sack truck and used the handle and mounted it directly onto the cabinet. its getting very heavy so i hope it wont be too hard to move around. i wanted a one box system because previously i have had to transport battery, amplifier, cabinet etc separately. previously the cabinet with the battery mounted within was too heavy for the sack truck i had. now i have removed the weak points the scak truck exhibited i think it will be rigid and resilient. also, with the battery and amps permenantly mounted and wired inside the cabinet i wont have to worry about damage to things like connections. will post picks once thigs come together more coherently
Date Posted: 13 April 2009 at 12:50pm
could be a little winner...
http://cgi.ebay.co.uk/New-Mini-2-Channel-T-Amp-Class-T-Power-Amplifier-Amp_W0QQitemZ380116991159QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item380116991159&_trksid=p3286.c0.m14&_trkparms=72%3A1690%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318 - http://cgi.ebay.co.uk/New-Mini-2-Channel-T-Amp-Class-T-Power-Amplifier-Amp_W0QQitemZ380116991159QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item380116991159&_trksid=p3286.c0.m14&_trkparms=72%3A1690%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
Posted By: subbass
Date Posted: 13 April 2009 at 1:25pm
how about this £11.95 + free postage amp that does 75wrms x2 from 12v? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280332500188QQssPageNameZMERC_VI_RCRX_Pr4_PcY_BID_Stores_IT&refitem=370187076431&itemcount=4&refwidgetloc=active_view_item&usedrule1=CrossSell_LogicX&refwidgettype=cross_promot_widget&_trksid=p284.m184&_trkparms=algo%3DCRX%26its%3DS%252BI%252BSS%26itu%3DISS%252BUCI%252BSI%26otn%3D4 - http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280332500188QQssPageNameZMERC_VI_RCRX_Pr4_PcY_BID_Stores_IT&refitem=370187076431&itemcount=4&refwidgetloc=active_view_item&usedrule1=CrossSell_LogicX&refwidgettype=cross_promot_widget&_trksid=p284.m184&_trkparms=algo%3DCRX%26its%3DS%252BI%252BSS%26itu%3DISS%252BUCI%252BSI%26otn%3D4
or this for £5 that has a " Aluminum alloy case good for sinking heat !" http://cgi.ebay.com/USB-HiFi-Motorcycle-Car-Bike-Stereo-Amplifier-MP3-ipod_W0QQitemZ280332843361QQcmdZViewItemQQptZUK_Audio_TV_Electronics_In_Car_Entertainment_GPS_Car_Amplifiers_PP?hash=item280332843361&_trksid=p3911.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A2%7C294%3A50 - http://cgi.ebay.com/USB-HiFi-Motorcycle-Car-Bike-Stereo-Amplifier-MP3-ipod_W0QQitemZ280332843361QQcmdZViewItemQQptZUK_Audio_TV_Electronics_In_Car_Entertainment_GPS_Car_Amplifiers_PP?hash=item280332843361&_trksid=p3911.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A2%7C294%3A50
Date Posted: 13 April 2009 at 4:11pm
15W doesn't sound like much, but give it a try, you'll be surprised. It won't be much use for sub, but for anything over 100Hz I find it gives quite a bit of volume if you don't need megasplease...
Date Posted: 14 April 2009 at 1:02am
no way this will do 2x 75w, but even if it does 2x 10w rms itll be great because it looks like it has a high and low pass filter. wonder if it is bridgable... if so, one bridged low pass on a 8", and another stereo high passed on some mid+piezos:)
Posted By: phattomherby
Date Posted: 14 April 2009 at 10:33am
Sorry to hijack...
Come summer i'm going to be building a single 12v powered cab using bits i have at home and stuff off ebay.
I have 2 Delta 15-LF and 2 1" comps currently.
In WinISD i did some fiddling and will likely use a 125l box tuned to 42hz to accomodate a single delta 15lf.
For the mid i reckon i'll use a sealed back driver (or two) like the Alpha8MR and then the 1" for top, adjusting the size of the cab for the amount of space the mid, top and batteries will consume.
I'd prefer to run it active with settings as follows:
50-60hz hi pass filter and ~500hz low pass on the bass
~500hz hi pass on the mids and configure the low pass crossover in accordance with the 1".
I'm thinking that a 1" with a single 15 and two 8" might be a little too much, but if it's run active it'll be an easy problem to solve.
Build will be using the lightest but strongest wood, so 12mm ply or mdf i imagine with loads of bracing. Really want to keep it as light as possible.
Then an amp to suit. Hopefully something with 4 channels, so 2 bridged for bass then another each for mid and tops.
Will also have to look into batteries, don't want over kill so something that can be used for like 8 hours at max. with a more likely run time of about 4-6 hours.
i'm yet to figure it out, but with the bigger batteries (i.e. bigger than rc ni-cad batteries) how do you charge them up? would something like a car battery charger work? mainly cos i have one of those to hand and would prefer to not buy a new charger.
I'll be using for similar reasons to everyone else, small gatherings with friends in woods, at beach. but also to hopefully be able to go into the city set up on some grassland and blast out some tunes and ting.
I'll post pics up over time. And give details of the build with any problems i had.
Date Posted: 16 April 2009 at 1:10pm
just put the wheel system in place on my main cabinet. i was very worried the weight would be too much. it certainly weighs too much to carry, but once put on its corner and rolled, it is easypeasie. i have also included a pic of the bass driver for scale (18"). you can see the water proof coating i have applied to the cone to allow easy use in mild drizzle conditions. should come in at around 75-90kg if my calculations are correct...
Date Posted: 23 April 2009 at 10:06pm
for those looking for batteries...
http://cgi.ebay.co.uk/LEISURE-BATTERY-YUASA-12V-65AH-NPL65-12IFR_W0QQitemZ400040826039QQcmdZViewItemQQptZUK_Campervan_Caravan_Accessories?hash=item400040826039&_trksid=p3286.c0.m14&_trkparms=72%3A1690%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318 - http://cgi.ebay.co.uk/LEISURE-BATTERY-YUASA-12V-65AH-NPL65-12IFR_W0QQitemZ400040826039QQcmdZViewItemQQptZUK_Campervan_Caravan_Accessories?hash=item400040826039&_trksid=p3286.c0.m14&_trkparms=72%3A1690%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
65ah for £30 delivered cant be bad. gonna need a 1 farad power cap due to limited current draw capabilities, but a 300w car amp will run well off this...
Posted By: SamV
Date Posted: 24 April 2009 at 1:00am
You sure about the cap rich? It made no discernible difference to my various systems.
Date Posted: 24 April 2009 at 10:14am
it depends. from what i remember reading, your battery is one that works well in high current apps...
i know my battery (a ups style - not deep high discharge rate) struggles to deliver the current my amplifier wants-it is trying to draw up to 40-60amps @ 8ohm i imagine.. then again, a 12v class d amp will draw half what my a/b amp is pulling for the same power output and probably wont need a cap. i intend on adding a cap to my power system to cut the stresses im putting on the battery and to also give me a quicker and less resistive supply to the amp when the kicks suck energy. i can visably see the power led dimming on very high volumes and clipping occcurs earlier than it should.
with a car wet cell or deep cycle/cranking battery a cap wont make much difference other than cutting down on headlight dimming when the kicks hit.. if you check specs on this 65ah for £30, it has quite a high internal resistance meaning significantly less cranking output than a similarly sized battery designed specifically for high current delivery.
im pretty sure this £30 65ah battery will deliver more than enough for the average duty. and imo adding a £25 cap should mean you end up with a cost effective setup that will compete against a high current battery costing around £100-150.
Posted By: SamV
Date Posted: 24 April 2009 at 10:59am
Sounds good in that case but will the batt be able to keep the cap charged up?
Date Posted: 24 April 2009 at 3:33pm
it should have time in between the periods of peak draw, which should only last a few ms.
Posted By: tomschute
Date Posted: 26 April 2009 at 11:40am
just bought one of these from ebay for a look see - i'll report back when it arives.
------------- Out to lunch... stableaudio@hotmail.co.uk www.stableaudio.co.uk Speaker Building Services
Posted By: subbass
Date Posted: 26 April 2009 at 1:02pm
Was looking at those myself ..
The question is; what does their 500w translate to in RMS? 50wrms x 2 maybe?
Date Posted: 26 April 2009 at 1:07pm
i imagine itll do 2x10-20wrms at a push. which is more than enough to run an efficient 12"+ tweeter imo. is it bridgable? and do you know the highpass/lowpass filter freq?
------------- REFLEX ALL THE WAY.... (however, im playing with horns again...) That ok Mister Valiant? :)
Posted By: djeddie
Date Posted: 26 April 2009 at 3:42pm
500W! They must be joking! Only on a Tuesday, when the crow is flying south, the moon is picking it's a**e etc. etc. These are advertised elsewhere (CPC I think) as 10W.
------------- Chas n Dave : it's like Drum and Bass but with beards. E=mc² ±3dB
Date Posted: 26 April 2009 at 7:06pm
rich_gale wrote:
i imagine itll do 2x10-20wrms at a push. which is more than enough to run an efficient 12"+ tweeter imo. is it bridgable? and do you know the highpass/lowpass filter freq? |
well i'll give it a bloody good thrash and find out :)
Posted By: subbass
Date Posted: 27 April 2009 at 10:54pm
http://cgi.ebay.co.uk/Portable-Sound-Set-With-Wireless-Mics-RRP_W0QQitemZ120410390159QQcmdZViewItemQQptZUK_ConElec_SpeakersPASystems_RL?hash=item120410390159&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1318 -
Looks like you can make money from ebaying these :). Have asked the buyer for details on the batt, drivers and amp
Posted By: SamV
Date Posted: 27 April 2009 at 11:12pm
Alas the margins aren't there to be worth the hassle. I build quite a few systems a year for people and most want something but can't usually stretch for it. I'd struggle to build a system like that for that price and that's just the materials.
Posted By: subbass
Date Posted: 27 April 2009 at 11:34pm
Well, he's using a 12Ah battery (£25?), 100w car amp (£40?), x2 unbranded 8" (£35?), x2 unbranded 3" (£15?), wireless mics (£35?), headunit thing (£20?) wood + other bits (£40?)
and thats £210 for all that..
Posted By: snowyweston
Date Posted: 28 April 2009 at 12:08am
Haven't been here in awhile and just spotted Sam's pimping his tricks here aswell!
Thought I'd post my little effort from a few years back -
Easily covers a 5-aside football pitch in the park with music for about 8 hours!
2 channel Maystar car amp bridged to mono (optimistically 150W) running an Eminence Beta 12 & El'Cheapo Maplin Piezo horn (in parallel to show 4ohm) running off a 36aH SLA in an astro-turfed birch ply (sealed) enclosure (approx. 40x30x75) on chunky castors.
I'm thinking of making a smaller one for this summer, but I'm only at the design stage:
with a smaller bass driver + a decent marine-orientated coax for mids&highs to clean up the sound - the originals are a bit unweidly (guesstimate 40kg) despite the wheels - which you definately shouldn't scrimp on by any means; the tatty little luggage-wheels you get on most of the carlsbro wanderer (etc) type ones are only good for inside or very light travel to and from the train to a taxi for travelling salesmen.... they'll fail the instant you get anywhere near gravel, grass, sand etc...
Personally I've been looking into getting these
6" pneumatic fixed-castors direct from a China manufacturer at £5 a pop (rather than £30 European marked up ones) but couldn't blag a free sample pair to trial them .
As for those cheap fleabay amps - don't waste your money - you'll get no more output than you would from those natty travel ipod systems that everyone and their daughter has in their hotel rooms on holiday...
So Sam, you going to sell me the Sony's yet?
Posted By: SamV
Date Posted: 28 April 2009 at 5:51pm
Date Posted: 28 April 2009 at 7:54pm
those pnuematic castors look tasty:) my cabinet uses sack truck tyres on 16mm threaded rod. they work a treat but are nowhere near as resilient looking as those beasts. i also love the astro turfing.
Posted By: SamV
Date Posted: 29 April 2009 at 2:17am
Group buy on those wheels? I'll take 4 pairs :)
Date Posted: 29 April 2009 at 2:12pm
I'll dig out the emails I had with a "George" to see what kind of numbers he mentioned for keeping the shipping down so the savings make sense.
IIRC correctly it was the business-style payment for the shipping of the trial pair I was requesting that stopped me, my bank not doing "international" transfers despite being "The World's Local Bank".
I'd buy at least 2 pairs, maybe more if I can fix a sample and they're decent...
Posted By: renzelkouten
Date Posted: 29 April 2009 at 5:21pm
ill have two
------------- dub it up
Date Posted: 04 May 2009 at 10:57am
http://img4.imageshack.us/img4/2480/dscn4793m.jpg - http://img4.imageshack.us/img4/2480/dscn4793m.jpg
Posted By: SamV
Date Posted: 04 May 2009 at 12:59pm
hah I like it! Baby stack!
Date Posted: 18 May 2009 at 10:03pm
So excited...
just to let you all know that this weekend i'll be commencing the build of my first ever 12volt system.
I'll be using a delta 15lf run from 50-60hz to 500hz, an alpha 8 mr from 500 to 2.5k and a 1" comp from 2.5k onwards using a 3 way passive eminence crossover.
i'm yet to buy the amp or battery but i'm looking to get a 3-400w ish monoblock thing. and a battery that'll last 5hours.
could anybody advise me on what type of battery i'll need, would 17ah last a decent amount of time?
will have pictures up sometime next week.
Posted By: SamV
Date Posted: 18 May 2009 at 10:19pm
^^^ 400w mono blocks are hard to find as most tend to be for sub duties. Your best might be a 2ch channel tripath or a 4ch with the rear channels bridged. As for batteries I dunno, I tend to buy the biggest for the money.
Date Posted: 18 May 2009 at 10:37pm
IIRC, you cannot bridge the lower power tripath amps, as they're already bridged...
You'd be suprised how loud they go with efficient drivers however...
Date Posted: 18 May 2009 at 10:57pm
got it through - it's sh*t as expected
Date Posted: 18 May 2009 at 11:25pm
Hah, how many RMS watts is it? Is it tripath?
Posted By: subbass
Date Posted: 18 May 2009 at 11:34pm
how many megawatts of power dya reckon from that thing then?
Got some spare cash the other day, so bought myself a little tripath amp. Got a true 20wrms per channel and was meant to be fairly expensive. (£80+). Thanks to the wonders of ebay and alot of luck I got it for £32 inc. p&p :D
Here it is driving me missions (cheap on ebay cos they didnt have grills ). Anyways, it really does pump out 20w p/c. These missions are 84 spl w/m sensitivity, so with some eminence betas (96 spl w/m) my guess is it'll be pretty damn loud. (It still quite happily overpowers the missions..) You can get decent tripath ones pretty cheap - i would get one with bass / treble knobs though if I were you....
Posted By: SamV
Date Posted: 18 May 2009 at 11:35pm
Sorry should have worded that clearer, I mean the 4ch bridged.
Date Posted: 19 May 2009 at 12:49am
i'll open it up and post up.
But it is fairly useless.
Posted By: subbass
Date Posted: 30 May 2009 at 3:42pm
http://www.dubpram.co.uk/ - http://www.dubpram.co.uk/
Posted By: _djk_
Date Posted: 30 May 2009 at 9:49pm
The Tripath shown is only 7W/8R and 12W/4R at clipping with a regulated 13.5V supply. Power will be lower on a 12V battery, and drop rapidly as the battery is discharged in use.
To me it makes more sense to use two 12V batteries in series. Power goes with the square of voltage so you can get about 4x as much.
These are on eBay all the time for reasonable money (under USD$40 with shipping)
http://www.sureelectronics.net/goods.php?id=920 - http://www.sureelectronics.net/goods.php?id=920
------------- djk
Posted By: Grinner
Date Posted: 31 May 2009 at 12:10pm
rich_gale wrote:
one last important point i think is worth making is that i find running an electronic high pass filter saves oodles of battery life. my rig wont go much lower than 60hz, so i threw the highpass on the amp to 60hz. this is pretty damn low setting for a built in high pass on a car amp so i was lucky(most are around 80-120hz). you might want to look at electronic kits or 12volt crossovers where you can highpass the input to your amps. |
can you recomend a 12v crossover?
Date Posted: 31 May 2009 at 12:14pm
I've been lazy and just bought a Blaupunkt Velocity2Go 6 for a bit of a bargain price after hearing some very good feedback on it from a friend I trust.
It runs off 8 AA rechargeables when portable but has hookups for a 12v input to be used as a car 'sub' when not making noise in fields and parks; I was thinking of getting a battery and a little trolley for it to get extra volume and longer playback, can anybody recommend one reasonably cheap?
Posted By: subbass
Date Posted: 31 May 2009 at 12:35pm
Those sure amps are looking quite appealing now..
I think bi-amping was mentioned earlier - think thats maybe the best direction? Setting the volume on the HF and LF amps to balance it out roughly, with an active Xover feeding into them the right frequencies.. (and EQing it all)
that way would also cut out the passive Xovers and Lpads :)
Posted By: _djk_
Date Posted: 31 May 2009 at 1:43pm
Yes, I would bi-amp with a car crossover and a pair of the Tripath amps from SureElectronics.
The bigger amps will run on anything from 10V~36V (of course the power depends on the voltage you use) . The small one is 12V only, and is currently USD$14.
http://www.sureelectronics.net/goods.php?id=12 - http://www.sureelectronics.net/goods.php?id=12
javascript:;">
------------- djk
Date Posted: 31 May 2009 at 3:27pm
would be worth using a tripath at 36v using 3 12v sla's in series. do i assume right that you'd get longer usage time running at 36v/10ah versus 12v/30ah?
grinner: go onto ebay and search 'crossover' in 'in car entertainment'. plenty pop up on there.
Date Posted: 31 May 2009 at 4:19pm
Just uploaded a video of yesterday in the sun. had it running to the point where the built in passive crossover was running out of steam. got there at about 12.30 and had it running till 7pm. no wind so amp was red hot!, battery still had loads more reserves!
http://www.youtube.com/watch?v=pjo_LKo7w7A - http://www.youtube.com/watch?v=pjo_LKo7w7A
Posted By: subbass
Date Posted: 31 May 2009 at 11:21pm
Nice use of the toasty weather there rich
check out this sure beauty:
http://www.sureelectronics.net/goods.php?id=918 - http://www.sureelectronics.net/goods.php?id=918
was kinda hidden on their site, but gives 100wrms per chan instead of 50.. mmmm
Posted By: _djk_
Date Posted: 01 June 2009 at 8:35am
It is the same amplifier except for paralleled outputs.
At 4R it is capable of about 70W before clipping, maybe 40W/8R. The 100W/4R rating is at 10% THD.
------------- djk
Date Posted: 01 June 2009 at 9:23am
was kinda hidden on their site, but gives 100wrms per chan instead of 50.. mmmm |
gonna get two of these. feed them each a 36v supply and reap the rewards. one side will run a 12" in a mini tapped horn. the other will run a 6"+ high power dome. 100hz crossover. my current rig is too big for little trips places and wont fit in the saloon either. im going for pure hi-fi quality and high efficiency on this new setup. instead of raw power and big battery reserves.
Date Posted: 01 June 2009 at 9:54am
Nice pics rich, that's near the Thekla isn't it?
I made another battery pack on the weekend, I got some pics also, I'll post em up when I get a chance, I managed to blow a TA2020 Lepai amp also so I'm trying to fix it as it sounded very nice when working... I have a feeling it's the output inductors as they use veyr thing wire...
Date Posted: 01 June 2009 at 10:55am
yep mike. thekla is about 20mtrs down the river. the perfect day to be down there. baking hot!
Posted By: biotec
Date Posted: 01 June 2009 at 11:07am
Wilson?
------------- me so horny, me love you long throw.
Date Posted: 01 June 2009 at 11:48am
biotec wrote:
toastyghost wrote:
I've been lazy and just bought a Blaupunkt Velocity2Go 6 for a bit of a bargain price after hearing some very good feedback on it from a friend I trust. |
Wilson? |
Yup, he couldn't wax enough lyrical about it!
Posted By: subbass
Date Posted: 01 June 2009 at 8:35pm
I take it the 2*100 sure amp is enough juice to give the beta 8s a good bit of volume? Apologies for me keeping on asking this kind of question
Oh, and proper stupid question here:
I know that those amps can't be bridged, but would combining two of the amps as shown work, and how well? shown only 1 channel of each, but channel 2 would work the same.....
AMP1 AMP2 speaker + | channel 1 + >>>>>>>>|<<<<<<<<< + channel 1
channel 1 - >>>>>>>>|<<<<<<<<< - channel 1 |
Date Posted: 01 June 2009 at 9:17pm
only if you have a dual voice coil. you cant just run two plus's and two minus's into one coil, which is a shame.
the beta 8's will be loud with 5 true watts of power into them, 20wrms will be fine.. all depends what you require. you wont get much bass from the beta's. why not use a few drivers? like some of the skytronic 8" drivers i used for my bro's rig? way cheaper than eminences, and pretty much the same thing.
Posted By: subbass
Date Posted: 01 June 2009 at 9:31pm
Well, I was hoping to EQ the eminences / bass boost them with the xover / equaliser thing to give a decent amount of bass .. Although you reckon it would be better to use a combination of drivers? I was kinda aiming for a simple solution with two drivers per side - but if you reckon it'll work better with a hf, mid and lf then Ill go for that
Date Posted: 01 June 2009 at 9:54pm
personally, id go with a single box and not worry about left and right.
Posted By: subbass
Date Posted: 01 June 2009 at 10:01pm
Date Posted: 01 June 2009 at 10:20pm
it just makes things a lot easier to transport.. less stuff to break/lose, better bass resonse, easier to make..
id tune a double 8" box to 60/80hz and apply a 60hz high pass to cut down on wasted power and excursion. id then run the pair of woofers off one side of the amp, and a pair of softdome tweeters off the other side (each channel will see a 4ohm load thatway). remember that you will want to look for active crossovers with above 12db/oct. a half din unit is nice if it has a volume knob and eq adjustment because it gives you a preamp to boost the pitiful output from an ipod etc.
Posted By: subbass
Date Posted: 02 June 2009 at 5:35pm
Perhaps - I am pretty set on my form factor though
gonna have a think about it over the next few weeks, the exams finish on the weekend of the 20th, so ill get making it asap after that :)
Posted By: subbass
Date Posted: 03 June 2009 at 7:18pm
Date Posted: 03 June 2009 at 8:35pm
nice job.
tune the cab to 60hz and the woofers will kick out a racket. the skytronic 3 way crossovers should work well with this config. crossover freq's are 800hz and 5khz. though if you are going active crossovers, id cross to the 6" drivers at 400hz to give them more work (they are more efficient than the 8" ones in the prominant midrange. are the 6" drivers closed back?
Date Posted: 03 June 2009 at 8:38pm
you might get away with leaving out the 6" tbh. though the 6" drivers will be a little smoother. at the levels you will be running, the apt tweeters will be able to be run at their lowest crossover freq so you wont need the 8" drivers to go really high up..
Posted By: Grinner
Date Posted: 03 June 2009 at 9:00pm
right you lot got me on a mission , after reading about all the 12v systems took the 1st step today an looked atwhaaatjunk bits i had laying around. i gotta build a 2 enclosures 1 for the bass with a access for battery an 1 for the mid tops an have it so i can pole mount it once i arrived at destination, thats the plan. waiting for 12 volt crossover to arrive too. in the mean time here is what i started with http://www.youtube.com/watch?v=dIzaKF15gX4
let the fun begin
Posted By: subbass
Date Posted: 03 June 2009 at 10:24pm
Yeah, gonna run it with an active Xover I've decided..
The 6" Fanes are open back I guess (in that you can see the cone through the basket??), but on blue aran they say that it can either be run full range if its ported, or mid only if its in a small sealed box.. I guess I'll decide how to run them once I've made the box - I'll then try out different ways of doing it.
amp-wise, im thinking for 2*50 for high, 2*50 for mid, with 2*100 for the 8" .. Would this work out about right? I'm unsure how much juice the tweeters would need to keep up with the rest it though - could 2*15 be enough? (These are all the sure amps btw). would all be wired up in parallel to keep pd constant
Date Posted: 04 June 2009 at 10:34am
amp-wise, im thinking for 2*50 for high, 2*50 for mid, with 2*100 for the 8" .. Would this work out about right? I'm unsure how much juice the tweeters would need to keep up with the rest it though - could 2*15 be enough? (These are all the sure amps btw). would all be wired up in parallel to keep pd constant |
for an active crossover....
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=250396016902 - http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=250396016902
having a low pass of 400hz would work well with your 8" woofers too.
I think you should go for a 2x100 for the 8" woofers, and a 2x50 for the 6"+apt's, but run the apt's with a passive 2-4k crossover. once you have them all set up, just pad the apt if its a bit too loud for the rest?
Posted By: subbass
Date Posted: 05 June 2009 at 6:44pm
That looks great, looks like it'll do the job well - thanks :)
pretty sure I'll go with that plan then, once I get this thing up and running should blow away all those other sh*tty portable boomboxs on the market
Date Posted: 09 June 2009 at 8:47pm
has anyone got experience with these?
http://cgi.ebay.co.uk/2-100-watt-4ohm-TK2050-Class-D-Audio-Amplifier-Board_W0QQitemZ250439095410QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a4f555472&_trksid=p4634.c0.m14.l1262&_trkparms=%7C301%3A1%7C293%3A1%7C294%3A30 - http://cgi.ebay.co.uk/2-100-watt-4ohm-TK2050-Class-D-Audio-Amplifier-Board_W0QQitemZ250439095410QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a4f555472&_trksid=p4634.c0.m14.l1262&_trkparms=%7C301%3A1%7C293%3A1%7C294%3A30
if so, assuming i give it a 24volt dc supply, what sort of real world rms power are we talking into a 4r load? and what sort of current draw are we talking @24volts?
also, is this a plug and play device? or do i need to supply my own heatsinking?
Posted By: _djk_
Date Posted: 10 June 2009 at 10:13am
The Pyramid crossover does not have a low-pass filter on the midrange output. I used to use a lot of these for car stereo (years ago). Better opamps and bypassing the coupling caps with a small film type will make them sound much cleaner (but that is true of almost every brand on the market).
The Sure 100W amplifier will clip at 70W/4R with a 36V supply, about 40W/4R with 24V.
With both channels driven at clipping with 4R/24V the peak supply current will be about 12A. On 50% duty cycle program material (sine-sweep bass) I would say about 6A RMS.
The Sure amps are ready to play. They come with a little heatsink that would benifit from a fan if you plan to pound it hard. Others have installed bigger heatsinks.
http://www.diyaudio.com/forums/showthread.php?s=5769114bfaee3b16600c0c945690d257&threadid=143669&perpage=25&pagenumber=4 - http://www.diyaudio.com/forums/showthread.php?s=5769114bfaee3b16600c0c945690d257&threadid=143669&perpage=25&pagenumber=4
------------- djk
Date Posted: 10 June 2009 at 1:39pm
cheers mate.
just picked up a pair of dvc woofers with 4r coils. gonna run each woofer off one of these sure amps. one coil per channel. starting to look as if the system is gonna be very lightweight compared to my current setup:) ill only need 12ah compared to 90ah for similar volume/running times!
thanks for the detailed description. very helpful mate
Posted By: subbass
Date Posted: 14 June 2009 at 5:45pm
http://cgi.ebay.co.uk/36V-15AH-LiFePO4-Electric-Scooter-E-Bike-Ping-Battery_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7c39Q3a1Q7c72Q3a1683Q7c240Q3a1307Q7c301Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem4a98194d82QQitemZ320379374978QQptZLHQ5fDefaultDomainQ5f0QQsalenotsupported - http://cgi.ebay.co.uk/36V-15AH-LiFePO4-Electric-Scooter-E-Bike-Ping-Battery_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7c39Q3a1Q7c72Q3a1683Q7c240Q3a1307Q7c301Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem4a98194d82QQitemZ320379374978QQptZLHQ5fDefaultDomainQ5f0QQsalenotsupported
If only I had the cash
36v, 15AH Lithium Battery....
(same capacity as a 45AH 12v battery)
Date Posted: 14 June 2009 at 6:18pm
very nice indeed man. i looked into building a nickle metal hydride pack of the same voltage and similar capacity. purchasing all the cells and hardware to make it would cost just over £100.
the lipo you linked is probably half the weight of the nickel one i been working on... im imagining a battery of this type might be sub £100 in a couple of years..
Posted By: subbass
Date Posted: 14 June 2009 at 11:34pm
Yeah, the idea of using a lead based battery for a portable system would seem pretty illogical to most people
but then again, it is the most cost-effective way by far ...
Date Posted: 15 June 2009 at 12:20am
Even pillaging old laptop battery packs, it can get quite expensive to make Li-ion battery packs once the capacity and voltage gets higher.
It can take quite a bit of time also, but Li-ion batteries are nice and light, around 1/3rd of the weight of Ni-mh for the same capacity.
I made another 11.1v pack recently, as I managed to kill one of the cells in my old pack:
If I made a 3rd pack I guess I could wire them in series and have a 33.3v pack, but only 4.8AH however... but it would be good for 10A of current before anything nasty happens! 330W is a fair amount of power to be pulling from a pack tho...
Date Posted: 15 June 2009 at 10:22am
cheers mike.
you just persuaded me to pop onto ebay and search for some laptop batts..
i just won a job lot of 10 laptop batteries. 10.8v, 4400mah, li-ion..
i worked out that if each cell is 3.6 volt, ill have 3 cells per battery (or three pairs of parallel cells).
so total should give me 36volt @ 13ah if i run 3 parallel sets of 10 cells in series.
i won the auction for the starting bid of £4 and delivery of £12.. so a total of £16 delivered!
so mike, please could you give any pointers to successful removal of cells from packs, rewiring and charging tips? and any other advise you might have learned?
for charging i been thinking maybe using tamiya remote control car battery connectors and making a few 10.8v packs to link in series during use, and charging each pack seperately at 10.8v from a laptop charger... any views?
