10,000 watt macro tech
Forum Name: Amp Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=32059
Printed Date: 28 March 2024 at 9:13am Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: 10,000 watt macro tech
Posted By: samson
Subject: 10,000 watt macro tech
Date Posted: 27 October 2009 at 12:20am
http://1 -
Hi guys came accros this picture of a 10,000watt macro tech amp..
Is this a picture of a prototype? Or maybe a failed attemp by crown to build such a beast?
Must weigh a ton if a prototype does exist
------------- Wisdom is better then silver and gold..
Posted By: cilla.scope
Date Posted: 27 October 2009 at 12:53am
http://www.crownaudio.com/pdf/legacy/k10684.pdf - http://www.crownaudio.com/pdf/legacy/k10684.pdf
seems it was intended for stadium use ... down into 0.5R .. but otherwise, not particularly powerfu.. especially when you consider the 10,000 watts was only for a single cycle of 1khz .. was down to 6K for a 40ms burst .. RMS was probaly 3K or so ...
I think I saw one of these driving a vibration test rig once ...
Posted By: studio45
Date Posted: 27 October 2009 at 1:21am
they were a full production item but presumably not many were sold, remember Crown, Amcron and AE Techron are the same company but AE T. specialise in medical equipment ie MRI scanner coil drivers- that's probably the genesis of this unit. Output current capability more impressive than voltage so works best on v. low impedance loads. 8x PD1850's hanging off this thing would be saying plenty i reckon!
------------- Studio45 - Repairs & Building Commotion Soundsystem -Mobile PA
Posted By: ceharden
Date Posted: 27 October 2009 at 1:37am
It's impressively large but the Crest 10001 is more impressive in terms of power output.
Posted By: Elliot Thompson
Date Posted: 27 October 2009 at 1:44am
The Crown Macro-Tech 10,000 requires 3-Phase 208 volts in order to operate. Who is moving about with that type of voltage.
It is the main reason why it never caught on in the States. There is a shop in New York that has one for display purposes.
Best Regards,
------------- Elliot Thompson
Posted By: colint
Date Posted: 27 October 2009 at 5:15am
8x PD1850's hanging off this thing would be saying plenty i reckon! |
So would your back tryiny to move it? I saw one of these at one of the plasa shows on the shuttlesound stand (display only)
it was huge, they said one was installed at of of the usa motor race tracks powering 64 bose 802's?
------------- Never criticise another man until you've walked a mile in his shoes. Once you have, call him what you like, you're a mile away and you've got his shoes!
Posted By: DjMidKnight
Date Posted: 27 October 2009 at 5:46am
Best Regards, |
Actually any venue large enough to need that kind of sound would have 208 3phase. 3phase is fairly standard in commercial buildings. given its not a standard but most major venues should have it. none the less an amp of that magnatude isnt intended for the average end user there built for installation.
Posted By: Wikl109
Date Posted: 27 October 2009 at 9:50am
I love stuff like this. Way over the top equipment that manufacturers simply wouldn't make now due to the cost issues. Some of the high end 'home' speaker systems Tannoy and JBL used to make were also just stupid.
Just look at some of the specs of this Crown monster, 80 output devices, gulp!
Posted By: burningbush
Date Posted: 27 October 2009 at 10:48am
Looks like it should have its own gravity field.
------------- music is the message
Posted By: numtie
Date Posted: 27 October 2009 at 1:19pm
wasnt it crown who also produced the infamous 1u belchfire
------------- Disco Hire Wales
Posted By: CLsystems
Date Posted: 27 October 2009 at 2:15pm
i believe it was indianapolis speedway, that had these.
Posted By: jonminns
Date Posted: 27 October 2009 at 2:16pm
The belchfire was a comedy datasheet production by crown, really quite funny for nerds such as myself
The MA10,000 is intended for running to very low impedance loads (eg a large impedance based paging system rather than 100v)
------------- 4 ohms is for wimps
Date Posted: 27 October 2009 at 3:15pm
Best Regards, | Actually any venue large enough to need that kind of sound would have 208 3phase. 3phase is fairly standard in commercial buildings. given its not a standard but most major venues should have it. none the less an amp of that magnatude isnt intended for the average end user there built for installation. |
In the 1980's, there wasn't a need for that type of voltage demand, as you would see today in the entertainment industry in the United States. With a lot of lighting being used today as oppose to 30 years ago as a means of effects, having 3 phase 208 volts was a rarity when this amplifier was introduced in the market.
The majority of audio professionals in the States are trying to get as much as they can on a 120-volt line, hence, the reason Crown & QSC only focuses on building 120-volt designs. There are only a few I know in the States (myself included) that operate their MA 5000vz amplifiers on 240 volts much less 208 single-phase. However the majority of users are operating those amplifiers on a 120-volt line source despite, having the ability to perform better on higher voltage.
Best Regards,
Posted By: colint
Date Posted: 27 October 2009 at 4:28pm
CLsystems wrote:
i believe it was indianapolis speedway, that had these. |
That'd be the one!
Posted By: jonminns
Date Posted: 27 October 2009 at 4:54pm
Is 240 an option in the US? Or is it done via a local transformer
Posted By: rich21
Date Posted: 27 October 2009 at 5:20pm
http://www.crownaudio.com/pdf/legacy/belchfire_datasheet.pdf - http://www.crownaudio.com/pdf/legacy/belchfire_datasheet.pdf
ahh the memory's
Date Posted: 27 October 2009 at 5:32pm
i think from what ive been told, most houses have both 110v, and 240v supplys. the 240v is used for tumble dryers washing machines etc.
Date Posted: 27 October 2009 at 6:06pm
The standard system installed here in the USA for small buildings and residences is 240V 60 hz single phase with a center taped neutral. either end of the phase to center is 120V and from one end of the coil to the other is 240V. Which messes people up because they think that its actually 2 phases when in reality its just pseudo 2phase system.
Date Posted: 27 October 2009 at 6:55pm
I not sure any members will remember this,it was pre-speakerplans days,there was three of these badged as AE Techron on ebay as a job lot about 5years ago,apparently they had been removed from some government testing installation,but yes,they were deffinately 3-phase...all three together went for about £800....they must have cost a fortune new.
------------- Be seeing you.
Posted By: colint
Date Posted: 27 October 2009 at 7:04pm
This is what you need to power your soundlabs:
http://www.aetechron.com/7796.html - http://www.aetechron.com/7796.html
some useful links on the site too!
Posted By: ychole audio
Date Posted: 27 October 2009 at 7:21pm
Here's the datasheet:Oh my!!
------------- I am ZERIEL'S dad!!!
Date Posted: 27 October 2009 at 7:23pm
Weight 153 lbs. (69 kg)
Now thats heavy!
Posted By: Jake_Fielder
Date Posted: 27 October 2009 at 8:39pm
Imagine what you could do with 6u these days! a bit more than 6000w burst!!
Date Posted: 27 October 2009 at 8:58pm
Jake_Fielder wrote:
Imagine what you could do with 6u these days! a bit more than 6000w burst!! |
72,000 watts of Powersoft K 10 ... Burst!
Date Posted: 27 October 2009 at 9:04pm
How much would they weigh? about the same probably...?
Date Posted: 27 October 2009 at 10:00pm
Jake_Fielder wrote:
How much would they weigh? about the same probably...? |
I would estimate 2.8 kg more. Not bad for 62,000 watts more.
Best Regards,
Posted By: SamV
Date Posted: 28 October 2009 at 3:10am
ahh the memory's
Reads like the Behringer sales pitch
Posted By: studio45
Date Posted: 28 October 2009 at 4:15am
seriously, when MRI goes out of fashion...get down to the hospitals and start bidding :) so many massive amps...sooo many.... I wonder if the doctors will start to upgrade to SMPS and Class D as well?
Posted By: Plaguesguitarist
Date Posted: 02 November 2009 at 8:40pm
ahh the memory's
HAHAHA!
i loved that.
A manly mans amp.
------------- Why did the lampy cross the road?
To steal MY sharpie.
Date Posted: 02 November 2009 at 8:58pm
That is soo funny! 1 unit (1.75 inchs), x 6 foot deep!
Date Posted: 02 November 2009 at 9:01pm
That is soo funny! 1 unit (1.75 inchs), x 6 foot deep! |
Edit...someone at Crown has a great sense of humour,the 6000sux was of course the "desired" futuristic new car in the original Robocop film.
Posted By: DjLeco
Date Posted: 03 November 2009 at 5:08pm
Laughing or not, the MA10000 from Crown, is the MOST POWERFULL class AB+B amplifier ever made.
The lowest distortion (of AB+B class, regarding any else other class amplifiers) and the lowest impedance desired by those design, must be appreciated.
But we're glorious to be proud, comparing of this one with "a stack" of digital's powersoft 20 mSecs BURST(bull$hit power) of same height and weight....
That's are people, we forget very fast,and denigrate Crown's OLD SCHOOL AMPLIFIERS.
Shame!
------------- I'm A Stupid SMART Romanian...
Date Posted: 04 November 2009 at 12:45am
Shame!
The Crown MA 10,000 wattage is based on burst. If you look at the continuous average power, it is the same as the Crown MA 5000 @ 4 ohms.
If you Parallel Mono one Crown MA 5000vz and load it at 1-ohm against one Crown MA 10,000 in a 1-ohm load the wattage will be basically the same from a continuous average rating.
Best Regards,
Posted By: DjLeco
Date Posted: 04 November 2009 at 10:08pm
I'm speaking about his maximum output power on 0,5 ohms.
No one has made an AB or AB+B Class amplifier, suitable for 0,5 ohms loading and at that amount of power.
5000VZ is suitable for 2 ohms or above, or mono parralel for 1 ohm loading.
Posted By: tallmike
Date Posted: 04 November 2009 at 10:12pm
0.5 ohms... I often load to that.
Date Posted: 05 November 2009 at 3:02am
5000VZ is suitable for 2 ohms or above, or mono parralel for 1 ohm loading. |
Fair enough.
Best Regards,
