Wbin JBL (SA4518 model) 18 inch
Category: Plans
Forum Name: Other plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=33244
Printed Date: 19 March 2024 at 1:12pm Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Wbin JBL (SA4518 model) 18 inch
Posted By: arno
Subject: Wbin JBL (SA4518 model) 18 inch
Date Posted: 01 December 2009 at 7:27pm
I just bought two of these empty
i have a void v18 1000 but its in the x1
so my question would the void be any good in the jbl bin ?
or does someone know a suitable driver ?
grtz arno
Posted By: giordihc
Date Posted: 01 December 2009 at 8:19pm
you need jbl 2240 or jbl E-155
Posted By: arno
Date Posted: 01 December 2009 at 9:20pm
giordihc wrote:
you need jbl 2240 or jbl E-155 |
No i wanna put other drivers in it, instead of the jbl's.
If i put PD.1850 or void acoustics v18, what would it sound like?
Posted By: _djk_
Date Posted: 02 December 2009 at 12:16am
The W18 Keele box was designed for the JBL K151.
The back volume is about 5 cu ft tuned to 35hz.
Look for a driver with specs similar to these:
Qts=0.3
Fs=35hz
Vas=12 cu ft
------------- djk
Posted By: giordihc
Date Posted: 02 December 2009 at 7:42am
If i put PD.1850 or void acoustics v18, what would it sound like? |
ok sorry i didnt understand you dont want to use jbl drivers.. mine were loaded with jbl2240h..i never used pd or void in wbins,but i dont think they sound good in this kind of cabinet.
Posted By: ychole audio
Date Posted: 02 December 2009 at 2:50pm
I have 4 of those loaded with 2240H and its amazing.You can try loading them with PD's if you have them lying around and let us know how it works.
------------- I am ZERIEL'S dad!!!
Posted By: 510
Date Posted: 06 December 2009 at 5:18pm
the wbin was a failure thats why it was discontinued so quickley i knew a fellow that had 48 of these mistakes , but if you want you can load them with the 2241 or gauss 18
Posted By: _djk_
Date Posted: 07 December 2009 at 7:36am
It helps to have the correct driver, and not overdrive them.
------------- djk
Date Posted: 07 December 2009 at 9:11am
Interestingly,that photo is almost identical to the Court acoustics 18" port-assisted w-bin,produced around the same time,early 1980's i think?
Court loaded theirs with the 2240.
------------- Be seeing you.
Posted By: _djk_
Date Posted: 07 December 2009 at 10:42am
2240?
I guess it would work.
2241?
Vas too high, Qts too high.
The 2242 would be a much better choice.
------------- djk
Posted By: Tedski
Date Posted: 07 December 2009 at 9:00pm
510 wrote:
the wbin was a failure thats why it was discontinued so quickley i knew a fellow that had 48 of these mistakes , but if you want you can load them with the 2241 or gauss 18 |
That's a bit strong. Literally thousands of these were made by JBL, SA(Holland) and countless others. The Keele W box was, for its time, quite efficient. Me and my mates still have an old W/Court/4512 rig and we still use it sometimes.
We also have them loaded with 2240. I think if you load it with an 1850, you would start to have to reinforce the bracing. With a 2240 at high power the box colours the sound a lot already, big horn honk, can only imagine what would happen with an 1850.
Edit: Maybe a fresh calculation of the ports would help for an 1850.
Posted By: giordihc
Date Posted: 09 December 2009 at 8:24am
2241 doesnt work in wbin
Posted By: _djk_
Date Posted: 09 December 2009 at 9:47am
"2241 doesnt work in wbin"
It doesn't work in THIS W-bin, the back volume is way too small.
------------- djk
Posted By: giordihc
Date Posted: 09 December 2009 at 9:54am
It doesn't work in THIS W-bin, the back volume is way too small. |
yep sorry i meant that
Posted By: 510
Date Posted: 13 December 2009 at 4:31pm
the 2241 was built to take over from the 2240 as a direct replacement, i had quite a few jbl factory built orignals boxes that jbl sent me the replacement speakers and they were the 2241, so your saying that jbl dont know their own speakers . the 2240 was rated at 400 watts and the 2241 600 watts
Posted By: giordihc
Date Posted: 13 December 2009 at 9:53pm
510 wrote:
the 2241 was built to take over from the 2240 as a direct replacement, i had quite a few jbl factory built orignals boxes that jbl sent me the replacement speakers and they were the 2241, so your saying that jbl dont know their own speakers . the 2240 was rated at 400 watts and the 2241 600 watts |
jbl probably sent the 2241 because the 2240 is out of production.but they have different parameters so they cant be the same.noone,here,said"jbl dont know their own speakers"..but if you ask for 2240 and its not available anymore they have to sell something else.its normal..2240 and 2241 are both 600w continuos.
http://www.jblpro.com/pub/obsolete/2240.pdf - http://www.jblpro.com/pub/obsolete/2240.pdf
Posted By: _djk_
Date Posted: 14 December 2009 at 1:28am
"the 2241 was built to take over from the 2240 as a direct replacement"
Only in the sense that they were both 18" in diameter.
They are very different speakers otherwise.
If you want to use it in this box, go ahead, it will still make lots of noise.
------------- djk
Posted By: 510
Date Posted: 14 December 2009 at 3:40am
jbl 2240 was rated at 300 watts pink noise and the 2241 600watts pink noise on the jbl spec sheet for the 2241 it says replacement with little or no box retuning need well thats from jbl i guess you know more
Posted By: _djk_
Date Posted: 14 December 2009 at 10:22am
"i guess you know more "
I certainly do!
JBL sells the same software I use.
Get some education and learn how to use the software yourself.
------------- djk
Posted By: 510
Date Posted: 14 December 2009 at 11:50am
i guess you did not understand what i was saying jbl sends a leaflet with the speaker and on it it says replacement with little or no box retuning need thats what i have been saying nothing else, yes the xmas is different and so on, but jbl them self say it is a replacement for the 2240 and it is a more power rated speaker as well not the same power ratings
Posted By: _djk_
Date Posted: 14 December 2009 at 12:29pm
I don't care what they say, it is not a suitable replacement for the 2240 or 2442 in this cabinet.
If you want to believe it, fine.
------------- djk
Posted By: 510
Date Posted: 14 December 2009 at 9:12pm
old cro i am just realizing what you are saying, i cant say that you are not right about the 2241 in the wbin i thought you were saying that the 2241 could not replace the 2240 in the other jbl boxes sorry sah dont blow a head gasket lol
Posted By: giordihc
Date Posted: 14 December 2009 at 10:27pm
510 wrote:
old cro i am just realizing what you are saying, i cant say that you are not right about the 2241 in the wbin i thought you were saying that the 2241 could not replace the 2240 in the other jbl boxes sorry sah dont blow a head gasket lol |
_djk_ wrote:
"2241 doesnt work in wbin" It doesn't work in THIS W-bin, the back volume is way too small. |
Posted By: geez
Date Posted: 28 December 2009 at 9:03am
I recently noticed P.Audio do a P180/2241 driver (and a P180/2242) are these supposed to be JBL equivalents? The P180/2241 has Fs=33Hz, Qts=0.3, Vas=311, which I think is pretty close to djk's recommended pars for a suitable driver
Tom
Posted By: tv00
Date Posted: 08 June 2010 at 11:13pm
If the reflex is blocked i think the rear chamber volume doesn't matter as much? -Since it is now a front loaded horn? I have two "DAS" boxes like that and they sound very good and clean, but my reflex 4518 copies with fane xb / b600 doesn't sound as good.
Of course they wont play as deep; from 60hz, which is fine for kick-bins wich is what i consider using them for:
subs: 4 CV L48 "E" type earthquake kick: 4 "W" bins with vents blocked kick: 8 4512 with phl 15" or beyma g300 or other midle: 4 12" horns high: 6 L&R audio 2" horns.
Wonder how thats going to sound? PLENTY of 100hz ability, but maybe weak in mid and mid/high?
Posted By: tv00
Date Posted: 08 June 2010 at 11:15pm
That's in each side, wich makes 16X18", 16x15", 8x12", 12x2"
Posted By: 18DJ
Date Posted: 20 October 2010 at 8:16pm
how did the jbl wbin sound with that woofer
Posted By: Night Hawk
Date Posted: 27 December 2011 at 12:27am
I'm soon to come into possession of 4 W bins, although their exact spec's I could not say. If it helps they have a single port. Are blue and have been kicking around the bristol scene for quite some time. Reportedly about 17 years old.
They are loaded with 186's and sound nice. For the sake of future advancement of my rig, I was wandering if, on a generic level, two 18" Wbins would sound okay using void v18's as a stop gap before placing the v18's into some hog's I plan to build in the future? I appreciate I might not be able to run them as low, but If I ran them more like low kick's (lower cutoff of say 50?) does anyone know if they would perform okay?
Posted By: The Builder
Date Posted: 27 December 2011 at 10:29am
Had the mis-fortune to work in a club in Ibiza (Summum) for a month where thay had these.
Honky bass, and thats being kind. Above were 2x15 JBL, then a 2" on lense, then bullets.
Old school to say the least, I never got much out of the W bins, seem to remember tuning the 2x15 to go as low as possible when owner was out.
------------- It just is.
Date Posted: 27 December 2011 at 2:12pm
any one with any experience of 18" wbins?
Posted By: Qautermass
Date Posted: 27 December 2011 at 5:46pm
Yes i have uesd them and sound good with 186, work well over scoop as kick but a bit heavy.got 4 of them.for sale unloaded
Posted By: mrspeedy
Date Posted: 27 December 2011 at 6:09pm
I use a pair of 18" wbins on my rig.
Really pokey things! Drop low enough and throw far enough!
Cross them at 111hz and theyre not honky or anything. I love them!
**Edit: Mine aren't ported though, sealed enclosure at the back of the driver...**
Date Posted: 27 December 2011 at 6:30pm
Qautermass wrote:
Yes i have uesd them and sound good with 186, work well over scoop as kick but a bit heavy.got 4 of them.for sale unloaded |
Yeah sweet, got your pm. Nice to know they sound good with 186's as that's what I have two of them loaded as. Are your's the above model or are they different? Mine are 18"wbins, although they only have a single port at the front. Most models I've seen have either 2 or 3. Can anyone shed any light as to what make they might be?
What scoops did you have them over? Hogs?
Was intending to use them as kicks in the long run, although might have to force a couple to be subs for about half a year until funds allow hogs to be made. (Hence wanting to know their capabilities with v18's or pd1850's)
**Edit: Mine aren't ported though, sealed enclosure at the back of the driver...** |
Sick, this is always good to hear about thing's you've bought. What difference does having the port sealed make? Have you been able to compare like for like at all?
------------- http://www.junglesyndicate.com" rel="nofollow">
Date Posted: 27 December 2011 at 6:31pm
Posted By: tv00
Date Posted: 27 December 2011 at 6:38pm
Don't know, you can calculate the ports to be tuned just below the cutoff of the horn or just block them for clean flh, remember lowcut or waste energy & driver life. I suggest lowcuts something like this: 8 pcs a side: 40 hz 4 pcs a side: 45hz 2 pcs a side 50 hz 1 pcs 60 hz
Date Posted: 27 December 2011 at 6:51pm
They are with single port
Date Posted: 27 December 2011 at 10:48pm
Sorry, still learning the ropes a bit here, could you explain what you mean?
Do you mean to make sure that I apply a lower cutoff to the Wbin? What do you mean by flh?
***EDIT***
These are the 18" W bins I've now got, does anyone know what they are? Just copies of the JBL bin?
