Design of Rectangular ports for a BassReflex Box
Forum Name: Advanced Discussion
Forum Description: Advanced discussion area for higher lifeforms
URL: https://forum.speakerplans.com/forum_posts.asp?TID=50507
Printed Date: 16 April 2024 at 9:04am
Topic: Design of Rectangular ports for a BassReflex Box
Posted By: endre_k
Subject: Design of Rectangular ports for a BassReflex Box
Date Posted: 31 March 2011 at 8:09pm
Hi,
i've been looking for some information of how to calculate, and desing a bass reflex speaker. But all books i look, they only talk about diameter, only of cilindrical ports.
But what about if i want to design a speaker with a rectangular port? wich formulas do i have to use?? Or is it a cut & try solution only?
how can i calculate, or estimate if you want to put one, two, four or how many ports you want? Or i can put as many as i want aslong as they verify they formulas???
i found this, can anyone verify this is correct? haven't seen it in any of the 3 books i looked :)
Port Length
The port length required to tune a volume of air to a specific frequency can be calculated by using the following equation:
   Lv = (23562.5*Dv^2*Np/(Fb^2*Vb))-(k*Dv)
where,
    Dv = port diameter (cm)
    Fb = tuning frequency (Hz)
    Vb = net volume (litres)
    Lv = length of each port (cm)
    Np = number of ports
     k = end correction (normally 0.732)
i have this formula from a good book, but for circular ports:
Lv=2340*(dv^2/fb^2*Vab) - 0'73dv
looks like it....but..... still not sure :S :S :S
thanks for your help in advance!!
keep up this cool forum :))Clap
Posted By: Steve_B
Date Posted: 01 April 2011 at 10:07am
If you use a program like winisd the port tab (I think it is called vent in winisd) lets you choose between round and rectangular. Otherwise you need to match the area of the port.
Posted By: audiomik
Date Posted: 01 April 2011 at 10:18am
isn't there something with rectangular ports that as the diagonal increases from it's minimum (square section) then the Q value changes?
Mik
Warning! May contain Nuts
plus springs, washers, screws, etc, etc.
Posted By: bass traffic
Date Posted: 01 April 2011 at 3:05pm
Mik
I'd be interested to hear about the effect of that.
Always think bigger because your dreams might be the only thing holding you back.
Posted By: endre_k
Date Posted: 01 April 2011 at 6:00pm
Mik
hmmm
Any more information please? Or where to find more?? :)
thx
cheerz from Spain!
Posted By: Steve_B
Date Posted: 01 April 2011 at 8:42pm
Mathematical models of loudspeaker designs all make assumptions or are based on some ideal situation. Some parameters like box losses (Ql) can only be determined after construction. Whether free or expensive the software programme or person using it has to estimate (guess) the value. If you read through enough posts here or on other forum you will come across people advising making allowances or tweaks based on past experience. Sometimes the best looking response doesn’t sound the best. If the theory gets you close enough then don’t sweat the details. One advantage of round ports, of the plastic type, is that you can make them a tight fit and longer than you think and then measure and adjust before finally fixing them in position.
Back to your question. All ports or vents have some resistance caused by the air in contact with the port wall. Multiple ports have a bigger surface area than a single port with an equivalent area. The resistance of air flowing over a surface varies depending on the speed so in a port it will vary depending on the audio level as well. The same thing applies to a narrow slot type port as with multiple ports. The more you move from square the bigger the ratio of surface area to volume. The larger surface area increases the resistance and lowers the Q.
Posted By: greeef
Date Posted: 02 April 2011 at 1:04pm
Interesting. Will a lower q port have a lower peak velocity, but output across a wider bandwidth? What is the effect of q in this case?
Posted By: Steve_B
Date Posted: 02 April 2011 at 2:17pm
endre_K, can you keep similar questions to one or two threads at the most. For old codgers like me it gets a bit confusing with all the similar threads that you have started. So the following is in response to your multiple drivers question.
Using more than one drive unit changes the Vas. If the enclosure size is constant then yes fs does change. It is normal to put multiple drive units in a proportionally larger enclosure to keep the response similar to the individual drive units. The isobaric technique uses two drive units in the same cabinet to improve bass performance for a given cabinet size, but that is at the expense of efficiency. I've only seen that technique used a few times for PA work.
If you want to learn the underlying theory you need to read some books on the subject, which will give you a more complete picture of what is going on.
The two standard texts which cover a lot of theory are:
 ‘Acoustics’ by Beranek and ‘Acoustical Engineering’ by Olson.
 ‘Dynamical analogies to engineering problems’ also by Olson is useful if you have any electrical engineering knowledge. (pop quiz question 1: what's the rotational mechanical analogy of two resisters in parallel?)
‘Bullock on boxes’ goes through some of the original alignments.
Google should bring up a lot of information about the Thiele Small papers.
More tuned pipes and horns Martin King’s website has a lot of information.
Re: the question about lowering the Q of the port. This is considered a bad idea because it increases cone excursion. There was a trend in the 1980s of adding straws to ports to improve the laminar flow through the port to reduce noise.  This too had the side effect of adding resistance and therefore reducing the Q. For multiple ports, or slot shaped ports I wouldn’t think that it makes that much difference.
I’ve tended to keep to relatively conventional designs so not looked into the problem at great depth, nor have I come across much theoretical work which discusses it (that’s not to say it doesn’t exist). Most papers on port noise tend to concentrate on flaring the ends of the port.
Posted By: Lee In Montreal
Date Posted: 02 April 2011 at 5:07pm
Hi endre
I don't know if have found your answer yet. Most ports are round simply because it is cheaper and easier to stick a piece of round ABS pipe on your baffle, than cut more wood to make a square ports. But basically as long as the area is respected, square or round doesn't really matter.
The surface of a diameter is 3.1415 / 4 x D^2
Posted By: endre_k
Date Posted: 02 April 2011 at 5:37pm
Steve_B, sorry about it, but i need to finish this school project for  june, and i'm a bit in a hurry, and nobody answered...i got stressed. Sorry again won't happend anymore.  :(
Another question about it,
 But if i'm trying to desing a bass reflex with 2 drivers. How do i start? I start doing the calculation with one driver and the number of ports i want, and once i have it calculated for one.
How do i change the values for two drivers? How do you associate 2 Vas drivers? Or associate 2 Qts,Qms,Qes?etc... Like electronic resistance?!?!:S
Thanks a lot for your help.
Really appreciate it :)
Posted By: endre_k
Date Posted: 02 April 2011 at 5:57pm
just one silly question, if i do something like this, but changing the 10Ohm R for a 4 Ohm R (because the 2 drivers in paralel equal to 4Ohms), and after, calculating the T/S parameters with the two drivers wired in paralel, will i be able to know how the T/S parameters change? and then be able to calculate the box with those values?
Could it be possible? Any considerations to do it? Or i'm just dreaming too much?
Thanks again for allClapClap
Set up diagram
Posted By: endre_k
Date Posted: 02 April 2011 at 7:46pm
i found this if someone is interested, or can verify it is correct :
If
"a" is the number of elements that are connected in series, electrically,
"b" is 1 for normal configuration, 2 for isobaric configuration and
"n" is the total number of elements, the new values are calculated as:
Vas=Vas1*n/b^2
Bl=Bl1*a
Sd=Sd1*n/b
Re=Re1*a^2/n
Le=Le1*a^2/n
So two drivers in series, side by side has a=2, b=1, n=2 and
Vas=2*Vas1
Bl=2*Bl1
Sd=2*Sd1
Re=2*Re1
Le=2*Le1
Posted By: Steve_B
Date Posted: 02 April 2011 at 8:33pm
Quote Steve_B, sorry about it, but i need to finish this school project for  june, and i'm a bit in a hurry, and nobody answered...i got stressed. Sorry again won't happend anymore.  :(
June is ages away. Wink
I tend to follow threads that I have contributed to and was puzzled when I couldn’t see any of my posts in one of the other threads thinking it was this one. As I said I’m not as young and sharp as I once was.
If you wire two drive units in parallel in one cabinet double the volume that you would use for a single drive unit and then tune the port to the same frequency as you would for a single drive unit. In the formula that you posted, the value of Vb doubles and Fb stays the same. The other variables can be what you want. If you alter the diameter (area) of the port, that will affect the length.
Posted By: endre_k
Date Posted: 02 April 2011 at 8:40pm
June is age away.... but i have to work, exams, live, party, etc =)
by the way, the solution that i said in the SET UP DIAGRAM is it correct?
thx again a lot :=)
Posted By: DJ_habyb
Date Posted: 05 April 2011 at 8:24am
If you know how to calculate the cilidrical port you will know how to calculete a triangle or a squer one.If you know the volum of the round port just make a triangle port with the same volume and you will have the same air volume passing tru and the same air speed.
We kill the noise :P http://www.youtube.com/watch?v=triRKoBEcik
Posted By: kevin tyler
Date Posted: 06 April 2011 at 4:45pm
i was told turbosound or was it martin  are shying away from the triangle ports, is this so?
kevSmile
Posted By: subbass
Date Posted: 06 April 2011 at 6:02pm
remember that port lengths change depending on whether the port is flush or freeair - something that WinISD doesnt take into account...
Posted By: Steve_B
Date Posted: 06 April 2011 at 6:15pm
Posted By: subbass
Date Posted: 06 April 2011 at 6:19pm
I stand 'corrected' Tongue
Posted By: Steve_B
Date Posted: 06 April 2011 at 6:23pm
While I am here, and because this is a thread on rectangular ports, if you didn't know, clicking on the shape changes the port to rectangular.
edit - Subbass I hadn't seen your reply when I posted, so this is a general comment not aimed at you. Smile
