CVA chinese amps
Forum Name: Amp Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=60506
Printed Date: 19 April 2024 at 3:26pm Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: CVA chinese amps
Posted By: tweeter box
Subject: CVA chinese amps
Date Posted: 14 December 2011 at 10:08am
any feedback on em?
http://www.cvr-audio.com/products_detail/&productId=e6cde308-19ec-4f41-9278-c3e8bd45c2e3&comp_stats=comp-FrontProducts_list01-1316481021149.html
http://www.cvr-audio.com/products_detail/&productId=c0b28b4e-7d96-4038-8943-e5121233486a&comp_stats=comp-FrontProducts_list01-1316481021149.html
Model |
PS-4130
8Ω Stereo Power |
4×1300W |
4Ω Stereo Power |
4×2200W
8Ω Bridged Monon |
2×4400W |
4Ω Bridged Monon |
2×5000W |
Frequency response |
20Hz-25kHz ±0.5dB |
THD+N(Rated Power,4Ω/KHz)% |
0.1%
Signal Noise Ration(dB) |
110dB |
Input Sensitivity |
20K Ohm Balanced/10K Ohm Unbalanced |
Output Connectors |
Speakon Connectors(NEUTRIK) |
Power Requirement |
200-240V/50-60Hz |
Input Sensitivity |
1V/1.5V |
Airframe Dimension |
483×377×88mm |
Package dimensions |
575×565×145mm |
Net Weight |
14.5kg |
Gross weight |
16.5kg |
Model |
PS-4130
8Ω Stereo Power |
4×1300W |
4Ω Stereo Power |
4×2200W
8Ω Bridged Monon |
2×4400W |
4Ω Bridged Monon |
2×5000W |
20Hz-25kHz ±0.5dB |
0.1%
110dB |
Input Sensitivity |
Output Connectors |
Power Requirement |
200-240V/50-60Hz |
Input Sensitivity |
1V/1.5V |
483×377×88mm |
575×565×145mm |
Net Weight |
14.5kg |
Gross weight |
16.5kg |
------------- PRECISION SOUND SYSTEM.
Posted By: king david
Date Posted: 16 December 2011 at 12:55pm
heard them a few times running scoops. i'd say they were powerful enough, i really didnt like the sound and cone control, maybe its not amp faul, but bad mixer and setup...
------------- http://www.warriorcharge.noblogs.org
Date Posted: 16 December 2011 at 2:17pm
what scoops/drivers were they running?
Date Posted: 16 December 2011 at 2:18pm
ive heard theyre very powerful amps, but havent had any feedback on sound quality, reliablilty yet, alot of bang for ya buck though
Posted By: idzard
Date Posted: 16 December 2011 at 2:57pm
I contacted the people of CVR and i've seen some videos. To be honest i think i will buy on next year, but shipping is very expensive. I got an pricelist from them and the are not very expensive. (Sorry for my english)
Posted By: THECANDLEMAN
Date Posted: 16 December 2011 at 3:00pm
rough pricing?
------------- Motion Systems - Void Airmotion, Airten & Stasys 218 With Powersoft DSP
Date Posted: 16 December 2011 at 3:24pm
i've seen them in action powering superscoopers loaded with b&c neo drivers, they were moving some air, but as i've said i didnt like the sound, maybe it was how the system was engineered as i didnt like it as a whole not just the sub. dont know about their price or reliability, i guess you get what you pay, but they had enough power for the job
Date Posted: 16 December 2011 at 3:27pm
i was told the biggest amp they do is "approx" £500 with shipping about £150 no idea how accurate that is though
Date Posted: 16 December 2011 at 3:31pm
that is very cheap compared to amplifiers with similar power, few gigs and you pay for it, there is some people selling them around here alongside other lab gruppen chinese copies...is there any warranty?
Date Posted: 16 December 2011 at 3:32pm
king david wrote:
that is very cheap compared to amplifiers with similar power, few gigs and you pay for it, there is some people selling them around here alongside other lab gruppen chinese copies...is there any warranty? |
what kinda prices did u get from them?
Date Posted: 16 December 2011 at 3:45pm
what kinda prices did u get from them? [/QUOTE]
i dont know...but here are some lab copies... http://www.mercatinomusicale.com/mm/negozi/s_home-studio-recording-finali-di-potenza_vt238-rp7-ct81.html" rel="nofollow - http://www.mercatinomusicale.com/mm/negozi/s_home-studio-recording-finali-di-potenza_vt238-rp7-ct81.html since you uk scoop lovers spend a lot of money for birch ply and pd/turbomax driver, i would still go for the usual suspects void/ffa/powersoft/crown etc
Posted By: davidk
Date Posted: 11 February 2012 at 2:19am
sounds the same as the d power amp, same power, think its dpower 413, sounded amazing running some Ohm br218, i have never heard them sound as good as that amp madetem sound!! it wasnt my amp, but have heard that since then it has done 5 x 6 hour gigs no problem ,stayed cool and no issues, im tempted to import a few myself!
Posted By: Stray-Sounds
Date Posted: 11 February 2012 at 4:42am
I've got an older model PA-1500, Use it to drive 8 x 12'' 16 ohm drivers. It seems to do the job OK but not really tried anything similar.
Mate has about 14 amps from the PA series and to be fair they sound bloody good considering the price! Sound fine for subs and tops, pretty lightweight.
Failure rate has been quite high but this was not always the fault of the amp.
I think 3 have given up with no warning or obvious reason.. others were being used in an extremely corrosive environment..
Posted By: levyte357
Date Posted: 11 February 2012 at 11:51am
Guv, save few more $ and get a PL9 or Inf8Mk2.
You know they can do the job, and you also know some lightweights (even expensive name brand models) will thermal trying to drive 2x Turbomaxes a side, playing Roots/dub.
------------- "Who am I? I'm the guy who does his job.. You must be the other guy".
Posted By: Centauri
Date Posted: 11 February 2012 at 3:07pm
Seem to be the Lab Gruppen copies that are plentiful from quite a lot of Chinese sources - I would say they are all made in the one place and distributed to various Chinese outlets which then claim to be the manufacturer....
I have seen a few of these - they sound quite good for anything, although I have seen a few early failures. they seem to have done a fairly reasonable job of copying the Lab design, and even seem to be using genuine On Semi output devices (at least the engineers at On cannot tell they are obvious copies from the detailed photos i sent them), although many other components are obviously lower spec than the genuine labs - so long term reliability may be an issue.
As with most stuff sourced from China, you won't get a warranty - local distributors of these type of things would figure the costs of potential replacements into their markup.
Posted By: davidk
Date Posted: 12 February 2012 at 9:55pm
Changed my mind on this, although they sound good, reliability and back up from supplier could be big issues.
Im going to spend more and buy british!
Date Posted: 13 February 2012 at 12:16am
davidk wrote:
Im going to spend more and buy british! |
Doesn't guarantee anything to be honest.
Tonight heard a Chinese torroidial amp drive same 4x cabs & drivers I've heard a British lightweight amp drive, and guess what, the British amp never ever sounded as heavy and as loud as the Chinese torroidoial.
Wont mention transformer amp is only rated approx 60% of the power of the British amp.
So investigate your possibilities before spending.
