AST Scoops
Category: Plans
Forum Name: Scoops
Forum Description: One scoop or two ;-)
URL: https://forum.speakerplans.com/forum_posts.asp?TID=63995
Printed Date: 19 April 2024 at 7:22pm Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: AST Scoops
Posted By: RealitySound
Subject: AST Scoops
Date Posted: 27 February 2012 at 1:52am
A company in New York called AST used to make these scoops.(they closed down about 10 years ago) There is probably 40 -50 of them here getting eaten by termites in peoples basements and garages. Only a couple sounds here still play with them. Mind you they were all brought in in the early to late 90's when every sound had there own box, and played out with it. There are probably only 6 sounds left who actually use there own box. Just got 12 of them. They are basically 2 feet wide and deep, and 4 foot high. 8 of them had been cut down and are now 22inches wide. I was told when you order them you can get them loaded with EV, Celestion, Gauss, or Fane. The ones I have are loaded with Celestions.
Here are some pics. they were in pretty ruff shape. The pic below is when I picked up the first 8.
All these cabs had ZERO bracing, and ZERO corners/reflectors throughout the scoop. I added double bracing to all 12 and crossbraced the mouth.
8 (22 inch wide) after bracing
last 4...
bracing
feet
last 4 after bracing
RTA RESULTS- 1ST is the celestion, 2nd is a B&C TBXsomething or other and 3rd is a Peavey Low Max. Those are the only drivers I had kicking around the workshop. RTA mic was about 10 feet away laying on the ground.(outside) RTA resolution is 2db (per light)
CELESTION-
B&C-
Peavey Low max-
All 4, (3 celestion & 1 B&C.)
Did my best to reverse engineer it. Don't think anyone would mind being as none have been made in ten years. They are loud, but do not drop too low (as you can see) If anyone has any suggestions on a driver that might sound a little better- I'm all ears. You can see from the dimensions that it seems they were trying to get a whole scoop outta one sheet of ply. I have not had an opportunity yet to test the scoops that were cut down from 24" to 22" wide, but I will at some point.
Here's my measurements. If some are missing its because I can get the tape measure to it. You'd have to work em out. They are carpeted too, so I'm not sure which piece starts and ends where etc.
They are 24 inches wide and deep, and 47 3/4" high. Made from 3/4" MDF (looks like)
Bless.
------------- When you gonna send me some $$ mate ?
Date Posted: 27 February 2012 at 1:58am
The second baffle is 17 1/4 " long. (the piece behind the first 16 7/8 one)
Posted By: hmaudio
Date Posted: 27 February 2012 at 9:35am
looking good man like the bracing but they do look alot like jbl 4530
------------- Nottingham based cab builder. https://www.facebook.com/HMAudio-154352667920145/?ref=bookmarks This account is used by 2 people.
Posted By: levyte357
Date Posted: 27 February 2012 at 12:14pm
To be honest, I wouldn't say the rev eng plan of the AST plan is looking good, looks a disaster on paper hence poor response.
@Reality sound:
Doubt it's possible to make those cabs sound like real scoops, given existing build.
If you decide to sell them, and build something else, can PM you some mods to another plan that is known to work.
Also:Suggestionto make life easier, work in millimeters.
------------- "Who am I? I'm the guy who does his job.. You must be the other guy".
Date Posted: 27 February 2012 at 12:38pm
@ HM-I thought they looked like jbl copies too. @ Lev- Didn't really pay much for these scoops, not trying to start a sound with these cabs or anything. I have 8 servo BT7's,& 16 doubles BR cabs for my low end. I'm giving 4 away and will probably use 8 for center fill for dancehall jiggy jiggy parties. I'm afraid tape measures over here have inches, I have to convert everything on this site from mm to inches, now the tables have turned! I just thought I would share what info I have gathered on these cabs for the speakerplans massive dem. In no way am I suggesting that anyone build these things, and I don't intend on spending any time modding these things to get them to sound any better. These kids coming out nowadays are only interesed in SPL anyway. Bless.
Posted By: JR.junior
Date Posted: 27 February 2012 at 1:05pm
Off topic. I've put insted of polyester stuff, the 3cm foam pyramids in the chamber and the deep bass is gone. So.. this white polyester stuff work the best.
Edit: Just to mentioned.
------------- Support the scoop technology, larger mouth plays louder!
Date Posted: 27 February 2012 at 1:13pm
Cool, had horrible feeling you were embarking on journey with pencil behind your ear, and ordering pallets of timber.
Date Posted: 27 February 2012 at 4:40pm
@ Lev- LMFAO! thanks, i really needed a good laugh.
Posted By: UpComingSound
Date Posted: 27 February 2012 at 6:33pm
AST in nyc those was the days lol use to luv dat place, they still in business they are in queens ny now
Date Posted: 27 February 2012 at 7:57pm
I thought they closed down completely. They had a big going out of business sale like ten years ago. Selling everything CHEAP.
Posted By: Ras Loud
Date Posted: 27 February 2012 at 8:14pm
Does the JBL scoop actually only have that one brace with the number 8 or are there more?
About tape measures: there are some beautiful ones that have inch as well as cm/mm on there at the same time.
Date Posted: 27 February 2012 at 8:57pm
We use inches here. I grabbed the closest tape measure. If anyone wants to convert the measurements to mm, they can use one of those beautiful tapes and figure it out. No one on here posts plans in inches to make my life any easier!
Date Posted: 27 February 2012 at 9:13pm
Ras Loud wrote:
Does the JBL scoop actually only have that one brace with the number 8? |
jp.
