If you follow the link to minaximal’s thread on horn
construction, it gives a good idea of how to go about constructing a round
horn. A couple of things that I have found are that mdf makes a better plug and
don’t use hub pullers to release the horn from the mould.
Due to how ply is constructed, when you turn it on the
lathe, you are cutting along the grain, then across the grain, then along the
grain…… If you are not careful you can get little ridges forming as you turn
the plug. Mdf is more consistent. I always glue and screw the layers together
and coat the wood with resin once shaped. I then finish off with increasingly
finer grades of wet and dry up to 1200 grit. Finally I use T-cut before
polishing with a release wax. Once I have made the initial horn from the turned
plug, I make a second mould from that and put the wooden plug away.
Using hub pullers concentrates all the pressure on two or
three small points on the flange which can cause cracking. One way round this
is to make an extremely thick flange. I use a frame that supports practically
the whole area of the flange and then use a steel bar fractionally smaller than
the throat and tap out the mould with a hammer. I use both wax and release
agent, and rarely have problems with sticking moulds. If you go with this method,
ensure that you polish all traces of wax off the mould before applying the PVA
release agent. If you have problems with the release agent not flowing, you can
reduce the surface tension by adding a few drops of washing up liquid; this
stops it beading. There were some useful videos by hornmaster showing how the horns were made once the mould had been finished. Before you get to all of the above you need to design your horn.
Call me cynical, but I would suggest that the throat angles
of compression drivers have more to do with the distance from the
diaphragm/phase plug exit and the throat exit, which has to be one of the
standard sizes. The actual diaphragm size also comes into this too.
One of the advantages of designing your own stuff is that
you get to decide which areas of the design can be compromised and which cannot.
There is a lot of information about the different aspects of design out there
on the internet so I won’t go into any great detail at the moment.
Exponential and tractrix horns give increasing directivity
with increasing frequency. This compensates somewhat for the fall off in power
response to maintain a level on axis frequency response. Conic horns (this
includes the OS and similar horns) have a more constant coverage but require
more compensation eq to give a flat frequency response.
Abrupt changes in the flare profile (line array slots and
traditional CD horns) will introduce ripples in the response, but may enable
better pattern control. The size of the horn will determine how low a frequency
the horn will maintain good pattern control. Depending on what you are using in
the frequency band below the horn, it is sometimes better to lose some control
so that the polar response of the two frequency ranges match at the crossover
point. For one off projects where the horn is designed for just the one box, look at the system as a whole and try and maintain an even power response through the crossover region. If possible, build and measure the mid section below the horn to give you a good idea of how low the horn needs to go and how to match up the dispersion patterns. As you are designing the horn. you have more flexibility that way rather than designing the horn and trying to match that with a suitable cone mid driver.
