MY PROJECTS :-)
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=91364
Printed Date: 19 April 2024 at 9:57am Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: MY PROJECTS :-)
Posted By: kr1sounds
Subject: MY PROJECTS :-)
Date Posted: 30 March 2015 at 7:53pm
Enclosure: 18mm Horn & Baffles: 12mm
------------- I MAN SERVE SELASSIE CONTINUALLY... NO MATTER WHAT THE WEAK HEART SAY
fostonshfs.webs.com
Posted By: dlyxover
Date Posted: 31 March 2015 at 1:57pm
looks interesting.
Reminds me of the logic systems 1090 10" horn and i do like this boxes.
Would be interested in the results.
------------- In the Truth there is no news, and in the News there is no truth
Date Posted: 31 March 2015 at 2:40pm
it would be nice if someone built this then done some graphs
fostonshfs.webs.com
Posted By: Timebomb
Date Posted: 31 March 2015 at 3:39pm
Quite low compression are you looking to add corner triangles and a phase plug to it?
------------- James Secker facebook.com/soundgearuk James@soundgear.co.uk www.soundgear.co.uk
Date Posted: 31 March 2015 at 3:48pm
is that a recommendation?
dont know much about phase plugs though
fostonshfs.webs.com
Posted By: dlyxover
Date Posted: 31 March 2015 at 3:49pm
what driver did you have in mind for this Kr1?
edit- have you done any sims?
Date Posted: 31 March 2015 at 3:56pm
driver: eminence kappa pro 10 sims: no as it was a plan someone (who makes a lot of speakers) did for me - i trust he knows what he was doing as he did it with no sims and based it on previous 10" horns he's made. i wouldnt know how to input this into hornresp or whatever so i cant help there either
fostonshfs.webs.com
Date Posted: 31 March 2015 at 4:22pm
40mm from each corner
fostonshfs.webs.com
Posted By: T-Bone
Date Posted: 31 March 2015 at 4:24pm
I got a couple of Faital Pro 10PR300, maybe I'll try this!
------------- BASS, how low can you go!
Date Posted: 31 March 2015 at 4:40pm
fostonshfs.webs.com
Date Posted: 31 March 2015 at 8:43pm
15" Folded Horn (plans available on request as i haven't measured them up in sketchup yet)
fostonshfs.webs.com
Posted By: T-Bone
Date Posted: 02 April 2015 at 12:29am
Which driver go in the 15" folded? Is this basically a kick bin from 90-250? Any 15" Faital recommendation?
Date Posted: 02 April 2015 at 12:06pm
i can go lower than 90. should go to around 70. do you want plans?
fostonshfs.webs.com
Posted By: bitSmasher
Date Posted: 02 April 2015 at 2:51pm
How big for a 70hz horn with that fold?
Date Posted: 02 April 2015 at 3:31pm
outer dimensions are 520x680x1000. a friend of mine has just built this and says it can go to 70 but i havent heard it yet and i wanna get this and another cab i designed done in hornresp if anyone can help me there?
fostonshfs.webs.com
Date Posted: 02 April 2015 at 9:25pm
what do they do? what changes do they make to the horn?
fostonshfs.webs.com
Posted By: T-Bone
Date Posted: 02 April 2015 at 10:07pm
I think it prevents the eddy's around the throat that can create distortion. Anyone can sim this with the Faital 10 PR 300 I will build this if someone is willing then I will test it with a mike. Thanks!
Date Posted: 02 April 2015 at 10:16pm
forget the sims you might aswell build it and the folded horn
fostonshfs.webs.com
Posted By: Thomas Hosker
Date Posted: 02 April 2015 at 10:50pm
Send me over the sketchup and ill sim it for you if you want :)
------------- WWW.T8Audio.Com
Posted By: T-Bone
Date Posted: 02 April 2015 at 10:54pm
Thomas knows send it to him kr1? Also the 15" need a back brace me thinks? Thanks! I am getting Faital Pro 15 HP 1020 in a month.
Date Posted: 02 April 2015 at 11:22pm
can you do the 10" too? with the corner triangles
fostonshfs.webs.com
Posted By: nickyburnell
Date Posted: 02 April 2015 at 11:41pm
KR1, in the interests of manners, thank you for all these very interesting projects
------------- It's everything, not everythink!
Date Posted: 02 April 2015 at 11:50pm
No problem - i just want to meet peoples needs
heres 2 of the 10" horns and a dual 8" horn for the oberton 8m250
fostonshfs.webs.com
Date Posted: 03 April 2015 at 12:33am
Thats the plans for the 15" folded horn. If you make any mods let me know i'm interested. theres also a mini version which is shortened to 900mm in height to match mini scoops
kr1
fostonshfs.webs.com
Date Posted: 03 April 2015 at 12:34am
man i do need to get autocad
fostonshfs.webs.com
Date Posted: 03 April 2015 at 12:40am
i can hear the cries "not another one" but this is priority for me
fostonshfs.webs.com
Date Posted: 04 April 2015 at 12:26am
A new system i'm hoping to have ready designed by the end of May
fostonshfs.webs.com
Posted By: T-Bone
Date Posted: 09 April 2015 at 11:38pm
Any thoughts on me using a pair of kr1 10" horn using new in the box PD 102 ER which I had for 10 years now I can build a nice phase plug and use this to 400-1700Hz ? Thanks!
Date Posted: 17 April 2015 at 6:29pm
go ahead
fostonshfs.webs.com
Posted By: JTH
Date Posted: 29 April 2015 at 12:17am
kr1sounds wrote:
it would be nice if someone built this then done some graphs |
I've been thinking along the lines of something like this for a while, a kind of 10" version of the MT121 and have finished building a rough prototype tonight.
Compact horn loaded cab with a 10" mid driver with 2" compression driver. I was hoping to post some pictures but the upoloader link doesn't seem to be working.
Anyway, we'll have a listen tomorrow and if it sounds promising, get some measurements done later this week!
Posted By: T-Bone
Date Posted: 29 April 2015 at 12:48am
JTH what woofer are you using? I plan to put in my Faital 10PR300's, I have two to test brand new. Also the BMS 2" coaxials would sound nice.
Posted By: JTH
Date Posted: 29 April 2015 at 12:59am
T-Bone,
We have a couple of drivers to try. The Kappa 10 Pro and Precision Devices PD.10MH25 although I like the look of the Faital 10PR300 you have there and might order one tomorrow.
As for the 2", I have a couple of P-Audio PreNeo 750Ns here with a P-Audio PH2723 Horn, but am looking for best mix and match really. I have no experience with the BMS comps, so any suggestions are welcome!
Tim
------------- JTH Concerts & Live Events - Stage Hire, PA Hire
Posted By: JTH
Date Posted: 29 April 2015 at 4:56pm
Here we are then, rough prototype of our 10 + 2 hornloaded cab. Hope to get measurements later this week :-)
Posted By: T-Bone
Date Posted: 29 April 2015 at 6:20pm
Nice work JTH, I am still drawing this full size a only have a few hours per day to work on this since I work 12 hour days and only an hour or two when I get a chance. Are you planning on putting a phase plug? Waiting on the results JTH, thanks!
Posted By: dlyxover
Date Posted: 29 April 2015 at 7:01pm
JTH I do like the look of you cab.
A BMS 4590 would work well, on a big horn could drop it too 850Hz or so
http://www.bmsspeakers.com/index.php?id=bms_4590" rel="nofollow - http://www.bmsspeakers.com/index.php?id=bms_4590
Date Posted: 30 April 2015 at 6:15pm
did you use my design or your own?
fostonshfs.webs.com
Date Posted: 30 April 2015 at 6:54pm
Your rough prototypes are better than my best!
Posted By: JTH
Date Posted: 30 April 2015 at 10:29pm
That's very kind of you! It helps having mostly the right tools and a bit of patience!
Posted By: JTH
Date Posted: 30 April 2015 at 10:31pm
T-Bone wrote:
Nice work JTH, I am still drawing this full size a only have a few hours per day to work on this since I work 12 hour days and only an hour or two when I get a chance. Are you planning on putting a phase plug? Waiting on the results JTH, thanks! |
Hello T-Bone. Thanks for that. I'm not sure aboutthe phase plug, nice idea but not sure how to implement that very easily. Lets look at some plots first
Posted By: JTH
Date Posted: 30 April 2015 at 10:37pm
kr1sounds wrote:
did you use my design or your own? |
A mixture really, your sketches certainly inspired me in my quest, so thank you for that ! The other factor was to build something similar to my current MT121s, which have been gigging every weekend for almost 4 years!
The big problem with MT121s I find is the weight, they are hugely heavy and I just wanted something with similar efficiency but smaller and lighter.
Date Posted: 01 May 2015 at 6:43pm
if anyone is good with hornresp pm me please
fostonshfs.webs.com
Posted By: Tweeter_Box
Date Posted: 01 May 2015 at 10:48pm
------------- https://www.facebook.com/PurpleAudioRecords
Date Posted: 01 May 2015 at 11:19pm
cheers
fostonshfs.webs.com
Date Posted: 02 May 2015 at 1:54pm
Work in progress...
fostonshfs.webs.com
Date Posted: 02 May 2015 at 9:40pm
2x12 (RCF L12750) & CD, tweeters or whatever
fostonshfs.webs.com
Posted By: T-Bone
Date Posted: 03 May 2015 at 1:52am
kr1 I bet thats loud is it Trap box? Nice but how low can you Go? LOL
Posted By: KidCreole
Date Posted: 03 May 2015 at 2:21am
S2 on that mid horn needs to be a bigger area
------------- Mykey Wattco
Date Posted: 03 May 2015 at 3:46am
kr1sounds wrote:
forget the sims you might aswell build it and the folded horn |
kr1sounds wrote:
...hornresp if anyone can help me there? |
kr1sounds wrote:
if anyone is good with hornresp pm me please |
You're pumping out a bunch of "designs", are you basing them on theory or ... ? Just wondering, because they are nice drawings but until someone (ie, you) builds and tests them, or at least sims them, they're just nice drawings
Date Posted: 03 May 2015 at 1:40pm
A few were done using hornresp which i had help with but no longer have as i'm no longer in contact with that person hence the reason why i ask on here for help. a few were based on theories that i read up on. only 1 cab (the 15" folded horn) has been built which i still need to go and listen to as well as measure.
fostonshfs.webs.com
Posted By: snowflake
Date Posted: 03 May 2015 at 2:41pm
hornresp is a lot easier to use than most CAD programs
Date Posted: 03 May 2015 at 3:20pm
im not very good at it. i need a good sit down with someone for me to understand that
fostonshfs.webs.com
Posted By: JTH
Date Posted: 28 May 2015 at 11:57pm
So here's two of the four prototypes we produced. We've changed the comp driver from a 2" to a sweeter sounding 1.4" and gone for a nicer looking horn flare.
We had two out at a small live music festival last weekend and were able to compare directly with our existing MT121s. The difference is astonishing. Apart from being much smaller, about half the weight and a one man lift, the efficiency is much greater.
We'll have four out at a larger live music festival next weekend and can't wait to stretch them a little!
The last picture is the H10 sitting on top of one of our old MT121s, quite a size difference!
Sorry about the poor picture quality and the fact that they got quite scuffed in the back of the van, these are finished in Tuff Cab and I don't think it had long enough to cure properly
Date Posted: 10 June 2015 at 10:45pm
The FHS12S - 12" sub using the bms 12s305
-3db: 41 hz
these have been built and tested, a stack of 2 and a mid/top sound great
fostonshfs.webs.com
Posted By: dlyxover
Date Posted: 10 June 2015 at 11:28pm
got a little 12" similar to that on my hit list next
Date Posted: 10 June 2015 at 11:42pm
same driver?
fostonshfs.webs.com
Posted By: dlyxover
Date Posted: 10 June 2015 at 11:49pm
no I went for the 12s330.
I've got some 3 way boxes with them in and love them.
Posted By: mini-mad
Date Posted: 10 June 2015 at 11:54pm
12N630?
------------- If it sounds like a gorilla is trying to escape, turn it down.
Posted By: dlyxover
Date Posted: 10 June 2015 at 11:57pm
mini-mad wrote:
12N630?
Would also be suitable
Date Posted: 11 June 2015 at 12:09am
dlyxover wrote:
mini-mad wrote:
12N630?
Would also be suitable |
£181.81 from thomann - not bad
fostonshfs.webs.com
Posted By: mini-mad
Date Posted: 11 June 2015 at 12:10am
... already got 1!
Posted By: dlyxover
Date Posted: 11 June 2015 at 12:17am
Little monsters, they are.
Date Posted: 11 June 2015 at 12:32am
indeed
36 hz at that point for a 400x400x450 cab. very promising
fostonshfs.webs.com
Date Posted: 12 June 2015 at 11:10am
The FHS218S- V18 - 1000 -3dB 39 Hz - FANE COLOSSUS 18XB (RECOMMENDED) FLAT TO 37 Hz - OTHER DRIVERS SOON TO COME
fostonshfs.webs.com
Posted By: odc04r
Date Posted: 12 June 2015 at 11:44am
I'd put a little more bracing in myself, especially that back wall which is going to be taking the brunt of the drivers output away from the tuning resonance. Probably a whole new side to side panel with nice big holes in it that formed a couple of T shapes with the back wall behind each driver
Posted By: DMorison
Date Posted: 12 June 2015 at 12:37pm
odc04r wrote:
I'd put a little more bracing in myself, especially that back wall... <snip> |
My first thought as well, David.
Posted By: mini-mad
Date Posted: 12 June 2015 at 12:39pm
I think he's more honing his sketchup skillz.
but +1 on more bracing.
Posted By: mini-mad
Date Posted: 12 June 2015 at 12:40pm
Can you do a double 15xb with a 45 f3?
My winisd ninja skillz suck.
Date Posted: 12 June 2015 at 2:24pm
i do it in bassbox pro but yeah mini i'll get to that now. any specific dimensions etc?
fostonshfs.webs.com
Posted By: mini-mad
Date Posted: 12 June 2015 at 2:26pm
i like the g-sub style.... just got a pair of 15xb's knocking around that could do with a home.
cheers....
fostonshfs.webs.com
Posted By: mini-mad
Date Posted: 12 June 2015 at 2:37pm
kr1sounds wrote:
...sorry, wasnt taking the pi$$... but once i got the hang of it i was knocking out bits all over the shop.
alsa, it was 5-6yrs ago and now i get very little time to do any real work on it. most of my forum chat is done from my fone while on the go.
next week i gotta clear me lockup out... well tidy it up any way. but no reception in a giat metal structure so i cant talk on here. but hey-ho i need the old rig gone so i can have some space back and gotta set up some sort of work station too.
Date Posted: 12 June 2015 at 2:46pm
lol i know don't worry
this is what i got atm
1000x536x600 - too big?
fostonshfs.webs.com
Posted By: mini-mad
Date Posted: 12 June 2015 at 2:49pm
how far would something like 1000x500x500 get me?... i may have to take your number/email and see if we cant have a chat about bassbox..
Date Posted: 12 June 2015 at 2:57pm
red: 1000x536x600 orange: 1000x500x500
-3dB is about 47 hz
fostonshfs.webs.com
Posted By: mini-mad
Date Posted: 12 June 2015 at 3:02pm
i cant live with 47hz...
could you shoot me the suggested plan please and i'll whack it together to keep my fanes from sitting all sad and lonely on a shelf.
i'll even see how my kappa LFs fair in it too! lol
thanks again! i can stick this over the top of my cubos to get my kick back!
Date Posted: 12 June 2015 at 3:03pm
do you want the 1000x536x600 plan then?
fostonshfs.webs.com
Posted By: mini-mad
Date Posted: 12 June 2015 at 3:05pm
if they are both up on the screen i'll take both but will end up building the 500x500.
cheers once again! lol
Date Posted: 12 June 2015 at 3:11pm
pm or chuck 'em in here?
fostonshfs.webs.com
Posted By: mini-mad
Date Posted: 12 June 2015 at 3:16pm
up to you... if you dont mind people using them and build them.
its been a while since someone chucked up a useful free plan for other to try.
Date Posted: 12 June 2015 at 3:23pm
fostonshfs.webs.com
Posted By: mini-mad
Date Posted: 12 June 2015 at 3:29pm
perfect!
did you account for any bracing in the design?
Date Posted: 12 June 2015 at 3:38pm
for the 1000x500x500 there was one 60x964 and two 60x464. same for the 100x536x600 but the two 60x464 changes to 60x500. not much change in frequency or anything. if you want to add anymore let me know and i'll add it in and see but it shouldn't make too much of a difference depending on size
fostonshfs.webs.com
Date Posted: 12 June 2015 at 3:45pm
just a quick thought - if i wanted to make it trapezoidal, would making the volume, vent area & length the same as a cuboid version result in them being the same?
fostonshfs.webs.com
Posted By: mini-mad
ok cool....i will prob stick a touch more in and stick a bunch of holes in the braces like a bunch of 40mm holes or the like. any weight saving/extra bracing is always a bonus!.
cheers for the ups! i'll tidy up my lock up and let you know how the 500x500 sounds!
Posted By: mini-mad
Date Posted: 12 June 2015 at 3:47pm
kr1sounds wrote:
just a quick thought - if i wanted to make it trapezoidal, would making the volume, vent area & length the same as a cuboid version result in them being the same? |
i think it would make a difference as it will be narrower at one end and tapper outwards... im sure theres a guru on here to point out how it makes a difference and how to overcome it.... hopefully.
Date Posted: 12 June 2015 at 3:48pm
no problem. here to help with anyone
anyone else have any spare drivers just hanging?
fostonshfs.webs.com
Date Posted: 12 June 2015 at 3:49pm
yes, a guru is needed. always wanted to design trapezoidal boxes
fostonshfs.webs.com
Posted By: mini-mad
Date Posted: 12 June 2015 at 4:09pm
kr1sounds wrote:
for the 1000x500x500 there was one 60x964 and two 60x464. same for the 100x536x600 but the two 60x464 changes to 60x500. not much change in frequency or anything. if you want to add anymore let me know and i'll add it in and see but it shouldn't make too much of a difference depending on size |
i think wen doing these type of boxes aim for 100mm width bracing minimum. 60mm isnt bad but with big bass you want big bracing and 100mm is a good start point. been looking over shed loads of other cabs and it seems to be the norm to "go big".
then a little extra off the internal volume for handles too.
and to add roughly a 30-40mm extra to the depth of the cab from the edge to the start of the baffle to account for either a grill or speaker clothe of some type....
ya know for wen your modeling in 3D....
Date Posted: 12 June 2015 at 5:48pm
yeah i done that in my 2x18 in the previous page or so. i done 20mm so that 18mm wood then a 1.5mm grill can go over the whole thing so it kind of looks flush
fostonshfs.webs.com
Posted By: mini-mad
Date Posted: 12 June 2015 at 5:59pm
i ment more like this....so you have the ability to have a full face grill not just a speaker grill.
im not picking holes, just a few suggestions for future designs.
Posted By: mini-mad
Date Posted: 12 June 2015 at 6:01pm
my bad... yes, iv seen yours now lol
Date Posted: 12 June 2015 at 6:04pm
hmm... will take that into consideration. thanks mini!
might design a 12/15/18 sub range like that for here as well as a 2x8/10/12 midtop especially for the forum. now i need to go searching for drivers
btw where a good place to get port tube, bluearan has a few but not a lot
fostonshfs.webs.com
Posted By: mini-mad
Date Posted: 12 June 2015 at 6:08pm
try car audio stores.... they give DIY bassers a lot more to play with.
also, PVC piping your can buy in b&q/wilkes is a good bass tube. i used 4" waste pipe (it has a thick wall) in my Q12 and it worked perfectly!
Date Posted: 13 June 2015 at 11:27am
any good online car audio stores? there isn't one in my area i dont think
fostonshfs.webs.com
Posted By: odc04r
Date Posted: 13 June 2015 at 11:59am
When I used them back in t'day maplin used to have a range. +1 on the pipe though, really easy to trim down on a chop saw until you get the tuning you want.
Date Posted: 21 June 2015 at 5:06pm
FHS28M
fostonshfs.webs.com
Posted By: DMorison
Date Posted: 22 June 2015 at 12:19pm
kr1sounds wrote:
FHS28M |
Looks good. Fane Sovereign Pro loaded?
Date Posted: 22 June 2015 at 4:24pm
Yes the sovereign pro 8 225
fostonshfs.webs.com
Date Posted: 26 June 2015 at 10:43am
Working on this at the moment for a friend. A sub using the BMS 12S305. Atm -3db is 44hz which isnt bad so far
fostonshfs.webs.com
Posted By: Timebomb
Date Posted: 26 June 2015 at 11:00am
Be careful running the ports so close to the back panel, it will add a bit of length, just in case you were not aware.
