multiple power amps to crossover
Forum Name: Newbie Discussion
Forum Description: Newbie Discussion/Questions. Look less stupid here...
URL: https://forum.speakerplans.com/forum_posts.asp?TID=96969
Printed Date: 19 April 2024 at 8:46am Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: multiple power amps to crossover
Posted By: vnaparam
Subject: multiple power amps to crossover
Date Posted: 28 October 2016 at 10:02am
hi gud day all, what could be done if i have say 4 power amps for subs and 2 power amps fot my mid-his. Now, i have only 1 crossover2/3 way one at the back i see ch1 Low/mid/hi and same with Ch2..how would i connect the cables from my amps to my crossover? do i have to buy another crossover since there are already 8 speakon cables for my subs and 4 cables for my mid-hi? i need some reply guys. tnx
Posted By: mini-mad
Date Posted: 28 October 2016 at 12:28pm
list your equipment.... this will help greatly.
------------- If it sounds like a gorilla is trying to escape, turn it down.
Posted By: vnaparam
Date Posted: 28 October 2016 at 12:55pm
Equipts namely 4x mc12000 for subs, 2x mc 4000 for mid hi, 1x crossover 2/3 way, 1x eQ, 1x 8ch mixer
Posted By: Conanski
Date Posted: 28 October 2016 at 4:33pm
First thing you have to do is think in terms of signal flow, you are connecting the crossover to the amps not the other way around. Then it's becomes easy, low crossover output goes to the first amp and then the signal jumps from the first amp to the second, second to third, etc. Then you do the same with the mid amps, and the highs.
Posted By: vnaparam
Date Posted: 28 October 2016 at 5:49pm
ok..what do u mean jump to the nxt amp? how is it being done then? please shed a light for me
Posted By: RUS
Date Posted: 28 October 2016 at 6:44pm
The xlr cables will come out of your crossover and go into the amp inputs then xlr from that amps outputs to the next amps inputs and so on, this will feed each amp linked the exact same signal,
http://s781.photobucket.com/user/audiotech_88/media/Mobile%20Uploads/image_zpsanbzcgty.jpeg.html" rel="nofollow">
Posted By: vnaparam
Date Posted: 28 October 2016 at 6:55pm
ok..that's pretty clear expl...thanks a lot!
