PL-Audio Q3
Forum Name: Amp Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=97940
Printed Date: 28 March 2024 at 7:28pm Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: PL-Audio Q3
Posted By: tillin
Subject: PL-Audio Q3
Date Posted: 28 February 2017 at 10:51pm
hey folks,
planning to build this system 2 x1 with pd 1850 4 hd15 with pd 1550 2 mt121 with pd 123 + bms4590 (combined with bms 2236 horn)
speaker management: xilica xp 4080
now for the amps: sub section: pl-audio q3. site is only in german ( http://pl-audio.de/produkte/endstufen/q-serie/ ) mid top section: ram audio zetta 440
does anyone have experience with the q3 amp by pl-audio and would share it? any general concern about this setup?
thanks tillin
Posted By: bass*en*mass
Date Posted: 01 March 2017 at 7:52am
you wont need a bms 4590 above mt121s, good 1.4" comp+big horn would do.. Q3 amps have been tested independently and not really recommended to drive all CH on bass duty despite the marketing blurb on their website..
Posted By: tillin
Date Posted: 01 March 2017 at 8:39am
thanks bass
what would be a good amp for the bass section? i would like to keep the amp not too heavy in weight. 4ch perferred ...budget up to 2000euros
Date Posted: 01 March 2017 at 9:07am
would go for a dedicated bass amp + tsa4-1300 on kicks and mids + dedicated hf amp (class a/b). plenty options, hard to suggest something, depends a lot on where you are based and whats available, new or SH etc.
Posted By: tillin
Date Posted: 01 March 2017 at 4:50pm
ok folks,
did some research...pardon i m new in the whole thing..
amps: tops: qsc gx3 kick/mid: tsa 4-1300 or ram 6044 low: synq 3k6
for mt121 tops: bms 4554 + bms 2236horn
what do you think?
Posted By: cravings
Date Posted: 01 March 2017 at 4:54pm
that compression driver won't fit that horn. also you probably want a 1.4 that will go a little bit lower than 1khz.. the 12" section of mt121 will play up to about 900hz. the 18 sound xt1464 is a great horn. and people rate the beyma 755 series of compression drivers so maybe look at them?
Posted By: Father-Francis
Date Posted: 01 March 2017 at 5:02pm
tillin wrote:
thanks bass
| If you trying to keep budget @2000euros is that for The AMP ? If so then get one of The powersoft K8 someone is selling here ,
------------- Music is the strongest form of magic.(+45 31879997)blakmanpro@gmail.com, foa@sweetboxaudio.dk
Date Posted: 01 March 2017 at 5:11pm
Or try one of these [URL=http:// http://www.bluearan.co.uk/index.php?id=JMSQ10&browsemode=manufacturer%20%5d" rel="nofollow - http://www.bluearan.co.uk/index.php?id=JMSQ10&browsemode=manufacturer%20] or buy two 2 ch amp . Is the euro stronger than pound ? 2000euro is about 1750£ so in reality you can get 2*4ch , if am not wrong .
Date Posted: 01 March 2017 at 5:19pm
tillin, i wont suggest the 3k6 on bass either.. they will die quickly, specially on subbass..! tsa would be ok on kick and mids, save the money for a proper bass amp ;) matrix xt800 would be my choice on hf, or an old little crest/camco/mc2.
re horns, the large faital and 18s 1.4" work well and more or less match mt121s dispersion, leaving a little xover gap between 12" and 1.4" would be better than running the comp lower imo.
Posted By: tillin
Date Posted: 01 March 2017 at 10:36pm
wow thanks for the input...so let me sum up things a little bit.maybe i didn t get everything
amps: tops: xt800. nice suggestion. class ab and lightweight. i just couldn't find a german shop that sells it.anyway i could order in uk kick/mid: i would like to go with a 4ch amp here to save weight. the JAM Systems Q10 looks good, but i saw it's no longer available on the page. here in the forum i saw this thread about this amp, there were discussions if the pl-audio 10.4 would be the same amp.is it like that? a 10.4 would be easy to purchase in germany sub: powersoft seems a good choice. i saw a k6 on used-stage-equipment.com. would this also do for the sub section or should i go for the k8?
top horn: i was a little guided by looks. i really like the tops of the translate soundsystem. seemed that they used those bms horns. is there a way to integrate them into the mt121? by the way i was planning to put the 121 apart so one m12 + top
Posted By: tillin
Date Posted: 02 March 2017 at 11:42am
more research done of course you were right regarding the hf section 18sound ND 1460 + XT1464 horn
Posted By: corell
Date Posted: 02 March 2017 at 1:35pm
Great combination! I would advise to go for 12NDL76 in the MT121, but the PD is not bad either (just old...) Personally i run SAE PQM8 on mid/tops (would also be good for kicks, as is the TSA 4-1300) and a DAP stage amp 4.0 on sub duty. You cant compare the DAP to a Powersoft K series obviously, but it will give a solid 2000-2500w per channel on Subs all night.
Stay away from cheap 1U 4 channel amps for bass. there is a reason the proper ones cost a few thousand (and even then, they wont give you the stated specs as long time output). Also stay away from QSC GX series. imo they are among the worst on the market. Ram Audio Zetta is fine for tops!
Overall, why not run the rig off two TSA 4-1300? They are cheap and when you do 1 channel sub, 1 kick, 1 mid and 1 high, it will be very fine. Not bad sounding either. If you can afford to, go with K series on sub, sure!
Btw, i have two unused ND1460 for sale and you can buy SAE amps via me. If you are located near berlin, you could come and look/hear yourself ofcourse.
Posted By: tillin
Date Posted: 02 March 2017 at 1:48pm
hey corell, thanks for your suggestions. i thought about the 2x 4-1300 but i got some money to burn for this project, so a used k8 will be possible. so for now Sub: powersoft k8 kick/mid: tsa 4-1300 hf: Matrix xt800 lovely how you guys help to set things straight here. thanks btw pretty close to berlin...greifswald
Posted By: tillin
Date Posted: 02 March 2017 at 1:55pm
oh one more thing...but offtopic does it make sense to use 16ohm 1550 for the hd15 because of pairwise use?
