w audio sb500/sb850. D4-500. XT800
Category: Buying and Selling
Forum Name: Wanted
Forum Description: Out of hen's teeth or need some more rocking horse doo-da? Post it here
URL: https://forum.speakerplans.com/forum_posts.asp?TID=97963
Printed Date: 19 April 2024 at 8:06am Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: w audio sb500/sb850. D4-500. XT800
Posted By: mini-mad
Subject: w audio sb500/sb850. D4-500. XT800
Date Posted: 03 March 2017 at 11:37am
I have larger amps to swap with but I need one of these and/or an Matrix XT800 for a 2.1 system I'm putting together as I like my racks to match (OCD) and the little w audio sb500 I have here hasn't let me down so would like a second or the bigger sb850. also if I can't get one of these Amps I can swap it all out and put a second xt800 in there...
as said I have a few larger amps to swap for them and or money but this is to build up a matching amp rack for a small system so I don't want to silly prices please.
------------- If it sounds like a gorilla is trying to escape, turn it down.
Posted By: bassdesigner
Date Posted: 03 March 2017 at 11:57am
I have a excellent condition w audio horizon 600 1u if that's any use?
Posted By: mini-mad
Date Posted: 03 March 2017 at 2:51pm
I'm trying to keep my amps all the same... I have one sb500 and one xt800... the little sb500 isn't to bad for tops on small gigs but would like to use it bridged for a single bass can and have an sb850 on tops duty.
...or like I use to have a pair of xt800 with a berry crossover set up the same way but with much more headroom (and being better amps of course).
but thanks for the offer none the less!
I have the 400 version of that in my living room on monitor duty for my decks. the fans are annoying at low levels
Posted By: mini-mad
Date Posted: 03 March 2017 at 2:59pm
double post
Posted By: mini-mad
Date Posted: 04 March 2017 at 6:18pm
....unless you have a matching pair...
or anyone has Thomanns 4-d500 going for cheap...
or a cheap 2U 4 channel amp that's bridgeable?
Posted By: mini-mad
Date Posted: 15 March 2017 at 11:16am
Still on the hunt...
