FFA amp power question
Forum Name: General Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=98032
Printed Date: 20 April 2024 at 12:28pm Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: FFA amp power question
Posted By: BigSoundNorthWest
Subject: FFA amp power question
Date Posted: 10 March 2017 at 8:06pm
An FFA 6004 amp is rated 6000w, yet only has a 20a Powercon, so could only get 4800watts? How are u supposed to get its max usage out?
Posted By: cravings
Date Posted: 10 March 2017 at 8:20pm
Read a little on reservoir capacitors (capacitors as reservoirs) for starters. Amps are a big topic though.
Date Posted: 10 March 2017 at 8:59pm
Cheers, I figured there was a way, was just interested as it confused me a bit... its definitely a big topic though.
big up fore the reply
Posted By: Conanski
Date Posted: 10 March 2017 at 11:45pm
BigSoundNorthWest wrote:
An FFA 6004 amp is rated 6000w, yet only has a 20a Powercon, so could only get 4800watts? How are u supposed to get its max usage out? |
AC watts does not equal Audio watts, audio is much more dynamic than the sine wave that comes out of the wall so part of what an amplifier does is store some of that energy to be used to reproduce peaks. And regardless what a spec sheet may suggest those amplifiers will not deliver those rated output figures indefinitely, look further into the specs to see what method was used and what the test signal was, chances are you will find it was a noise signal with a defined crest factor and was time limited.
Posted By: snowflake
Date Posted: 11 March 2017 at 12:51am
spec sheet says it's 1kHz sinewave. probably for 10ms.
Posted By: MPASOUND
Date Posted: 11 March 2017 at 4:23pm
Actually FFA are one of the few that can deliver sustained power and pretty much meet the manufacturers spec. Not sure about the four channels but take a look at the amp meet 3 results for the FFA 10000.
------------- It's just bits of paper flapping about in a box.
Date Posted: 18 March 2017 at 10:16pm
Cheers for all the answers guys, im researching as we speak, I'll get ther.
Nice one!
