LF18G401 vs L18P300-07 for 186
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=98193
Printed Date: 20 April 2024 at 8:12am Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: LF18G401 vs L18P300-07 for 186
Posted By: Futendra
Subject: LF18G401 vs L18P300-07 for 186
Date Posted: 01 April 2017 at 3:56pm
Which one would be the best bang for the buck? Would there be any noticeable difference? We would be making eight 186 horns.
The L18P300-07 is €269, and the LF18G401 is €229
L18P300-07:
General
- Price: €269
- Rated power: 1000 W RMS
- Impedance: 8 Ohm
- Frequency range: 35 Hz - 1000 Hz
Thiele/Small Parameters
Resonance frequency:
33 Hz
DC resistance:
5.0Ω
Mechanical factor:
8.3
Electrical factor:
0.34
Total factor:
0.33
BL Factor:
23.5 T · m
Effective Moving Mass:
180 g
Equivalent Cas air load:
226 liters
Effettive piston area:
0.113 m²
Max. linear excursion (mathematical):
7.8 mm
Voice - coil inductance @ 1kHz:
1.9 mH
Half-space efficiency:
2.30%
LF18G401: General
DC resistance:
4.8Ω
Mechanical factor:
7.6
Electrical factor:
0.30
Total factor:
0.29
BL Factor:
24.6 T · m
182 g
268 liters
0.122 m²
8.5 mm
2.4 mH
3.09%
Posted By: corell
Date Posted: 01 April 2017 at 4:14pm
Its a no brainer. The 18G401 beats the 18P300 by every means imo, being much newer.
Posted By: Futendra
Date Posted: 01 April 2017 at 4:42pm
So the budget option is also better? That sounds like music to my ears!
Posted By: cookie-dj
Date Posted: 01 April 2017 at 6:31pm
The G401 is more suited to horn loading too, the P300 is a wicked reflex driver though.
------------- You can't polish a turd!
Posted By: fourway hornloaded
Date Posted: 08 May 2017 at 4:00pm
L18P300 used to be RCF's top of the range bass driver for a long time until it was superceded by the LF18G/X400. It has got a thick top plate to increase linearity and power handling, and ventilation holes in the back plate to the same purpose. It's still being made and now sold at a competitive price, compared to its successor, which has a higher voice coil winding.
LF18G401 is a budget driver. Some features have purposely been omitted to keep the price down. It lacks extensive ventilation, has a comparatively thin top plate and not much voice coil hight. That said, it's got a modern suspension like its larger siblings and a very high efficiency (because of the short coil).
I think it's hard to choose. It must be funny to spend extra money to obtain a driver that's actually older (LF18P300). The price of the L18G401 ist just unbeatable. On the other hand, guessing that you have certain expectations when building 8 bass horns, I'd consider using a driver with high power handling and especially, a greater voice coil overhang.
