mosfet replacements please help!!!
Forum Name: General Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=98538
Printed Date: 19 April 2024 at 10:11am Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: mosfet replacements please help!!!
Posted By: young simba sounds
Subject: mosfet replacements please help!!!
Date Posted: 15 May 2017 at 8:16pm
doing my head in trying to find these fets i dont think i am but is there an alternative i can use
numbers on fets are as goes sml buz908d
and buz 903d
any help would be much appreciated thanks!!
------------- scoops...yes scoops the only SUB for me
Date Posted: 15 May 2017 at 11:48pm
I take it you have checked RS or Farnell?
------------- Musical Roots Reggae Vibration is Life! for music is sound...sound is vibration...vibration is energy... and energy begets life. Therein lies my passion!...MUSIC IS LIFE...
Posted By: kedwardsleisure
Date Posted: 15 May 2017 at 11:57pm
dont think you'll get any other than ebay as Hitachi who made them are no longer, they merged with mitsubishi to form Renesas, but AFAIK never made them at that time. Magnetek (now TT) made them for a while too. The nearest equivalent would've been an exicon ECF20N/P25 but I dont think they make those any more either. If you find new ones they're likely to be around the £20 mark each. You could buy a scrap Chevin or old Matrix or similar as they usually have this sort of thing in there.
------------- Kevin
North Staffordshire
Posted By: _djk_
Date Posted: 16 May 2017 at 1:20am
What is the ±V on the amp?
If it's higher than ±100V you may be SOL, the only part available now is the 200V
ECF20N20 at GBP15 each
------------- djk
Date Posted: 16 May 2017 at 7:54am
yeah i feared this aswell, i have found one of each for around 18 quid each on ebay thanks for the replies guys!!!
Posted By: VentureSound
Date Posted: 16 May 2017 at 5:53pm
Try cricklewood electronics
Date Posted: 16 May 2017 at 6:00pm
thanks everybody, also would anybody no a close value to the small ceramic capacitor next to the mosfet?
the little orangy brown ones have no numbers or any values on them at all??
Date Posted: 16 May 2017 at 6:16pm
it also took that out on its way
Date Posted: 16 May 2017 at 6:48pm
could you ask the manufacturer maybe?
------------- Kevin
North Staffordshire
Date Posted: 16 May 2017 at 6:55pm
thats where it gets complicated, the amps are complicated (psl) yes i no, i heard the stories they go bang but ive had a fair few and none failed miserably even when pushed beyond there limit, there is no info anywhere, all else is now good i have some tracking to bypass apart from that its just that last ceramic capacitor now
Posted By: APW
Date Posted: 16 May 2017 at 7:30pm
NOS BUZ90x
http://dalbani.co.uk/catalogsearch/result/?q=BUZ908D" rel="nofollow - http://dalbani.co.uk/catalogsearch/result/?q=BUZ908D
£12.99 each inc vat, half the price of Cricklewoods.
Date Posted: 16 May 2017 at 8:03pm
peerfect thanks, gnna order these in!!!
Date Posted: 16 May 2017 at 8:13pm
between the resistor is the two brown little ceramic http://www.ebay.com/sch/Consumer-Electronics-/293/i.html?_nkw=capacitors" rel="nofollow - capacitors thats the last thing, i have one that has gone, any info on what would be the best as there is no indication on them?
Date Posted: 16 May 2017 at 8:15pm
between the resistor is the two brown little ceramic capacitors thats the last thing, i have one that has gone, any info on what would be the best as there is no indication on them? also this is a pic of the board in repair
Posted By: simonp1100
Date Posted: 16 May 2017 at 8:16pm
the little orangy brown ones have no numbers or any values on them at all?? If the capacitor is connected between drain & Gate of each FET then i assume these are being used to minimize the amplifier from oscillating & i would say around 10pf (250v). That PCB board looks like the top MOSFET output module of a PSL amplifier ???. Check Gate voltage protection diodes / Zeners as well. |
Date Posted: 16 May 2017 at 8:18pm
perfect, this is more a project for me so will get them ordered thanks again for quick replys!!!
Posted By: odc04r
Date Posted: 16 May 2017 at 9:55pm
Do yourself a favor and buy one of these little doodads - http://www.ebay.co.uk/itm/New-All-in-1-Component-Tester-Transistor-Diode-Triode-Capacitance-ESR-Meter-0W77-/201493269992?hash=item2ee9ef4de8" rel="nofollow - http://www.ebay.co.uk/itm/New-All-in-1-Component-Tester-Transistor-Diode-Triode-Capacitance-ESR-Meter-0W77-/201493269992?hash=item2ee9ef4de8
I promise you will find it more then useful enough to warrant the price tag for applications of unknown components.
Date Posted: 16 May 2017 at 10:42pm
good sounding amps when working properly.
------------- Kevin
North Staffordshire
Posted By: _djk_
Date Posted: 17 May 2017 at 12:18am
DALBANI !!!
Have had a huge problem with them in the past with counterfeit parts.
Buyer Beware.
------------- djk
Date Posted: 17 May 2017 at 8:16am
odc04r i will do, i just havnet really thought about getting into amp prepair im very very novice, dont no much but do no a couple little basics, been lurking on this forum for years and years learning and takng in points. after further looking at this amp on the secondary board all the fets are unmatched anyway so looks like either somebody has been in there before (could be within 20 years) as they are old now as i doubt they was made that way, this is more of a practice amp for me anyway so if it goes wrong it does
Date Posted: 17 May 2017 at 8:22am
thanks for heads up djk!!!!
Posted By: odc04r
Date Posted: 17 May 2017 at 9:40am
odc04r i will do, i just havnet really thought about getting into amp prepair im very very novice, dont no much but do no a couple little basics, been lurking on this forum for years and years learning and takng in points. after further looking at this amp on the secondary board all the fets are unmatched anyway so looks like either somebody has been in there before (could be within 20 years) as they are old now as i doubt they was made that way, this is more of a practice amp for me anyway so if it goes wrong it does |
That's why I recommended that gadget :) Like a budgie it is very cheap for the help it can provide.
Maybe it would be worth drawing out the schematic and simulating it, then seeing what other FETs might work well in it? I have no idea if they exist but I bet you could get somewhere close and you'd learn an awful lot. Plus simulation is free and quite powerful for the audio frequency range if your device models aren't hopeless.
Date Posted: 17 May 2017 at 9:45am
yeah thanks again, we all have to start learning somewhere, everything i am good at apart from circuits and amplifiers, its the last part of audio im yet to learn so now is time to start i think i have orderd all parts so far ill keep you updated when all come to see if the amp fires properly, (it did fire when i aquired it) but ive only just realised these parts had gone, i heard amps will still run without some fets anyway??
Date Posted: 17 May 2017 at 1:38pm
_djk_ wrote:
DALBANI !!!
Buyer Beware.
+1 Beware Dalbani. Quite well known for selling fake parts.
Date Posted: 17 May 2017 at 1:48pm
between the resistor is the two brown little ceramic capacitors thats the last thing, i have one that has gone, any info on what would be the best as there is no indication on them? also this is a pic of the board in repair |
Out if interest,what amplifier is this from? Those individual heatsinks look like they would be a dust-trap!
------------- Be seeing you.
Date Posted: 17 May 2017 at 1:57pm
out of a please ka2401!!!
Date Posted: 17 May 2017 at 6:44pm
and buz 903d
Sorry i am confused, your asking for the above FET'S yet in the board that you posted a picture of they are BUZ901D & BUZ906D as well as BUZ903D & BUZ908D ????? i am sure these need to be ALL BUZ901D & BUZ906D throughout both channels (the last one i repaired had ALL 906D & 901D).
Posted By: ceharden
Date Posted: 17 May 2017 at 6:47pm
IMO the cost of the replacement FET's will be much more than the value of the amp.
Date Posted: 17 May 2017 at 6:48pm
ceharden wrote:
IMO the cost of the replacement FET's will be much more than the value of the amp. |
Date Posted: 17 May 2017 at 6:49pm
thats what was in there, i got another two of these amps all fets are buz903d and 908d but i was just going to put back in what i took out
Date Posted: 17 May 2017 at 6:50pm
in the long run this amp was a spare anyway just incase i needed parts but i thought id have a shot at it to learn on basically so money is not much of an object but rather more of a learning amp
Date Posted: 17 May 2017 at 7:00pm
I would make sure that you replace all the BUZ906D & BUZ901D with BUZ908D & BUZ903D as the 906D & 901D are rated at 200V devices & the 908D & 903D are rated at 250v devices.
These amplifiers were well known for FET'S exploding hence why they may have changed / up-rated the output FET's due to the high supply rails.
Do not mix the two together (either all 200v devices or all 250v devices).
Date Posted: 17 May 2017 at 7:05pm
thanks simon, this must be an older model to the other two then as this one also has different capacitors also not as well built as my other two, i might just put this one to rest lol
Posted By: _djk_
Date Posted: 17 May 2017 at 10:25pm
"Do not mix the two together (either all 200v devices or all 250v devices)."
Does not matter.
If the ±V is 100V or less the 200V parts will be fine
The difference between the 200V and 250V parts is the 250V parts are obtained on a selection basis.
They start out with the same die .
The ones that test better than 250V become 250V parts.
Then they lower the test spec to 200V, and the ones that pass are sold as 200V parts.
Hitachi did the same with the 2SJ48/49/50 series rated at 120/140/160V.
------------- djk
Date Posted: 18 May 2017 at 5:25am
Does not matter.
Because of the past record with these amplifiers having FET's blowing with the 906D & 901D fitted and with the supply rails being OVER 100v, stick with the higher voltage FET's for longer long term reliability. Repaired quite a few of these in the past and have seen many PCB's damaged beyond repair due to FET's blowing and taking out the board as well.
By the way these amplifiers were made in Bristol (Flowers hill).
Posted By: odc04r
Date Posted: 18 May 2017 at 10:45am
Tbh an amplifier with +100V is not a great idea for a learning project anyway. As the FETs are valuable then you're probably better off stripping it for parts or selling intact as spares second hand, then investing in a more sensible amplifier for learning with.
The P3A on ESP audio is a great starter to build, and as long as you have a half decent dual DC power supply then you won't have to build any mains power supplies to be able to have a listen at low levels. If you simulate the design first you will learn a lot as you build it and test it out, mechanical as well as electronic with regards to construction and biasing. It's a good way to start learning vs jumping right in at the deep end with an unknown quantity.
Date Posted: 18 May 2017 at 10:52am
im going to take your adice on this one anyway (last night during a power up one of my mid range amps blew) so money will be going to an engineer to fix this one instead, so......
i have a small quantity of various buz906 901 and 903 fets if anybody wants lol
Date Posted: 23 May 2017 at 10:57pm
they're great for learning about holes in the tops of transistors, holes in the soft start part of the pcb and holes in your wallet. I once had some new transistors (not lateral fets) from a supplier mentioned in this thread and they were short circuit out of the box. Got a refund however. I've also had fake parts although they were very good fakes...the Crown amplifier knew better though.
------------- Kevin
North Staffordshire
Date Posted: 24 May 2017 at 9:14am
yeh i no, ive scrapped the amplifier for spares now, i also have a behringer ep4000 that i had switched on after a while which got extreme hot to the touch then smoke, though on inspection the only damage i can see is one of the hitachi transisters has completly cracked in half!!!
