Problem connecting MiniDSP to PA |
tommontereye
Registered User Joined: 02 April 2016 Location: melbourne Status: Offline Points: 16 |
Posted: 14 April 2016 at 12:40pm |
My MiniDSP 2x4 has just arrived and iv downloaded the 2/4 advanced software and done all the necessary set up.
i have my source (laptop) connected to the DSP via a 3.5mm to RCA cable into inputs 1 & 2, The DSP is then connected by RCA to 3.5mm from channels 1 & 2 too the 3.5 input of my 2 channel digital amp (i use this amp constantly and would normally connect it by 3.5mm cable to my laptop and it works fine) The amp is connected to a passive PA speaker which obviously has an inbuilt cross over. i have done all this, changed absolutely nothing in the DSP settings but when i connect it all up and hit play all the signal is being sent to the woofer of the PA and nothing to the tweeter so it obviously sounds worse than rubbish and i cant figure out whats wrong. Is there something in the original set up of the DSP that would be doing it or am i using the wrong cables possibly?
odc04r
And are you only connecting one output of your amp. to this speaker? Sounds like it.
What are you trying to do? Bi-amp the speaker so that one amplifier channel drives the woofer and that the other drives everything above it? If so you need to remove the passive crossover and directly connect your amplifier to the right components of the cab. You have already filtered the signals in the miniDSP so you don't want to do it again with passive filtering. |
tommontereye
The speaker runs off one channel of the amp correct, same as i always have when using it before and it works perfectly, i bought the DSP because i am building a sub (not done yet) and i wanted to apply a high pass filter to the PA at 120Hz and send the rest to the sub.
since i am only running the one speaker not left and right am i doing the right thing by having the 3.5 connected to both inputs or should i just be running a 3.5 to single RCA on one output and same out the other side? |
tommontereye
i dont the dsp to act as a cross over i just want it to apply low/high pass filters and possibly delays for the sub, i cant imagine this is particularly difficult im just simply too new to understand what im doing wrong
toastyghost
Swap the red and white RCA connectors on the MiniDSP end.
odc04r
What he said, sounds like you are sending <120Hz to your cabinet instead of >120Hz.
tommontereye
I tried swapping the cables around on both the in and the out and it didn't make a difference so I'm not sure that's it unfortunately
tommontereye
I thought that too so I set the dsp back to regular settings and didn't put any filters on but had the same problem. |
odc04r
Swapping the inputs round won't make a difference assuming you have a valid signal coming into both L+R of the MiniDSP.
Time to go back to basics. Something must be wrong in the MiniDSP settings. Set up output one with zero processing, no filters, 0db gain. Then connect just output one to one of your amplifier channels, and the output of the amplifier channel to a cabinet. If you can't get a full range signal out of the cab something is wrong with the MiniDSP settings, or the caninet crossover. You can eliminate the cab crossover by plugging your source direct to the amplifier channel. If that works your issue has to be with the MiniDSP settings. |
tommontereye
Thank you! Il try when I get home, when I make this connection I only need to use single RCA to RCA cables with a 3.5 stereo jack adapter on both sides right? |
odc04r
Yeah, assuming both L+R signals are going into the MiniDSP ok you only really need to plug in on each end. To cover all bases if you like plug the output lead into both output one and output 2 of the MiniDSP, and set up both outputs to have no filtering and 0dB gain. Then at least whatever channel of the amplifier you plug the speaker into it should be seeing a signal.
Tbh it shouldn't be that hard to get working, there must be something fairly basic wrong. I have never used the software myself but I'd also be very carefully re-reading the manual just in case something got missed. |
tommontereye
Got afew different mono cables and tampered with the high/low pass filters and all is good. thank you for your help!
