Problem with 12v system |
Post Reply | Page 12> |
app
Old Croc Joined: 26 December 2013 Location: Finland Status: Offline Points: 2435 |
Posted: 10 March 2014 at 4:17pm |
Greetings!
I built a mono system which is mono and is using a behringer xenyx 302usb as a mixer and sure electronics 2x25w amplifier.Speakers are p.audio hp-10w and p.audio pht-409. The problem is that id like to get more volume out of it but the thing starts to clip and distort. Do I need: 1.More power from the battery for example 18v or 24v instead of 12v? 2.More powerful amplifier 2x50w instead of 2x25w? 3.Something else,what? Thanks! |
"what!?"
lutkeveld
Probably a gain problem with your amplifier. You have to set the gain to the highest when using a mobile phone or other low output device.
app
Well my friend has a preamp and I have the mixer and the same problem occurs.
The gain setting dont have an effect on the clipping. Maybe 12volts is not enough for the speakers and the amplifier? |
"what!?"
lutkeveld
How do you mean 'The gain setting dont have an effect on the clipping'? Have you tried it or do you assume it? If you use a pre amp it shouldn't be on the highest setting.
I thought of the ta2024 version but that's the 15 watt version. Your amp is not suited for 12 volt usage, it only delivers around 10 watts in 4 ohms. You should look into buying TA2020 based amps or the MaxAmp from Accusafe. Max amount watts will increase and the idle current will decrease.
Edited by lutkeveld - 10 March 2014 at 5:01pm |
app
Ive tested it.Theres a certain limit of volume which we cant cross no matter the settings of the amp/mixer.
Maybe there is a problem with the sure amplifier.
I hope the problem can be solved.Ill order the maxamp now... |
"what!?"
lutkeveld
The problem cannot be solved. It's limited by the amplifier chip. It won't give more power unless you give it more voltage. You could step up your 12v to 24-30v to utilize it's full potential but that will use a lot more power.
Edited by lutkeveld - 10 March 2014 at 5:28pm |
slaz
Yeah your supply voltage is too low.
One thing thing you might try is using a "car laptop power adapter". Its just a DC-DC step up converter. I've used one OK at 24V driving a Sure 2050 amplifier - set the o/p voltage at 16, 18,19 etc..... one gotcha though is that if you power up the converter before connecting/switching on the amp, the converter goes into protect, as it sees too low resistance (mebbe when charging up the smoothing caps). I works OK though if the converter is connected first - in that case you'd want a good chunky DC switch prob rated at 10A or more in the 12V line. Obviously this will shorten your battery life quite a bit - so you might need to double the size of battery. Oh yeah - get one with a higher power rating e.g. 120W. Edited by slaz - 10 March 2014 at 6:30pm |
lutkeveld
Or just get a boost converter, costs almost nothing. Take this one for example:
http://www.ebay.com/itm/150W-8A-DC-8-32V-to-9-46V-12v-24v-36-step-up-BOOST-converter-pc-car-power-Supply-/400557877161?pt=LH_DefaultDomain_0&hash=item5d431c27a9 or this one; http://www.ebay.com/itm/DC-DC-600W-10-60V-to-12-80V-24V-Boost-Converter-Step-up-Module-CAR-Power-Supply-/281214694457?pt=LH_DefaultDomain_0&hash=item4179b3b439
app
Thanks for the help guysNuff respect!
I ordered the maxamp.I want to try it anyway since ive heard a lot of good things about it and its the recommended amp for the boominator for example at the moment. Nice to see some activity at the 12v forum
"what!?"
app
By the way the speakers are 8ohm so wouldnt that be like 5watts or something?
"what!?"
WesleyK
Registered User Joined: 24 December 2012 Status: Offline Points: 90 |
Yep something like that, would also explain why it's not going loud enough. With a maxamp and 12V you'll be looking at about 8W (no distortion) and 10W with 10% THD.
app
What do you guys think.Is there a big difference in volume and sound quality if im usin for example 3meters of audio cable vs 1,5meters or 1meter.Does it make any difference?
"what!?"
