problem with martin raptor fan.... |
mk2_ginger_biscuit69
Posted: 21 September 2014 at 8:19pm |
so its a basic old fixture, but one unit has a broken fan.... is a pretty basic 12v DC high volume unit.
so went checking around with a multimeter [while comparing it too a working unit], got 15.5v on the PCB fan outlet, checked the fan on a 12v bench supply and that was fine, so checked the voltage at the fan which was only 1.5-2v, thus presumed a dodgy cable to the fan/connector. So i swapped that out, and still no joy. Swapped the entire fan assembly out of a working unit, and that didn't work. so what could be going on? Why am i getting the voltage i should, yet it simply refuses to work? Tried finding a 12v supply on the PCB to solder the fan onto but failed. ideas? |
djeddie
Is there a dry joint in there somewhere? Not familiar with those internals, but sounds like it might be that. Or a broken/damaged cable somewhere.
The reason you're reading the correct voltage might be because the multimeter has a very high input impedance and therefore doesn't load the circuit in any way. The voltage might be there but the current isn't... if you see what I mean. |
mini-mad
Is it on all the time or thermally controled? (Just asking)
ahhh good point! will have another bash at it tomorrow evening, this time i think im going to take it out and have a proper look around. The actual control PCB is only the size of a kingsize box of matches, with about 10 components... very simple design!! |
well given up, and just soldered an external 12v PSU to the fan.... will try and fix it in a fortnight once i have some more time, im about to go sailing for a week, disembarking the night before the disco! But for now, its ran an hour problem free so that'll do for now!
Edited by mk2_ginger_biscuit69 - 23 September 2014 at 10:27pm |
djeddie
Fair play Pat!
simonp1100
Young Croc Joined: 01 September 2008 Location: Bristol Status: Offline Points: 1103 |
Check the main smoothing capacitor on the PCB board, could have dried out due to the heat.
