  New Posts New Posts RSS Feed - Proel PSW 2600
Proel PSW 2600
subconscious View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote subconscious Quote  Post ReplyReply Direct Link To This Post Topic: Proel PSW 2600
    Posted: 08 February 2012 at 4:56pm
Has anyone on here used and worked with any Proel amplifier particularly PSW 2600
I was considering buying one and seeing it's performance but I want to gather some reliable information before hand
What are peoples views on these products
Any info will help
Regards
CSE Powersupplies View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CSE Powersupplies Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2012 at 7:01pm
Would not buy... Accuracy 20-20 is only +/-1dB and THD 1% @1KHz. You may get junk with old capacitors and used price/ sold out prices are too high. Stability @ 2R is not known. You may get a new DB HPA2800 or a Pronomic X800 for less money. I personnally would take a Calm D1400 or a DJG DA1400 for nearly half the rpice an double power ... just if you are looking for iron amps.
dwsound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwsound Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2012 at 7:14pm
I was a service engineer @ proel UK, and there were several issues with the PSW range.
The time and effort of repairing said amplifiers outweighed the cost price to be honest.
They have a quirky assembly around the heatsink which is the output devices are assembled to the heatsink by machine and then another assembly is put over them and fixed to the heatsink.
Thus when we get to repair them to say its a pain is an understatement and hugely time consuming.
In the end we ended up just board swapping as it worked out cheaper to buy in the assembly than to repair it.
Spares were not very forthcomingv :(
Performance wise theyre not all that bad its just a case of when they die not if.
Personally i really wouldnt through any money at them.
Sound Engineering|PA hire|Pro Audio sales|Design & Installation
T: 07734 035 958 - E: info@dwsound.co.uk - W: www.dwsound.co.uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote CSE Powersupplies Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2012 at 9:08pm
Proel is an Italian company, isn't it ... anyone tried to fix a Fiat? Wonder if you leave the garage without slitted artery Evil Smile
Tried to get some engineering-data from the new HPD series - no chance, they did not support data. Someone claimed they use digam-power-modules in it what I should take as a q-statement?? No reply about SMPTE, slew rate, THD, transient recovery... By the way - some days ago I saw totally equal ones on a Chinese website ... do not await that these guys are going to cover Proel, necessarily. Make heads or tails of it. They have no dealer left in Germany. These days they make some kind of direct marketing with two people located in the "Ruhrpott".
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2012 at 10:36pm
When I've bench tested them I wasn't impressed by the performance.  Ok but far from great.
I think Mr DWSound's post probably answers the question....
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwsound Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2012 at 10:46pm
the HD amplifiers from proel ,are indeed powersoft modules, built by sekaku in china.
the alto D series amplifiers are basically the same as the HD - the HD series have a slightly different psu arangement, a nicer chassis/look and selectable HPF/LPF filters on the rear.
lukam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lukam Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2012 at 7:36am
dwsound is right! I repaired one myself and I tell you it realy is a pain to remove those heathsinks. And after the service it didn't survive more than 2 months. But performance wasn't sooo bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote subconscious Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2012 at 9:58pm
Thanks for the helpful information I wont be purchasing one of these in the near future
Forum Software by Web Wiz Forums® version 10.11
