  New Posts New Posts RSS Feed - Proline 3000 running 4 x Kappa 15 LF
rosssss224 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosssss224 Quote  Post ReplyReply Direct Link To This Post Topic: Proline 3000 running 4 x Kappa 15 LF
    Posted: 13 February 2017 at 3:27pm
I recently got a proline 3000 to run my 4 cubo 15's and wondering how careful I need to be. Of course will avoid clipping as best as possible but is there a risk of over powering the drivers with the bench tested 1850w @ 4ohms? The kappas are 600w rms 1200w  peak although I am naturally dubious about how useful wattage rating are.
Any advice appreciated. Thanks.
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2017 at 4:11pm
knowing that a proline can get a pair of 1850s basket's front rim hot to the touch, I would reckon it can pretty much sodomize four Kappa 15lfs  if not careful. but provided with a safety margin & not pure 30 Hz sine wave signal why not. At least you won't run out of headroom
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosssss224 Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2017 at 5:04pm
its the safety margin im having some trouble with!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosssss224 Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2017 at 5:05pm
Currently thinking to set limiter on the ultradrive to -22db then roll back -6db on the sub output. 40-90hz
Edited by rosssss224 - 13 February 2017 at 5:06pm
spongebob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spongebob Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2017 at 5:38pm
You MUST run an XLR attenuator on the Ultradrive output channel for the proline, even the harshest limiter setting possible (-22db) on it will clip the tits off the Proline
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosssss224 Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2017 at 6:18pm
I assume these are just a more solid equivalent to turning the gain on the output down? Extends limiter range to -32db?
Thanks for the reply. Was concerned id missed something
Edited by rosssss224 - 13 February 2017 at 6:22pm
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2017 at 7:11pm
Bad link
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2017 at 7:40pm
yu wont be getting a proline clipping on them four kappas very much doubt it,
yul smoke them drivers on power alone, before clip,
so plenty power
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosssss224 Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2017 at 7:51pm
So does anyone have a solution to run this successfully? Im quite aware the prolines a hefty amp for some not so hefty drivers :D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2017 at 7:53pm
come on bro, ears man
dont drink too much lol
not being a arse lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosssss224 Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2017 at 7:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosssss224 Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2017 at 7:54pm
haha well thats fine then! That I can do.
