  New Posts New Posts RSS Feed - Push-Pull Tapped Horn
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 09 June 2009 at 1:35pm
what are the drivers in this box
http://www.danleysoundlabs.com/tapped_horn.asp?MODEL=TH%20221
neo magnets. i thought they were b&c initially but i think they have 8 spokes on the basket. it's hard to tell from the photo. anyone recognise them?
cheers
Phil
jethrocker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jethrocker Quote  Post ReplyReply Direct Link To This Post Posted: 09 June 2009 at 5:55pm
Well,  seems DSL are using alot of new faital pro neos, and those drivers seem to have the distinctive
faital magnet structure.  Faital don't have a 21" model listed on their site, so could be oem.
Deadbeat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deadbeat Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2009 at 10:17am
Yer. You noticed them on the synergies as well?
Comps as well. Their phase plug up to throat thing seems to do quite well.
Away on extended leave.
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2009 at 11:05am
"i thought they were b&c initially but i think they have 8 spokes on the basket"
Blow up the pdf to 300%~400%, you will see it's the B&C.
Edited by _djk_ - 10 June 2009 at 11:10am
djk
sheffield-junglist View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sheffield-junglist Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2009 at 11:23pm
Originally posted by john binary john binary wrote:
how do push pull cabs work ?
Its basically one driver facing one way and another driver wired 180 degrees out of phase (Positive wire connected to negative terminal, negative wire connected to positive terminal) facing the other way. This makes them basically behave like one driver. When one pushes, the other pulls and vice versa hence push-pull cabs.
Wiring a driver out of phase will make it move forwards when it should be moving backwards etc...
It creates a perfectly inverse signal
Sorry if you knew the phase stuff but I'm not sure how much you already knowSmile
Edited by sheffield-junglist - 16 June 2009 at 11:25pm
AndyWave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyWave Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2009 at 1:53pm
Originally posted by james folkes james folkes wrote:
i bemoan the demise of the 12lx60, it was an absolutely fabulous driver.
why do manufactureres always seem to pull the really good ranges and continue the useless ones! grr...
james.
Why not use 12P1000Nd model instead?
I've made a pair of 1*12" tapped subs with them for live music bar. (or should I call them bass cabs since they're tuned to 45Hz). Works well. Design guidelines are in same ballpark as in DJK's 40Hz example.
2pcs 45Hz single tapped horns parallel
Def_Const |Horn Dimensions
a1 = 490e-4; |Area at throat (cm^2)
a2 = 532e-4; |Area at rear of driver (cm^2)
a3 = 1400e-4; |Area at front of driver (cm^2)
a4 = 3080e-4; |Area at mouth (cm^2)
l1 = 15e-2; |Distance from throat to rear of driver (cm)
l2 = 210e-2; |Line distance from rear of driver to front of driver (cm)
l3 = 24e-2; |Distance from front of driver to mouth (cm)
Def_Driver 'Dr1'
|2pcs Beyma 12P1000N
Sd=1100cm2
fs=47Hz
Qes=0.27
Qms=7.89
Vas=98L
Re=2.55ohm
Le=1.0mH
system 'S1'
Driver Def='Dr1' Node=1=0=3=4
Waveguide 'W1' Node=2=3 STh={a1} SMo={a2} Len={l1} Conical
Waveguide 'W2' Node=3=4 STh={a2} SMo={a3} Len={l2} Conical
Horn 'H1' Node=4 STh={a3} SMo={a4} Len={l3} Conical
Graphs
http://www.speakerporn.com/displayimage.php?album=30&pos=8
Tested 'em with ev CP-3000S in bridge mode, clipping (more or less 1600W peak each), until I could smell the glue getting hotLOL.
No excursion problems (x mech 52mm p-p). Bar drives them with 2x PSL1200 in bridge (2x 8R load). Limiters set from -1dB from clip. Running everyday, no problems.
Andy
torturing electrons since ......
