QSC vs Berry INUKE |
Post Reply | Page <1 3456> |
toastyghost
Wait for it.....it's the cost of research and development though the K series design is about 10 years old so long paid for. Would love to hear the inuke 12000 and PCM 20 side by side.[/QUOTE] Yes and of course once a design has paid for itself you stop making any money, and of course you never spend a penny on R&D for other projects. Jesus Christ. |
toastyghost
Also this is the dynamic of well designed Class D really. If people stopped talking watts and actually used Volts, which is more accurate anyway, then it wouldn't be so surprising. Voltage swing is king, especially for high crest factor music. Edited by toastyghost - 08 December 2016 at 8:52pm |
jammin75
Old Croc Joined: 08 July 2012 Location: west midlands Status: Offline Points: 2375 |
over 2 years ago wen i first got my inuke 6000 dsp been goin strong ever since how views have changed |
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4539 |
paulus
Old Croc Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3181 |
i have no experience with i nuke 6000 on sub , but mentioned is the sae 1450, this is also an impressive amp for the money,i strap 4 x 1850s on mine 2 a side cut 33 to 77 with good results and no clipping,i find it very smooth and the cone control is 2nd to none,have surprised a few people with it when they come to look at amps and do not see a 3u monster,i changed my big void infinite for one,tho being in a 2u case i was sceptical,but dont watch that,stays ice ice cold even after 6 hour hire outs and hits the lows, my hire outs are all heavy drum and bass and jungle so lots of low material, if it did not do the job would have be off loaded by now :)
Edited by paulus - 09 December 2016 at 8:18am |
TRENDSETTER SOUND SYSTEM
osse
Registered User Joined: 26 August 2013 Location: Sverige Status: Offline Points: 84 |
Interesting, do you apply any voltage limiter? If so, at what voltage? I'm limiting my two 18sw115-8(one each side) at about 95v, and with low crestfactor 40 hz basslines it starts to clip slightly. I wonder which driver is more powerhungry, 1850(I guess you use 8 ohm models) or 18sw115-8? In the future I might get two more drivers so your insight is valuable regarding how you drive your system! Do you blow any fuses running the system hot with 4 drivers? Thanks Edited by osse - 09 December 2016 at 8:59am |
paulus
i use a limiter on my LMS so the amp when i going for it, hits the clip say every 5 secs,yes 1850s are 8 ohm drivers, 2 in parallel so running 4 ohm per channel , tho i will add i do use a 6mm feed and when running on 13 amp plug tops use the bass amp on its own plug,i have only took the breakers out once so far and that was being lazy and running all sound off 1 plug top, i now use 6mm feeds to bass amp thenanother 6mm to the rest, tho that driver you have is a 1700w beast and 97db , have found the limiters on the amp it self very good also no nastys or loss of damping on cones at high/flat out level, not that i am saying you should run it flat out i think with drivers like you have there more power will be needed, or go down the bridge root
Edited by paulus - 09 December 2016 at 10:21am |
levyte357-
B&C 18SW115 has Reference efficiency (no) Value of 1.9%, which makes the published sensitivity value of 97db pure fiction/manufacturer lies. PD1850 (Not Series 2), is far more efficient. Berry INUKE 6000 will not be sufficient to drive 1x 18SW115 per channel. In fact, due to very low efficiency of this driver, would imagine most amps would clip, before fully powering a pair of these, per channel. |
toastyghost
Perhaps contact Bennet Prescott if you think the B&C specs are lies. They're very open about how numbers are derived.
levyte357-
I said the published sensitivity was lies, which it is. According to this calculator, http://www.mh-audio.nl/Reference.asp the reference efficiency is 1.83, and the sensitivity is actually 94.6. Maybe plug in T/S values for V18-1000, JBL 2226H, PD1850 (series 1), Fane Colossus 18-400, to get an idea, of which drivers are close to real 97db sensitivity. EDIT:Is nothing new, or particular to B&C. Most driver manufacturers, embellish sensitivity figures, as they know most buyers swallow the figures as gospel, and only the really discerning buyers, will take the time to calculate them, given T/S parms, and draw up spreadsheet, comparing Reference efficiencies.
Edited by levyte357- - 09 December 2016 at 11:55am |
Timebomb
reference efficiency and sensitivity are not the same thing Lev, sensitivity can be measured at a specific frequency, or averaged over a band, you change the band you chance the sensitivity. Its really not a question of one number, No. is derived from free air parameters anyway, once you load the driver it all changes.
levyte357-
The above has was argued previously here. However a little strange, that Void V18-1000 calculated Ref efficiency of approx 3.57, is also inline with published sensitivity of approx 97.7 I've found Rog's approach to be fundamentally correct, most Manufacturers invent fairytale sensitivity, and the really sensitive drivers, have decent reference efficiency, and the published sensitivity figure, is inline with calculated no. This is the case with Series1 PD1850, JBL 2226H, Fane-18-400. Distributors selling low efficiency 18s on SP, tend to disagree with this, but I'll stick with Rog on this one. Edited by levyte357- - 09 December 2016 at 12:08pm |
