  New Posts New Posts RSS Feed - 'Quad' ES18BPH
'Quad' ES18BPH
teknojay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teknojay Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2013 at 4:19pm
its was shocking Freddy, can't believe someone would do that to 4 es18's :/
ShokZi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ShokZi Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2013 at 7:09pm
im so very confused.. are 2 firing out the side??
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2013 at 7:23pm
nooo... they all fire into a central point and then out of the port facing you using the two horns as 1 big horn.
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2013 at 7:47pm
a bit like the 70's trouser flapping design but...... the back two now have a longer horn path. To get this to work all 4 horn paths would need to be the same length, and all four cabs would need there own horn not shared. It would work by allowing all four to couple once the sound has left the box....
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2013 at 7:56pm
well, wots done is done... get your measuring gear out and lets see what youve created Dr Frankinstien. and if you can delay those front two cab just a tiny tiny amount... theres only a few cm's in it but im sure it will make a difference.
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2013 at 8:01pm
Defo delay will be needed. Not sure how to rescue this one other than using electronics
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2013 at 8:11pm
i recon a tiny amount of delay will "cure" most problems.... just hook it all up and give it a bit of real-world testing and tweaking. but as on AB test stack 4 ES's beside it mouth coupled and listern for any difference in depth/punch...sorry kick... and play with the bandwidth a little too. you never know it may cure honkyness from being played to high. either way you already got the foreplay out the way you might as well go balls deep and see what its capable of!
Twiggy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Twiggy Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2014 at 6:41pm
I foresee in the very near future 4 blown drivers
AlfieDring View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlfieDring Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2014 at 10:04pm
Which will at least have the positive effect of making it easier to decide on throwing whats left of the cabs out
To the O/P do you mind if i ask,  what are the other speakers in your setup? not sure if its just how there stacked or a trick of the lens but the left part of that wall and the ones on the top of the right stack look like they also have chopped fronts or a spikey bit sticking out? sorry not sure exactly how to explain that. Just wondered if thats so and are they your design?
Alf
Requiem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Requiem Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2014 at 11:59pm
i can see the pic now, hmmm. lol
www.requiem-soundsystem.com
Custom Martin Audio WSX, USB & CSG Soundsystem based in Bristol
