Question on ohms |
Page <12 |
| Author | ||
Requiem
Joined: 20 January 2011 Location: Hampshire Status: Offline Points: 531 |
Posted: 27 January 2012 at 10:55am |
Cheers i didnt know that, that is where i was confusing people, i got parallel confused with series
yeah i assumed the drivers i was getting would be exactly the same as the ones i already had as they were the same driver but apparently not. ill just run one top at 4 ohms and one at 8 thanks for your help guys
Edited by Requiem - 27 January 2012 at 10:59am |
kedwardsleisure
Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 1941 |
Posted: 27 January 2012 at 6:48pm |
Are these in an MR228?
North Staffordshire |
Requiem
Posted: 27 January 2012 at 8:48pm |
kedwardsleisure
Posted: 27 January 2012 at 10:20pm |
The reason I ask is; dont they have crossovers in? Changing the impedance of the drivers will change the response of the crossovers and screw the cabinet characteristics.
Edited by kedwardsleisure - 27 January 2012 at 10:21pm |
Requiem
Posted: 27 January 2012 at 10:31pm |
nope no crossovers, its biamped- the big horn and the bullets run off one input with the bullets on a 7khz filter and the 2x 12" drivers run off a seperate input
kedwardsleisure
Posted: 27 January 2012 at 11:18pm |
OK but surely they should be the same if you're running them together unless you can address the response difference in an LMS
Requiem
Posted: 28 January 2012 at 10:08am |
i have no idea - that was the purpose of this thread.
a driver needed replacing in each top, and the new ones i got were exactly the same but the 8 ohm version whereas the drivers i already had were the 16 ohm version. was trying to find out if i could run one of each in each top or not, but is probably better to run one top at 4 ohms and one at 8 so far as ive been advised
Disco Stu
Joined: 03 March 2005 Location: United Kingdom Status: Offline Points: 2437 |
Posted: 29 January 2012 at 11:45am |
Personally I would just send the drivers back and get the right ones.
Stu
All you need to know is:
Sensitivity + Power Handling - Power Compression = Max Output My acts: www.myspace.com/thebowiexperience www.myspace.com/scheisseelektronisches |
Page <12 |
Tweet
