RCF ART200a 12" driver |
BJtheDJ
Young Croc Joined: 28 November 2012 Location: Bristol Status: Offline Points: 886 |
Posted: 20 October 2016 at 7:38pm |
Have just acquired four of these; two of them have noisy volume pots and one of them has a rattly bass driver.
I've found advice on replacing the pots but welcome suggestions about a replacement 12" driver. Should I go for a recone or are there other, cheaper, drivers out there which would fit and do the same job and maybe be an improvement - and maybe even lighten the cab ?? cheers BJ |
KDW32
Young Croc Joined: 09 April 2010 Location: Green Hell Status: Offline Points: 540 |
You might be able to sort out the noisy pots with a bit of switch cleaner. I use Servisol super 10. I fixed a couple to Turbosound Milans and a Crown XTi last week with it.
krazyneil
Young Croc Joined: 06 December 2007 Location: Bolton ,lancs Status: Offline Points: 1206 |
I don't think you will find anything cheaper that will match the rcf driver so a recone is the best option
GOD TOLD ME TO DO IT !!!!!
MattStolton
Need a little care with Servisol or other cleaning solvents. In the worst case they can dissolve the carbon track itself (Servisol 10 is designed for brass contacts in light switches, to remove arc crud build up! i.e. carbon residue). Equally, most pots have some form of semi conductive grease, keeping things smooth and slidy, and excluding air to track (to stop oxidation). Most solvents get rid of that first. Some of the crackle can be caused by dust trapped in the grease, making the wipers jump (think stylus on record) and you hear mini arcs as the wipers lift of the carbon tracks. Sadly, any solvent approach tends to be a short fix, so replacement is the only real long term fix. Sorry to be the bearer of bad news, but been there, done that. Got a load of QSC RMX pots that all need doing, so feel your pain! They are famous for oxidation related crackles, and mine have just started....
KDW32
Interesting I always though as super 10 was a cleaner and lubricant as well it was safe to use. It gets advertised for pots and faders as well. Their website mentions nothing about being made for brass light switches.
http://www.crcind.com/csp/web/ProdDisp.csp?lng=3&idx=1828331&country=GB&product=SOL%20SUPER%2010&brand=SERVISOL
Thanks for the info. I'm going to give them an email and ask about their product dissolving carbon tracks. |
BJtheDJ
Thanx for the reply. I found a three-year-old thread in another forum
giving the various options for replacing the pots which are apparently
board-mounted and not an easy replacemtn.
The Servisol link that you gave said "A highly efficient switch and contact cleaner. It offers a combination of high purity electrical cleaning and mechanical lubrications for contacts, switches and relays." but no mention of by them of pots or faders. cheers BJ |
KDW32
It's on amazon as
Brand New Servisol Super 10 Professional DJ Fader and Switch Cleaner Spray https://www.amazon.co.uk/Brand-Servisol-Professional-Switch-Cleaner/dp/B000KHE1D0 Possibly miss leading description. I have also seen recommended on other forums as safe to use on pots as as it's lubricated. I'll post up the email response I get back. |
BJtheDJ
Heehee. That description by "Motionperformance - Waxacar."
I wonder if they'd take performance advice from a Sound Engineer or DJ ?? cheers BJ |
KDW32
Here's the response
Good Afternoon, Thank you for your enquiry. Our technical department have advised that Super 10 has been used successfully on amplifier volume pots. However, we do not have any test data on it being using on carbon faders. Hope this helps, if you need any further information please let us know. |
