  New Posts New Posts RSS Feed - rcf l12 544k
rcf l12 544k
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Topic: rcf l12 544k
    Posted: 20 February 2017 at 3:50pm
got these in some mt121 sort of ish similar cabs any feed back on what they are like? LOL with no idea on the comps atm and some cp22 i think beyma bullets
horn loaded for her pleasure
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2017 at 5:34pm
should work fine, dont expect much "lowend" extension though..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2017 at 7:53pm
thats all good itl be used above our 186 horns so 120 at a push lowest probably 150hz until i get the doobers sorted lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2017 at 11:23pm
without more details on those cabs its hard to say, naturally i would expect that driver to fall off quickly below 200ish hz due to its low Q/high efficiency.. 120? not likely, even with "hi tech" drivers in sp12.. ;) 160 sounds more reasonable, cut them shallower and leave a gap to the 186s, might sound better..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 23 February 2017 at 1:48pm
these are aparantly the preffered choice for the phillishaves? ahhhhh
cant find t/s params anywhere for them lol
madboffin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboffin Quote  Post ReplyReply Direct Link To This Post Posted: 25 February 2017 at 7:37pm
Data for the L12/544 is on this sheet:
http://www.spamabyss.net/pictures/L12544.jpg
The "K" in L12/554K just means the voice coil was the improved version (Kapton former).
I would expect the parameters to be very similar, though that's not guaranteed!
charlynch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote charlynch Quote  Post ReplyReply Direct Link To This Post Posted: 25 February 2017 at 11:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2017 at 12:32am
So would these work in mt121/122? And would getting another pair be hard?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2017 at 12:45am
Better still fx12? 150hz up to 1khz ish?
This page was generated in 0.281 seconds.
