recording music |
krazyneil
Young Croc Joined: 06 December 2007 Location: Bolton ,lancs Status: Offline Points: 1206 |
Posted: 26 March 2017 at 7:49pm |
ok guys as an artist and commercial dj f 2 years and I've meddled with recording karaoke nights and stuff originally twin tape deck, then borrowed a cdr recorder and tried with that all with limited success
I have got all the main gear as you'd expect ,dynacord powermate mixing desk, mics, speakers ect and changed ever to laptop for djing but what do I need to start recording stuff a bit more professionally ,this is mainly for me but im a stickler for my sound so its got to be right I have also been challenged to do 10 different songs a week for a year so was thing of recording these maybe on a facebook site or youtube so it can be verified ,ive tld them ill lok into it and see what I need,ive seen loads of people n youtube singing and stuff but not sure how yu go about it hopefully some of you here will have some nuggets of wisdom for me
GOD TOLD ME TO DO IT !!!!!
jacethebase
X32 Producer is a good bet.
www.stage2sound.com |
shagnasty
X32 is a good bet, but I would forget the producer, for an extra £200 you can have the compact, which has scribble strips, making it a more than an the 8 ch desk the producer is.
But be aware you will need a laptop with software (Reaper would be fine) to multitrack record, the inbuilt USB is stereo only. you would also need a mic splitter like the MS8000 for this setup, unless you are the kinda maniac that records off shared pre-amps (which IMHO can't be done). I am also thinking maybe you just want to record stereo direct to disk, in which case buy a behringer UCA-202 (which are really good and you need to spend like 10 times more to get a lot better) and pluf that into a laptop, again you will need Reaper or Adobe Audition type software ideally to record but you can get WAV file to burn direct to CD... |
jacethebase
Producer is perfect for recording especially with its DAW mode. As this is what it was designed for.
shagnasty
The lack of scribble strips is just un-forgivable IMHO, make sit as useless as a Yamaha.....
jacethebase
Yeah that is annoying but its simple to use DAW interface and rack mount size make it a amazing tool for on site multitrack recording.
shagnasty
TBH, for onsite the last thing you need is any kinda of surface, a Rack would be miles better, personally I use a rack of D8s and Hammerfall running DigiCheck, If I could work out how to sync 2 s16s I would use them, but AES-50 appears to have a random clock agenda to say the least..
70,s hero
Young Croc Joined: 14 December 2014 Location: bristol Status: Offline Points: 637 |
I have an Akai DPS 16 (with effects), may be worth a go, pretty versatile desk, only issue is that export is only one channell so any mixing ,finalizing is done on the desk. Dont want a lot for it P.M. me if interested.
Top banana
MarjanM
If all you need is recording the whole output (no multi track) then all you need is a nice two channel external sound card.
Main output from the powermate to the sound card inputs and then record to your laptop using Soundforge or some similar program. This will be easiest way if that is what you actually want.
krazyneil
that's sounds easiest, as I use Tascam iur2 soundcard so that might work in reality I just want to record myself to put some songs onto website or discs for customers to listen to if I can do this using what ive got here and plug into the record outs on the powermate and that will record the whole sound on to my spare laptop then ill give that a try out I can work out the challenge aspect later lol
