  New Posts New Posts RSS Feed - Reflex Port/Vol Relationship
SwenK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SwenK Quote  Post ReplyReply Direct Link To This Post Topic: Reflex Port/Vol Relationship
    Posted: 04 February 2012 at 4:01pm
Hi
I originally listed this in the newbie section, becaiuse for loudspeaker builders i guessed it is a newbie question, but go no bites.
So i have a design of a basic square sub with an  18" driver. 600x600x600mm
Keeping the driver the same, if i reduce the volume of the cabinet from 173L to 160ish is there a simple calculator that allows me to calculate the change in port length/size required to meet the same tuning?
so everything is remaining the same except i am shaving 2cm off the width and height  of the box, but adding 2cm to the depth.
Realistically how much effect is this going to have anyway on a 173L box?
i know i can fit two 58cm cabinets (guess what brand) side by side, two high in my van and its snug, so wanna build something that i can get in there in the same arrangement.
thanks in advance
s.
It's an artistic piece...but i like it
hmaudio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmaudio Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2012 at 4:03pm
http://www.linearteam.dk/default.aspx?pageid=winisdpro
winisd is easy enuf to use even i can use it LOL
We all start from the bottom, very few, in comparison, make it to the top.
Forum Software by Web Wiz Forums® version 10.11
