  New Posts New Posts RSS Feed - replacement 2" drivers
wires View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wires Quote  Post ReplyReply Direct Link To This Post Topic: replacement 2" drivers
    Posted: 25 May 2016 at 11:42am
Been looking at newer 2" compression drivers on the market and wondering about peoples opinions.
Various boxes i run have beyma 850nd, cp800ti and cp380 in. I find these very musical but the high end does roll off on the 2" quite alot.
Any comparisons/results/opinions on replacement ideas from companies like BMS and 18sound?
Thanks
all bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2016 at 8:23pm
The BMS coax drivers.
Teunos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teunos Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2016 at 8:28pm
@Bas, 18 Juni Mariaheide zomercarnaval, are you coming?
Best regards,
Teun.
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2016 at 8:34pm
Until a look at google maps just a minute ago i diddn't even know about the existence of that place...
Are, and your rig, there? I'd be interrested to be there in that case.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teunos Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2016 at 8:42pm
jup, will be there, 8 subs, 4 or 8 kicks, 4 mids and 4 highs.
Not to derail the topic too much, as far as 2'' drivers go, i would definitely vouch for the BMS coaxials.
I have the ferrite version.
Would love to have the Neodymium version.
Looking back, i should have splashed a bit more to get Neo instead of ferrite.
Edited by Teunos - 25 May 2016 at 8:43pm
Best regards,
Teun.
Shortrope View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shortrope Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2016 at 9:33pm
Yes...BMS coax...lovely sounding.
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2016 at 9:53pm
Depending on how low you need to go, some of the modern 2.5" VC, 1.4" exit drivers can be a good alternative and go a bit higher than a 2".  Also depends on the horn flare too, some will behave better at high frequencies.
You can usually EQ most decent 2" drivers to give reasonable extension but they'll never quite match a 1" for sound just due to the moving mass and higher air volumes.
Grinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grinner Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2016 at 10:43pm
what horns are good for the bms coax?
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2016 at 1:08pm
RCF HF950 and 18Sound XT1464 have been used by Peter Morris in his Ultimate DIY Mid High, think they're both 1.4 versions IIRC.
Lots of solid info on them in the DIY section at soundforums.net.
HTH,
David.
lickweed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lickweed Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2016 at 10:08am
b&c de610 de82-1.4",de75,de85, bms4590,92 sounds good to me.
Im sure there are others but i have experience with above
Edited by lickweed - 16 June 2016 at 10:09am
http://www.liquidsound.co.uk/
