  New Posts New Posts RSS Feed - Replacement driver choices for a double 12" cab,
Message Reverse Sort Order
CPHSOUNDSYSTEM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CPHSOUNDSYSTEM Quote  Post ReplyReply Direct Link To This Post Topic: Replacement driver choices for a double 12" cab,
    Posted: 13 January 2008 at 1:19pm
PDN.12MH25 - Neodymium
They are Pd 12" rated at 300rms
not to sure on the price though
STOP WARS NOT DANCES
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2008 at 6:34pm
Kevin, I have just read your first post again and I think that the Bass bins are already built, if so please ignore my last post. I must read more carefully next time.
Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2008 at 12:44pm
I would question the use of PD184's whilst they work OK in a reflex box they are not ideal.
Have a look at the Beyma 18P1000Nd or 18P1200Nd these really have moved the goal posts.
Another great choice would be the BMS18N850v2 which work beautifully in a 140l enclosure but are pretty expensive(£270).
Tony
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2008 at 12:37pm
It's a nice idea but ultimately probably causes more issues than it solves.  In these boxes the frequencies are covered easily.  Taking mine for example:
The 12" driver is capable of playing to probably 3kHz fairly cleanly (ignore the fact it'll get a bit beamy).  The compression driver and horn combo is useable down to 500Hz (although you wouldn't want to because of power handling issues).
This means that at a crossover point of 1.2kHz both drivers are capable of doing an octave either side of it, making for a very clean transition between the two.
tweeter box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2008 at 12:31pm
Just a thought;
The bottom 12" keep as a low mid
Change the top 12" to a 10" or 8" and use as a high mid
Itll run as a 4 way setup and youll cover the frequencies better.
Ive used the B&C comps they give a beautiful sound but cant remember what horns they were!
Nice drawing Teks.
Edited by tweeter box - 12 January 2008 at 12:33pm
PRECISION SOUND SYSTEM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2008 at 12:26pm
No, the 12NDL76 in terms of parameters is closest to the 12MH32 although the neo has about double the excursion capability of the MH32.
12PE32 is a dedicated midrange driver, has a very light cone and only a 2.5"VC and ideally should only be used on mid horns from about 200Hz up.
Although saying that the 12ND710 I use in my mid-tops is a dedicated midrange driver and I use it down to 120Hz.  It does mean there is a bit of a dip in the system between 120Hz and 200Hz but since it's not unusual to put a cut in the EQ around there on most systems, you don't really notice it missing.
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2008 at 11:51am
Originally posted by Wrighty Wrighty wrote:
DE250 = 108.5dB @ 1W @ 1m. 60W continuous (RMS) power handling
PD912 = 97dB @ 1W @ 1m. 300W continuous (RMS) power handling
DE250 continuous SPL = 108.5 + 10log(60/1) = 126.3dB
PD912 continuous SPL = 97 + 10log(300/1) = 121.8dB
   => 2xPD912 continuous SPL = 124.8dB
Therefore, I'd say a single DE250 would keep up with a pair of 12s. Unless they're 100dB neo 12s with 400W RMS power handling like B&C 12NDL76, in which case a single will be almost perfectly matched to the DE250.
I'm more than sure I've read somewhere on here which I can't find, but last question before deciding on which 12'' to go for, whether these or the 18Sounds Neo driver.
Is the B&C 12NDL76 the Neo version of the B&C 12PE32's ?
Cheers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 16 July 2007 at 1:47am
Kevin,
Did you see my thread about the cabs I build recently of this type?
http://www.speakerplans.com/forum/forum_posts.asp?TID=10250&KW=cha2214
The cabs have now been fitted with 18Sound 12ND710's which are incredibly efficient and will work well with high crossover points to the HF.
I'm using the currently unavailable PDC14 that you also wanted to use.  I would recommend using a larger compression driver and getting the crossover point down.
In terms of alternative compression drivers, the 18Sound drivers are worth considering.  They are quite bright sounding and need a bit of work on the processor but that done you get a very detailed sound.  Not particularly expensive.  Also worth looking at how much some of the new B&C 1.4" drivers are, or maybe the DE610.  Definitely recommend the 18Sound 1.4" flares though.
And just to help your decision process if you want to go down the other route a DE250 on 1086XT with a single 12", crossover 2kHz ish is also very nice indeed.Again 18Sound maybe for a 12" or B&C 12NDL76.
Most of the 12" drivers I've suggested will exhibit the roll off on the low end.  This is just due to their high midband efficiency and the very strong magnets used to acheive it.I find a low shelf starting about 160Hz and lifting the low end by 3-4dB tends to flatten it out.The other option is to use a slight overlap with the subs.
Oh, and one twin 12" mid top will keep up with about 3 18" bass bins!
kevinmcdonough View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevinmcdonough Quote  Post ReplyReply Direct Link To This Post Posted: 15 July 2007 at 5:18pm
Originally posted by AlfieDring AlfieDring wrote:
Tiny word of warning about the reflex ports in your tops. If you cut them like that the port piece (assuming you need to extend it beyond the baffle depth? - if not ignore all this!) ends up being mightily complicated to cut as its got no 90' angles in it. It has to follow the trap angle to keep the same dimensions throughout the port. You also have to make an angled cut into the baffle or else the port will have a slight constriction at the very end.
Ill show you a picture of what i mean when we sort out the net at home, just moved house ya see :)
Alf
hey,
no need I understand exactly what you mean.
No the port was chosed specifically to be 18mm deep so that it would just be the depth of the badffle wood and essentially just a hole
With the dew drivers the design has changed anyway and its now a long shelf port right across the bottom of the cab, but again just 18 mm deep so very easily made by just making the baffle slightly shorter than the rest of the cab.
k
AlfieDring View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlfieDring Quote  Post ReplyReply Direct Link To This Post Posted: 15 July 2007 at 4:48pm
Alf
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevinmcdonough Quote  Post ReplyReply Direct Link To This Post Posted: 15 July 2007 at 3:24pm
hey
LOL, yeah unfortunatly that was exact driver   my other post www.speakerplans.com/forum/forum_posts.asp?TID=10798 has the info i got from PD. You'll still be able to buy whatever stocks are left in shops and things, but once they're gone looks like that'll be it.
PD 122  looks great for a single 12" + CD cab, or ArthurG's recomended neo Beyma will work great doubled up with a very wide and gentle para eq centered around 200Hz just taking 1 or 2 dB out and smoothing things off.
k
rich, ind.st View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich, ind.st Quote  Post ReplyReply Direct Link To This Post Posted: 15 July 2007 at 3:00pm
regards someone mentioning an 8 horn between the 12's and cd. ive got a design worked out for that already, it uses the de250 on the 18sound horn, a jan audio horn with eminence 8 mra and 2 12's which win isd tells me is good for 127db, can be crossed around 80 hz and has very low group delay.
if you want the plans your welcome, just pm me...
 i reckon you would get away with using 2 a side, it'll work out cheaper than buying a shed load of 12's and they sound very good...
music is god
Forum Software by Web Wiz Forums® version 10.10
