  New Posts New Posts RSS Feed - Rhino/MS18 Mk2/Mk3 with V18-1000
Absulum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Absulum Quote  Post ReplyReply Direct Link To This Post Topic: Rhino/MS18 Mk2/Mk3 with V18-1000
    Posted: 06 November 2012 at 4:46pm
Hi,
Firstly am i right in thinking that the Void V18-1000 is suited to the Rhino MK2, and the MS18 MK3?
I was sold a pair of Rhino MK2's, however im not entirely sure if they actually were Rhino's or MS18's (they were built buy someone after the Rhino plans were withdrawn, and i believe there was some confusion).
I believe the Rhino and the MS18 are very similar, but that the mk2 versions are slightly different?
In which case is there any way to work out which my scoop is and whether i can use the V18-1000 in it or if i should mod it into a mk3 first?
(up till now I've used them loaded with Fane 18XB)
Cheers
phildat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phildat Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2012 at 7:44pm
Mk.2 fine w. Voids
Mk.3 more spl.
Did u get them off biker dave? I sold 2 pairs to him and they absolutely rhinos mk.2 if so.
Great cabs and wicked combination...
Its just a ride.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Absulum Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2012 at 8:18pm
Nope got them off stitchy on here, will send him a pm.
You sayin Rhino mk2 is fine, or that mk2 of either rhino or ms18 is fine?
and mk3 gives higher spl, but wouldnt work with the voids? or that i should mod them to mk3 to get a higher spl with the voids?
Cheers
mans1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mans1000 Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2012 at 8:30pm
MK3 sound awesome with voids.
"The earth provides enough to satisfy every mans needs...but not every mans greed."
t.geessounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2012 at 8:30pm
the rhino is deeper than ms18 or its easy to tell if its the rhino or the ms18
Post Options Post Options   Thanks (0) Thanks(0)   Quote Absulum Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2012 at 8:32pm
is that the front chamber thats deeper or the whole cab?
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2012 at 8:33pm
whole cab
stitchy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stitchy Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2012 at 8:45pm
just to clear things up quickly they are definitely RHINO'S MK2,built by myself
Post Options Post Options   Thanks (0) Thanks(0)   Quote Absulum Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2012 at 8:55pm
all sorted haha :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2012 at 9:12pm
ok u got a rhino Wink
mykey- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 07 November 2012 at 12:03am
If you want to make them a Mk3 just add a 18mm board to the rear baffle panel. You can do this with one panel in half sections glued and screwed.
Autograff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Autograff Quote  Post ReplyReply Direct Link To This Post Posted: 07 November 2012 at 3:08pm
A sound in Sheffield has 8 Rhino MKIII's with V18-1000, they are alright, but seem to blow easily.
That could be down to who's running it though.
This page was generated in 4.516 seconds.
