RMX2450 Knobs |
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8711 |
Posted: 11 March 2012 at 3:43pm |
Hey all,
I wanna give my amps a squirt of switch cleaner, how do the volume knobs on the QSC come off? Do they just pull off? I tried giving them a bit of a tugged but they don't seem to move and neither I nor Lev wanted to force them. Cheers, Sam |
taurusty
Registered User Joined: 09 January 2007 Location: Jamaica Status: Offline Points: 473 |
They pull off, if I recollect correctly. Better you pull down the amp & remove the module in it"s entirety & clean properly. Think switch cleaner mite damage the tracks
duck1
Registered User Joined: 22 February 2008 Status: Offline Points: 173 |
I cleaned the pots on pair of these a couple of years back. IIRC, the knobs just slide off. I ended up taking the whole pot apart to clean it though...
kedwardsleisure
Yes, pull off knobs. .
North Staffordshire |
ceharden
The only way to successfully clean the pots on those amps is to remove them from the board, bend the little tabs that hold them together, dismantle and then clean with a cotton bud soaked in switch cleaner. At which point it is probably easier just to fit a new set. Unfortunately just squirting some switch cleaner into them doesn't really help with the root cause of the problem.
I recently dismantled some to try and find out why they failed so quickly on these amps. The answer appears to be that it's not the carbon track that gets dirty but the conductive track which joins the wiper back to the centre contact oxidising up. Looks like silver plating that's getting tarnished. |
kedwardsleisure
Made by Taiwan Alpha. Cheap pots in an otherwise good amp.
I fit a superior type when they go. |
SamV
Which one do you recommend?
