Router guide cutting bits/ bearings |
Page 12> |
lukelucas93
Joined: 05 July 2011 Location: Carlisle Status: Offline Points: 519 |
Topic: Router guide cutting bits/ bearingsPosted: 13 June 2012 at 2:48pm |
Can any cab builders help me out I want a couple of these to use with my jig however all the ones I'v found have had too long a shank I'm probs just looking for the wrong thing
or maybe some where that sells a bearing kit
If its too loud... Your wayy too old...
shagnasty
Joined: 30 July 2007 Location: Guildford, UK Status: Offline Points: 4423 |
Posted: 13 June 2012 at 5:41pm |
Too long?? Most routers have a bed that goes up and down to allow you to set a cutting depth, explain what jig you have and what you are trying to do and I may be able to help...
lukelucas93
Posted: 13 June 2012 at 6:30pm |
Right I have a 12mm jig/ template and want the depth of the channel to be 5mm the cutting edge only has to be 7mm then the bearing above this blade will have to sit against the jig edge.... hard to explain
I'll see if i can throw a little diagram together ![]() Edited by lukelucas93 - 13 June 2012 at 9:28pm |
shagnasty
Posted: 13 June 2012 at 7:02pm |
I see, what i would do is fix a bit of 18mm(or whatever you need to loose the extra depth) under your template so you can get a tidy 5mm cutter protrusion, if you have 12mm template you have some adjustment there as the bearing is usually about 5mm so a 35mm cutter would work for you...
lukelucas93
Posted: 13 June 2012 at 9:27pm |
Thats the little diagram this hopefully makes more sense Edited by lukelucas93 - 13 June 2012 at 9:29pm |
shagnasty
Posted: 13 June 2012 at 11:47pm |
bee
Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 1699 |
Posted: 13 June 2012 at 11:55pm |
the smallest cutters i have like this are 20mm in length.... as allready said can you not raise the template up by using some batton..... normally i use a collet on my routers instead of bearing cutters.....
shagnasty
Posted: 14 June 2012 at 12:00am |
lukelucas93
Posted: 14 June 2012 at 12:21am |
Can someone to link me to a supplier for these cutters i cant find any small ones
dlyxover
Joined: 14 June 2007 Location: Liverpool Status: Offline Points: 829 |
Posted: 14 June 2012 at 12:52am |
In the Truth there is no news, and in the News there is no truth
johnatron
Joined: 18 November 2008 Location: Lancashire Status: Offline Points: 153 |
Posted: 14 June 2012 at 12:56am |
when i rebate cabs i use an 18mm straight cutting bit then use a 30mm guide bush to to keep the cutter centered in the 30mm channel on the template.
I find using bearings on templates over and over the messes up the template.
I always do a dry fit on a piece of scrap mdf just to make sure the template is true. You'll probably need a new jig tho if you have an 18mm profile on your jig like the diagram below |
dlyxover
Posted: 14 June 2012 at 1:06am |
Ive been making jigs tonight.
Used a 10mm bit with a 30mm guide bush but have been making jigs for handles and connector plates and top hats. I would agree with johnatron for rebaiting. using bits with bearings I've found fatigue your jugs rather quickly.
Page 12> |
Tweet
