Forum Home Forum Home > General > Wanted
  New Posts New Posts RSS Feed - Router guide cutting bits/ bearings
lukelucas93 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lukelucas93 Quote  Post ReplyReply Direct Link To This Post Topic: Router guide cutting bits/ bearings
    Posted: 13 June 2012 at 2:48pm
Can any cab builders help me out I want a couple of these to use with my jig however all the ones I'v found have had too long a shank I'm probs just looking for the wrong thing or maybe some where that sells a bearing kit
If its too loud... Your wayy too old...
shagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 13 June 2012 at 5:41pm
Too long?? Most routers have a bed that goes up and down to allow you to set a cutting depth, explain what jig you have and what you are trying to do and I may be able to help...
Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote lukelucas93 Quote  Post ReplyReply Direct Link To This Post Posted: 13 June 2012 at 6:30pm
Right I have a 12mm jig/ template and want the depth of the channel to be 5mm the cutting edge only has to be 7mm then the bearing above this blade will have to sit against the jig edge.... hard to explain
I'll see if i can throw a little diagram together
Edited by lukelucas93 - 13 June 2012 at 9:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 13 June 2012 at 7:02pm
I see, what i would do is fix a bit of 18mm(or whatever you need to loose the extra depth) under your template so you can get a tidy 5mm cutter protrusion, if you have 12mm template you have some adjustment there as the bearing is usually about 5mm so a 35mm cutter would work for you...
Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote lukelucas93 Quote  Post ReplyReply Direct Link To This Post Posted: 13 June 2012 at 9:27pm
Smile
Thats the little diagram this hopefully makes more sense
Edited by lukelucas93 - 13 June 2012 at 9:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 13 June 2012 at 11:47pm
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 13 June 2012 at 11:55pm
the smallest cutters i have like this are 20mm in length.... as allready said can you not raise the template up by using some batton..... normally i use a collet on my routers instead of bearing cutters.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2012 at 12:00am
batons won't work you need a bit of MDF of similar the same size as the template, I have template laser cut in steel to use a 30mm collect but if you have a 1:1 template you can use teh cutter shown, you just need to use a bit of scrap sheet to space it out, personaly I would mark the shet with template and then jig-saw/freehand route it a bit bigger than the cut lines so the sheet isn't heating up the cutter, when you do this you MUST have either good extraction of blow compressed air into the cut line to stop the bit clogging up with dust....
Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote lukelucas93 Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2012 at 12:21am
Can someone to link me to a supplier for these cutters i cant find any small ones
dlyxover View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2012 at 12:52am
In the Truth there is no news, and in the News there is no truth
johnatron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnatron Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2012 at 12:56am
when i rebate cabs i use an 18mm straight cutting bit then use a 30mm guide bush to to keep the cutter centered in the 30mm channel on the template.
I find using bearings on templates over and over the messes up the template.
I always do a dry fit on a piece of scrap mdf just to make sure the template is true.
You'll probably need a new jig tho if you  have an 18mm profile on your jig
like the diagram below
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2012 at 1:06am
Ive been making jigs tonight.
Used a 10mm bit with a 30mm guide bush but have been making jigs for handles and connector plates and top hats.
I would agree with johnatron for rebaiting.
using bits with bearings I've found fatigue your jugs rather quickly.
web department
