  New Posts New Posts RSS Feed - sb1000 eaw
sb1000 eaw
Tom Umney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 10 July 2005 at 11:07pm
Think EAW SB1000 is a dipole reflex design.
TDA-Audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2005 at 2:16pm
EAW SB1000 plans-
http://www.igolkin.com//soft/Tda-audio/upload/EAW-SB1000.pdf
omari7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omari7 Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2005 at 2:17pm
The EAW BH882ip drivers by RCF are no longer available.  Does anyone have an idea of what woofers would be a good replacement.
I own two EAW BH882ip, and I am looking for two more.
Omari
ar49@nyu.edu
Omari
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2005 at 4:06pm
If those are really the plans for a SB1000 then it is a BP6, not BR.
In addition to that the SB1000 is pretty inefficient. Only 95dB 1W/1m! Yes, both 18s driven.
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2005 at 4:08pm
Or somewhere in between, that manifold is very negligible
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2005 at 6:04pm
The plans which have been floating around on here are NOT the SB1000. It's lacking the large central port which they have common to both drivers.  I know cos I've had the grill off one and stuck my arm in it to see how far it goes!
tslson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tslson Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2008 at 6:15am
Originally posted by jers jers wrote:
I seek the plan of SB 1000 eaw
do you have a plan for sb-1000 eaw
tech sound and lighting show
mylesound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mylesound Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2008 at 4:48pm
3 years ago i hired 6 of them to take care of the rear of my truck for NY carnival. sounded crap compared to only 4 single 18 foled horns i used last year.
SURINAME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SURINAME Quote  Post ReplyReply Direct Link To This Post Posted: 06 February 2008 at 8:50pm
CHECK THIS OUT!!!!!!!!!!!!!!!!!!!!!
http://www.snakepro.com/pdf/proj/projeto_18_01.pdf
BETTER LATE THEN NEVER ENJOY................
Post Options Post Options   Thanks (0) Thanks(0)   Quote SURINAME Quote  Post ReplyReply Direct Link To This Post Posted: 06 February 2008 at 9:08pm
sirck50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sirck50 Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2010 at 7:39pm
THAT LINK IS not THE sb1000 PLAN. Anyone knows how the central port is built? Dimensions?
4q
kumar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kumar Quote  Post ReplyReply Direct Link To This Post Posted: 13 April 2011 at 12:49pm
hi all i also need same plan but i got some pics its not eaw sb 1000 but similar to this
Forum Software by Web Wiz Forums® version 11.07
Copyright ©2001-2016 Web Wiz Ltd.
This page was generated in 0.160 seconds.
