  New Posts New Posts RSS Feed - scoop amps
scoop amps
(SoundcreationaudiO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote (SoundcreationaudiO) Quote  Post ReplyReply Direct Link To This Post Topic: scoop amps
    Posted: 17 March 2008 at 7:38am
alright guys...   what amp would i idealy have if i wanted to drive 12 scoops all loaded with the Royal Turbomax 1200i..?  infinite 8? 3 cabs per side, but not much room for error like...  or an amp that can do 2600-2800@4ohm per channel?
Tiff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tiff Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2008 at 5:08pm
12 drivers that size on one amp?
dont think even the infinte 8 mrk 2 can do that m8.nest bet wud be to get 2 amps
SmokeyJoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmokeyJoe Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2008 at 5:42pm
You would be better off with two Infinite 8's!
That would slap your Scoops!
Post Options Post Options   Thanks (0) Thanks(0)   Quote (SoundcreationaudiO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2008 at 5:49pm
yes guys, i meant what make/model amps to drive 12 scoops..  i thought about 2 infinite 8 mk2, 3 scoops per channel..  should do the job nicely.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2008 at 6:40pm
Definitely a smart choice if you have the cash.
Jhodas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhodas Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2008 at 7:37pm
^^ +1
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2008 at 8:15pm
For this application, You also should consider 2x Crest 9001s, if you have the power supply available.
I would class the 3kW per channel at 2ohms as conservative.
Edited by levyte357 - 18 March 2008 at 8:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SmokeyJoe Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2008 at 10:31pm
Hello, these look new and interesting:
http://www.crownaudio.com/amp_htm/mai.htm
What you rekon people?
- Joe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhodas Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2008 at 11:30am
not out yet, but the voids will undoubtedly be cheaper. More power by the looks of it too. the 12000i is coming into the US at nearly $7k, which puts it at £3500 ish, more than twice what the voids cost.
Go with the infinites. I can personally vouch for them pushing scoops. So can my eardrums.
